Question about Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
I have a new modem from comcast and now my router will not connect to the internet. i have reset the router and even connected directly to the router to see if i can get internet and still can not get through. what should i check next?
    Sergeant:
  • 358 Answers
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
ISP Cable or Dynamic
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9: ISP DSL
Note: If your connection is DSL choose the connection type as PPOE
and set your User name and Password( ask yous ISP provider
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
========= WIRELESS SETTING UP A WIRELESS CONNECTION ====================
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Posted on Nov 01, 2010
3 Suggested Answers
SOURCE: BelkinMIMO wireless router stopped connecting to internet
I just installed a Belkin N1 (model F5D8635-4 v1000) to a Comcast Arris modem in SW Florida by resetting the IP on the router to 192.168.1.1 Comcast assigns 198.168.0.1 (but will accept 192.168.1.1 however not .2.1) and Belkin default is 192.168.2.1. Problem is easy enough to correct by following the instructions for changing the default router IP using a Firefox interface as documented in the user's manual. Note that when applying changes it takes about 30 seconds for changes to be effective.
Posted on Oct 03, 2009
bschilz
  • 2049 Answers
SOURCE: Moved router to connect directly to the Comcast
Your ISP should have given you the following information...
Static IP, Internet IP Address, Subnet Mask, Gateway, Static DNS 1-3.
With that information at hand, follow tis link to the router user manual and go to Page 11 of the manual to go through the step by step process of setting the router up for an internet connection.
http://downloads.linksysbycisco.com/downloads/WRT54GX2v2_ug,1.pdf
Posted on Nov 26, 2009
WRT54GS ROUTER don't work with new modem
I would suggest you to look into the user manual first it may solve your problem.
Click HERE
Goodluck..
Feb 15, 2008 | Linksys Wireless-G WRT54GS Router...
Globe symbol won't turn green.
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
Jun 08, 2010 | D-Link Wireless N 150 Home Router 4Port...
I have a Zonet Router that I am hooking up to Comcast DSL internet. i show that i am connected but i can not get online. i duplicated the MAC address i just dont know what else can be wrong. is there a...
The first thing is that Comcast is Not a DSL connection it is Cable connection. Now first make sure that your computer will be able to go on line when connected directly to the modem. Connect your main computer directly to the comcast modem and check if that goes on line. If not then you will need to contact Comcast and get main computer on line. If it is online then reset your router for 30 seconds. release the reset and wait for 1 minute. Now connect the main computer to the router and comcast modem to the router. open the set up page and Clone the MAC address of the " Main " computer.
power cycle the modem and the router. See if it works.
Click here for more information about router and networking
Apr 19, 2010 | Zonet ZSR1104WE Wireless Router
D-link has stopped working with comcast internet.
Are you trying to install the router.You can do it manually
without the CD.
MAke sure that your computer is able to go
online through the modem.
If your computer is able to go online
through the modem
Then you need to connect the computer to the
router ad the modem to the router.
open the set up page of the
router and change the settings of the router according to the
ISP.
Click Here for step by step by instructions
Jan 16, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Moved router to connect directly to the Comcast modem that also provides VOIP. Comcast activated modem and internet works when computer is connected directly to Comcast modem. Router does not connect to...
Nov 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Router wont work with new modem
Hello Ladoof,
We offer support for Comcast supported routers because they are widely used in the world today. If you are using one such router and it has stopped working, then you just need to call us for instant support.
Comcast Tech Support Internet Help Toll Free 1855 856 2653
May 08, 2009 | Blitzz Technology Computers & Internet
New internet provider
Can you get one computer to surf directly from the modem? if yes, connect the router wan port to the modem
press the reset button on the modem and after resetting the modem, try to get an IP from your router
if it doesn't work, get the MAC address from comcast device and clone it to your router WAN MAC (hope this option is available on the router)
Apr 13, 2009 | Edimax BR-6104P Router
No internet when using router
Your modem has already registered itself with the MAC address of your computer, so it doesn't recognize the MAC of your router. In cases like this you have two options:
  1. Configure your router to clone the MAC of your computer
  2. Connect the router to your modem and do a soft reset so the modem registers itself with the MAC of your router.
Clone MAC - Go to your routers Admin web interface and on the main page you should see the "Router MAC Address" section at the bottom. Select "Use Computer MAC Address" and click "Apply" and your router should reboot and you'll be back in business.
Soft Reset
- Plug the modem into the router via the ethernet cable then do a soft reset.
To do a soft reset, do the following:
  1. pull the power cord from the modem
  2. count to 5
  3. hold down the Reset EMR button on the modem
  4. plug back in the power
  5. count to 30 while holding the Reset EMR button (the modem should be blinking a lot)
  6. release the Reset EMR button and see what happens.
Jul 07, 2008 | Computers & Internet
Became new customer to comcast-got the bundle package, internet,phone,cable. Voice overlay modem to accomodate internet and phone lines. Did not use their wireless router-using exsiting router D-Link model...
Hi jad123,
I am sorry to learn about the problems you are experiencing with your service.
I will be happy to reach out to my contacts to assist you in resolving this issue. Please feel free to contact me so that I can get more information from you.
Thanks in advance!
Mark C.
Comcast Executive Offices
We_Can_Help@cable.comcast.com
Apr 10, 2008 | Computers & Internet
Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Logo
104 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
