Question about Proform 560hr Treadmill Walking Belt
Will not move belt
When i press the start button the belt will not move incline and display is still working fine
    President:
  • Proform Master
  • 832 Answers
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled. The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
Posted on May 31, 2010
Just got Nordictrack 1750. Assembly was easy but incline does not work. Everything else seems to be okay. Took motor cover off and do not seem to be getting any power to incline motor.
go HOOD cover motor follow the steps or ready your owner manual, and RUN the software calibration for easy diagnostic and fix it.
The
Steps for Newer Style Console Calibration
1. Locate the calibration area on the
rear or underside of the console (a hole, near the console\'s center, that goes
through to the electronics board. (This hole should not have a screw in
it.)
2. Insert a pencil (eraser end),
into the hole and feel around for the cal button (will click when
pressed).
3. Press the button 2 times
(with the pencil eraser). The first click should show CL11 in the
console, the second click should show CL21.
4. If the process was done correctly,
and CL21 appears in the console, you are in "calibration mode."
The next few steps consists of pressing buttons on the console
and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in
the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in
7. Press ENTER. CL24 should display in
8. Press ENTER. CL25 should
display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should
display in the TIME window. You should then see the letter
"E."
10.
Press
ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be
off, the treadmill.
12.
Push
the ENTER button. The walking belt should start to move, accelerate to maximum
speed, then stop on its own.
13.
When
the belt stops, the incline should self test by raising to its
highest incline position, then lowering back down to its lowest position.
14.
Once
the incline test is complete, push the POWER button 2 times. The unit should
shut off and the console should go completely blank. If this
happens, the treadmill is done calibrating and is ready for use.
If the letter
"F" appears in the SPEED or INCLINE window when the power button is
pressed 2 times, the treadmill is indicating a failure somewhere
either in the SPEED or INCLINE (depending on the window the
"F" appeared in). Troubleshooting the failure would be the next
step.
God bless you
Oct 17, 2013 | Nordic Track Exercise & Fitness
I have a Proform 1026 EXP treadmill that began running at full speed whenever it is turned on. The incline controls function normally but the belt speed is incredibly high. When set to 1.5 MPH (the slowest...
please run the Software calibration see the instruction.
GOD BLESS you
The Steps for Newer Style Console Calibration
1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10. Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Sep 18, 2013 | Proform 1026 Exp Treadmill Motor Control...
Horizon treadmill won't incline
Step 1:
see the diagram attached.
Clean the motor, lube the gear+shaft
Adjust the small POT for a little.
RUN the software calibration for troubleshooting. see the diagram
Step 2:
Step 3:
Step 4:
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
Feb 07, 2013 | Horizon Fitness Horizon T101 9 Program...
X9i incline trainer clicking
Step 1:
RUN the calibration software . and fix it. God bless you
Step 2:
Feb 07, 2013 | Nordic Track Incline Trainer X9i...
Tempo 621T treadmill incline Incline reads 0.0 but is not all the way down. How to bring it down.
you must RUN the software calibration, for troubleshooting and fix it.
See the steps.
The Steps fhor Newer Style Console Calibration:
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the
    1. F" appeared in). Troubleshooting the failure would be the next step.
Jan 09, 2013 | Exercise & Fitness
Tempo 621T treadmill stuck in incline postion scale is reading 0 but it is not completely down..How to reset my incline button
Run the software calibration for troubleshooting and fix it. See the next steps. God bless you
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Lube the elevation motor, shaft and gear. adjust the POTentiomer,
Milestone 1200 series
RUN the software calibration see the steps.
However lube+clean the elevation motor, shaft and gear, and adjust the small POTentiomenter for fix it.
God bless you
Treadmill belt runs too fast and will not power off with control panel
Step 1:
test the speed sensor,m for open or faulty, clean it, and tight the connector. see the diagram attached.
However follow the steps for RUN the.s calibration for fix it.
God bless you
Step 2:
The Steps for Newer Style Console Calibration:
Jan 07, 2013 | Exercise & Fitness
I hae a Pro Form 540 Iteracive Trainer treadmill. When the key is inserted, the treadmill cuts on but the control panel doesn't seem to work when you touch start. I waited and cut it off and went...
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful."
Aug 08, 2011 | Sport & Outdoor - Others
We have a 600 mx and the pad is not working, the only button working is the start, i cannot increase speed or incline it either.
It is very unusual to have no incline or walking belt operation..
Try entering diagnostic mode and do a calibration. The instructions are found under the motor cover on a tech sheet.
1: with the safety key removed, press stop and speed up simultaniously.
2: Attach the magnetic safety key.
3: press stop 1 time.
4: at this time, by pressing the incline up, the incline should calibrate, going up to maximum then back to minimum..
5: press the speed up key, you will see the numbers on the console increase. The machine should start moving the walking belt around 25-30 on the display. At 85 the belt should be running at maximum speed.
6: press speed down, the machine should stop.
7: remove the safety key. Now replace the safety key and try the machine again.If any of this procedure didn't work, I would suspect a defective console. Otherwise, the motor controller may need replacing.
Good Luck
Dec 14, 2010 | Epic 600 Mx Treadmill
Proform 560hr Treadmill Walking Belt Logo
548 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
