Question about Brother IntelliFax-2820 Laser Fax
Vertical stripes appear on incoming faxes - Brother IntelliFax-2820 Laser Fax
  • 125 Answers
Hi:
Try making a copy and verify that the vertical stripes are showing up in the same area. If not, then the problem is not with your fax but the sending fax.
Andrew
Posted on May 27, 2010
My TV is showing only vertical stripes. Audio is ok
Hi Arquimedes,
It appears to be a Tcon board issue. Tcon boards are repairable at times. Please contact some good TV tech.
Jul 24, 2015 | Televison & Video
Samsung CLX-6220-FX vertical lines when scanning and copying
The reason for such lines if they appear only on scans/copies from the automatic document feeder (adf), but not on regular scans and printouts is that there is dirt on the small glass stripe next to the scanner area that is used for scanning from the adf. Just clean that glass stripe and the lines should go away.
Jan 21, 2014 | Samsung CLX 6220FX - multifunction fax /...
Black Stripe on outgoing faxes
If the stripe is a thin line, the scanner glass is dirty, if it is wide stripe you have a bad scanner block. EXPENSIVE
Jul 01, 2010 | Brother IntelliFAX 4100 Laser Fax
Black stripe down right side of incoming faxes and copies, cleaned view window but still there and actually got worse.
pull your drum unit out and look at the top of it. you will see a blue plastic tab. that tab has got to be all the way on the left side. if not, it will cause a black stripe about 3/4" wide.
hth,
razors
Mar 03, 2010 | Brother IntelliFAX 4100 Laser Fax
Black vertical Stripe
Move the blue slider on the drum cartridge side to side 10 times.
Jan 30, 2009 | Brother IntelliFAX 5750e Laser Fax
Printing of incoming faxes
I have the same problem on my hp all-in-one. it looks like a staple went through the copier and it shows on incoming faxes as well...
May 21, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Blank vertical stripes on incoming faxes
1st. Print a report. If the blank stripes are still there, you must remove the drum and t6oner combination and clean the laser glass located on the bottom of the machine.
If the blank stripes do not appear, then the fault is on the scanner of the sending fax machine.
Feb 25, 2008 | Brother IntelliFAX 2800 Laser Fax
White "Stripes" across page
REPLACE PAPER AND THE INK CARTRIDGE
May 14, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
Brother IntelliFax-2820 Laser Fax Logo
83 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
