Question about Philips DVP642 DVD Player
The power on/standby button is flahing with red light.
The disk is inside. tray is not opening up. the power on/standby button is flahing with redlight. after few minutes the red light stabilizes but the display screen is not on. overall dvd player is not working
  • kiranksohail May 27, 2010
    Naiven thanks for reply. I have opened the disk. I have broke the cd out of it. Still the same situation. How to check the tray???
    Problem Solver:
  • 17 Answers
Well as your problem need some technical assistance well here is the resolution.
well if you know how to open the DVD Player and if you have all the equipments to open it than an than only do it by your own otherwise go to the service center of Philips and ask them to fix it for you.They will surely charge for this if your warranty has period expired.
Well if you gonna do it by your own than follow the instructions and do it carefully.
  • Unplug the player from any electric connection.
  • Secondly Open up the top hood of the player with the use of proper screw driver.
  • Than Look for the tray weather it has stuck with some other part of the player or not.
  • If not than look for the CD weather it has stuck some where ?
  • When you find the real problem try to fix it if it is ok to do it by self otherwise don't.
  • Than remove the CD out of it.
  • And Simply retry to check weather everything is ok or not.
  • Than close the hood of the player and you are done with it.
Well if you still not able to do it or if you had any other quarries in your mind please do reply me.
Naiven
Posted on May 27, 2010
  • Nilesh  Patel
    Nilesh Patel May 27, 2010
    Well it seems that the spring or a slide belt had some problem, I guess they might be loose. How long you been using this player? Had you ever gave it for service if not than you did a big mistake, well now if i come to the point your player need some servicing. And specially your tray need to be checked.If you try it by your self can damage the player so I might not ask you to do it by yourself.
    Naiven.
We have a red light flashing on the front of the tv.It shut off and we don't know how to turn it back on.
A red flahing light is sometimes a Standby Mode. Does the power button on the remote turn it on.Sometimes the remote has multi funtions and you need to select TV for it to work.Try using the Power Button on the TV.Good Luck.
Jul 29, 2011 | Toshiba 44NHM84 TV
How do you open the tray on the ps3. the power is on and im on the main ps3 menu but when i push button to open it just beeps
There is no tray on the playstation 3. It's slot-loaded drive; meaning it pulls the disks in and spits them out without opening a tray like you see on a desktop PC or a Xbox. If it's just beeping then that usually means there's no disk in there. The best way to check is if you see a blue light beside your red/green power light, then there's a disk in there. If it's just your red/green power light, there's no disk inside.
Feb 28, 2011 | Video Game Consoles & Games
Unit on standby mode only, the dvd rack didnt open when open button was pressed.
Turn off and unplug at mains Plug back in and turn on press standby button so power light come son. If pressing open button on player (rather than remote) doesn't work it may be a disk that is not sitting properly in the tray. You could try sliding a very thin blade (preferably something with an insulated handle!) gently in the top of the tray to press the disk downwards whilst gently prising under front edge of the tray with a small screwdriver. If you can manage to press the open button at the same time as doing both these things it may help.
If that fails to solve the problem it may be a broken drive belt or worn cogs in the tray operating mechanism. DVD players are so cheap these days that repair is seldom worth the expense.
Feb 23, 2011 | Philips DVP642 DVD Player
Sony KV-34xbr800 standby light flahes all the
Flashing standby light is an error code that is specific, there would be pause of 3 seconds in flashing, so count pause to pause and let me know that how many times red standby light is blinking to diagnose problem.
Thanks.
Jan 11, 2010 | Sony Televison & Video
Doesn't power up. Red standby light flashes.
How many times does it flash?
Odds are the A board components. Let me know how many times the stand-by light flashes, and I'll tell you want the fault might be.
Oct 25, 2009 | Sony KV-27S40 27" TV
Red standby light light blinking
there is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
Jan 11, 2009 | Sony KDF-E55A20 55 in. LCD Television
Won't Turn On
Try reseting the system. Instructions below.
DVD reset procedure for TH-A10
1. Make sure there is no Disc in the tray.
2. Disconnect the power cord.
3. While Pressing "Stop" and "Open/Close" buttons together reconnect the power cord
4. Front display will show "TEST0".
5. Then the display will change to : "TEST1 JC2".
6. Press "Enter" button on the remote, display will show "EEPROM"
7. Press "Power" to shut unit off.
8. Reset is finished
Jun 01, 2008 | JVC TH-A10 System
My MD16XDVD9 doesnt work. Its power is on with the small greeen light flickering and the bigger green light steadily on. but the the DVD tray doesnot open automatically. Even if it is force-opened and a...
have you got it set on an IDE cable on it's own and if so have the jumper at the back set to master the other thing to do is power of pc and remove ide cable from all devices and leave power cable to burner then torn on pc if you have removed power and ide cable from hard drive then when pc boots in press button on cd,dvd drive to open tray then place cd lense disk or any cd in drive tray press close button and let device kick in if it picks up disk then try with a dvd disk with power on pc if all goes well try with a ifferent Ide cable to motherboard and reconnect harddrive and power up if all goes well the pc should recagonise it if not then get it replaced
Aug 06, 2007 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
Won't boot up, can't eject disk tray
buy an xbox i mod them and have absolutely no problems
Jun 01, 2007 | Sony PlayStation 2 (PS2) Console
My dvd/cd try does not open when i press the eject button say "locked"
That means your trays are on Child Lock (this is a safety feature to prevent any accidental opening or closing of disc trays by small children when listening to your favorite tracks.)
To solve this, simply switch off your radio to Standby and hold the power button...whilst holding the power button, press open on the tray that is locked....the system will display UNLOCKED on the display of your hi-fi.
That should be it. To lock the tray....repeat the same process on the particular tray u want locked.
May 21, 2007 | JVC DX-T9 System
Philips DVP642 DVD Player Logo
639 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
