Question about HP LaserJet 2300 Printer
Problems with duplex printing
Even though the printer is capable of duplex printing, it continues to do it manually via tray 1 when duplex is selected.
  • gggg May 27, 2010
    What do you mean, it does it manually? So it is duplex printing? Are you using thick or heavy paper?
  • mgollan May 27, 2010
    I'm using normal paper. It wants me to manually move the paper to tray 1 as opposed to doing it automatically from one of the other paper trays.
  • 903 Answers
So you're saying it will only pull paper from tray 1? This is likely because there is some setting that makes it think the paper in the other tray is not "normal" -- either thick paper, or a different size, or recycled. Check the paper type and size settings in the printer's menu, and also check the settings in the print driver.
The other tray that you want to duplex from is capable of duplexing, right? On some printers you can only duplex from specific trays.
Posted on May 27, 2010
Dell 966 aio printer....paper jam and I cannot release paper from roller. Is there a way to release roller?
Have you read the Manual on paper removal? It mentions a rear panel that can be removed. That might free up the rollers:
If the paper jam is near the paper input tray:
1. Remove the paper tray.
2. Pull firmly on the paper to remove it.
3. Replace the paper tray.
4. Press the Select button .
5. Resend your print job to print any missing pages.
If the paper jam is not visible:
1. Turn off the printer.
2. Lift the printer unit.
3. Firmly grasp the paper, and gently pull it from the printer.
4. Close the printer unit.
5. Turn on the printer, and print the document again.
If the jam is located in the duplex unit or near the rear access door:
1. If you have a duplex unit, remove it.
2. Open the rear access door.
4. Close the rear access door.
5. Re-install the duplex unit.
6. Press the Select button to continue printing.
If the paper jam occurs near the ADF:
1. Lift the ADF cover located to the left of the ADF input tray.
2. Firmly grasp the paper, and then gently pull it from the printer.
3. Close the ADF cover.
Aug 28, 2013 | Dell 966 All-In-One InkJet Printer
Auto Duplex Unit Not Working Model: HP LaserJet 2420dn I am using Windows XP and installed "HP LaserJet 2420 PCL 5e" driver. It is connected via internet and when I try to print double...
You need to go into the print driver on your Windows machine and go to the Device settings tab. One of the settings is to set whether the unit has a duplexer or not. It does not always set automatically.
Jun 23, 2011 | HP LaserJet 2420dn Printer
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
Duplex printing not happening
In your printer model duplex printing is not supported. But it can be achieved using the manual duplex printing option. In the printer properties select the type of duplex printing you want to take and click on print. Once the printing got over on one side of the papers, then you will be prompted to turn the whole printed paper bundle and keep in the tray again and continue the printing. Now by this way duplex printing is done in your printer model.
I hope this is useful to you.
Please rate the solution provided.
Thanks
Mar 31, 2010 | HP J4680 Office Jet All-In-One Printer
Printing from wrong tray
I suffered from the same problem for a long time. We got Xerox Phaser 8550 and 8560 here. I choose on computer "tray 2" but the printer just print from tray 1 which is empty.
Today i figured it out! It's some configuration at the printer. So go to "Paper tray setp" -> "Tray 1 mode" and "Tray 2 mode" -> change to "static".
I figure it's like this. Before it was "dynamic", it probably means the printer decides it's better to use tray 1 even though you choose tray 2 - and this decision is stupid. Changing it to "static" fixes this.
Let me know whether this works for you too!
Feb 12, 2010 | Xerox Phaser 8560MFP Laser Printer
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
HP 3600dn Duplexing Issue
Manual 2-sided printing. Most of the supported media sizes and types listed for printing from tray 1 can be manually duplexed. Do not use the 2–sided printing feature on transparencies, envelopes, or labels.
I found this note in the 3600 service manual. Maybe it will help.
Mar 06, 2009 | HP LaserJet 3600dn Printer
Xerox Phaser 8560 Not Duplexing
Check to make sure that "Plain Paper" is selected as the paper type for tray 2 in the printer's internal setup. If it's not set as the default then the printer may think you have labels or some other special media loaded that can't be printed in duplex.
1. Go to the printer.
2. Use the up and down arrow keys to hilight "Paper Tray Setup" on the main menu and push "OK".
3. Use the up and down arrow keys to hilight "Tray 2 Paper Type" and push "OK".
4. Hilight "Plain Paper" and push "OK".
5. Press the return button (the one with the little rounded arrow symbol) to return to the main menu.
That should solve it.
GOOD LUCK!!!!!!
Feb 13, 2009 | Xerox Phaser 8560DN Laser Printer
Duplexer
If you really have an HP 4350dtn (d = duplexer), then the duplexer is not connected correctly. Look at the back of the printer for the duplexer. It prtrudes from the back drop down tray and is used to print on both sides. I would pull it out and push it back in to make sure all connections are tight.
Tray number 1 is the manual feed tray in the front of the unit.
Mar 03, 2008 | HP LaserJet 4350dtn Printer
Duplex printing
The HP Laserjet 4+ does not have duplex capability built in; you'd need to purchase and attach the duplex unit (HP part number C3157A) to have that option.
Depending on your operating system, your driver may support a "manual duplex" mode in which you print one side, reload the paper, and then print the other side. You can also "fake" this from many applications (such as MS Office / OpenOffice) by telling it to print only even-numbered pages, then printing only odd-numbered pages.
Nov 13, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 2300 Printer Logo
391 people viewed this question
Seeker5211
Seeker5211
