Question about Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor blinking after power outage
After the power came back on after an outage, my Samsung flat screen monitor is blinking on and off. I tried unplugging it from the current and computer and this did not help.
  • 11,361 Answers
Check the power supply section first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 27, 2010
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
Hello there,\r\nMy samsung 940be flat screen is
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Jun 09, 2010 | Samsung SyncMaster 940BE 19" LCD Monitor
Samsung 913N Monitor went out after a power outage.
try a known good monitor on the PC, is the light blinking green or orange?
www.aa1consuling.com
Jul 24, 2009 | Samsung 226BW Monitor
Screen is black
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try. If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable The board can run anywhere from $50 on up. Depending on how old your monitor is and how much you've invested into it, you may find it better to just replace it with a gently used one from ebay.
Jun 05, 2009 | Samsung SyncMaster 174V 17" Flat Panel LCD...
Samsung
Please try to connect your monitor to another PC, if still the problem exist, then probably an internal electronic part/s is cold soldered / defective, which I suggest to bring the unit to an authorized service center to fix the problem. regards
Jun 02, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Dell monitor
Monitor Help CH000315, Black borders on side of screen. CH000316, Dead or black pixels. CH000403, Macintosh and/or PC monitor compatibility.
Black borders on side of screen. Additional information about what causes black borders on computer displays.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Blinking monitor screen
this might be overly technical, but it sounds like the video card is on the blink (no pun intended). I'd power down the machine, open it up, pull the video card, re-seat it, and power the computer back on.
If it continues to do this, that card is probably toast.
Dec 06, 2007 | Computers & Internet
Problems After Power Outage
Sounds like the power outage damaged the video interface could be damaged. You might have had a spike that effected the red input of the monitor. You can try to order a video interface, or like I suggest to others, look for the same monitor but broken on ebay and swap out the interface board. Chances are this will fix your problem. Good luck
Oct 02, 2007 | Kogi L9CH 19" Flat Panel LCD Monitor
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
380 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
