Question about Garmin StreetPilot c510 Deluxe GPS Receiver
Cant find satellites
Used both resets, downloaded update no joy.
for some reason i'm stuck in central london.
any idea how i might cure this at the moment just
says aquiring satelites with a flashing '?' on the car.
  • tierntot May 22, 2008
    wont acquire sattilites
Same problem the acquiring satellites appears with a flashing '?' some where in central london 'horseguard', ......the unit switches on and off i have reset it used hard and soft reset methods.....updated the unit....same problem....
garmin streetpilot c510 delux model
Posted on May 07, 2008
Satellite Scan function, once completed comes up with Tuner overload Have tried reset factory settings, but no joy. Any help/ideas appreciated??
satellites use a 5v feed fed into the LNB through the co ax line to toggle between vertical and horizontal polarisation, check for any shorts on the co ax and especially its connections, if you have a multimeter disconnect both ends of the co ax and meter the cable for shorts
Dec 13, 2015 | Televison & Video
Tip
Satellite signal taking ages to come up
If your tomtom is taking ages to find a satellite signal, it may just need the GPSquickfix updated.
You can get this updated using the Tomtom Home software thatcame with your device or you can download if from the Tomtom website.
The reason this happens is that the satellites are constantly moving on different paths etc and the GPSquickfix files is updated weekly with that weeks satellite paths.
on Aug 18, 2009 | Tomtom GO 720 GPS Receiver
Screen stuck empowering
Dear frnd,
There are many reasons to have video stucks problem.
1) Low Ram ( need to increase Ram Memory)
2) Outdated Player ( Need to update the palyer with latest version)
3) Player not support that video format( Need to download good player like KMP /VLC etc..)
try it..
Jan 15, 2014 | Toshiba Satellite A40-S161 Notebook
Update failure; system status code. 3151-0000-D080-0200-8007-045D. What I've done: Cleared HD cache... no joy. Removed wireless and switched to cat5... no joy. Connected directly to Modem...
I can't really find anyone who has been able to fix this issue. Have you hooked it directly to the modem via the cat5 cable? I wasn't sure if you meant you hooked it to the modem or router.
Mar 08, 2011 | Computers & Internet
Cant acquire satellite
first thing you need to do, is make sure the battery is fully charged. a low battery will cause slow down or prevent the satellites from linking up to your nuvi.
whether that cures the problem or not, go HERE and download the Garmin Web updater and install it on your computer and once the program is running, hook up you nuvi via the usb cable to your computer. the updater will find any available updates for your nuvi automaticly.
no sense searching the garmin site for something that may or may not be there when the updater does it for you.
bill
Dec 20, 2009 | Garmin nuvi 200W GPS Receiver
My Maestro 3225 is stuck on the system settings
if your lucky, all it will need is a reset. start the unit and using a paper clip, insert it in the small hole on the side. if that fails, try the update using the Magellan link below...follow the update directions carefully. you must register your unit on the magellan site to download the update.
if neither solution works, id say the digitizer is bad (the touch screen) but the update normally cures this problem!
let me know if you need further help!
Aug 29, 2009 | Magellan Maestro 3140 GPS Devices
Takes a very long time for my Garmin to locate a satellite.
The real reason it takes so long to connect is:=
The battery has to be fully charged (by AC or USB)
Using just the car charger does not do it. It is a manintenance charger.
Hence the intermittent experience you are having Freshly charged works well, not charged poor connection
Check the charge level before you use it .
Please rate our help to keep the free service online++++Thanks for using FIXYA
Aug 24, 2009 | Garmin nuvi 250W GPS Receiver
Loose mirror
Click the link below and you will find the address. Thanks.
Jul 12, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Garmin StreetPilot  c510 Deluxe GPS Receiver Logo
202 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
