Question about Avaya Eurostyle 18D Corded Phone
PHONE WILL RING BUT WILL NOT LET ME ANSWER OR MAKE A PHONE CALL
The clicker switch might be bad, you can get it repaired.
Posted on May 31, 2010
How to extend the incoming rings please
Go to Settings and choose options of Ring before Answering Machine.
Aug 17, 2014 | Uniden DECT 6.0 Cordless Phone ID
I NEED TO ANSWER THE NEC DTERN 8 WITHOUT HAVING TO HIT THE LINE BUTTON THAT IS RINGING
If your phone is set to ring then the Answer key should also flash during incoming call, you can use that. If its not set to ring there is a program to set Answer key to flash without the ring, but it's in system programming, likely a vendor thing.
Jun 11, 2014 | NEC Dterm DTP 16D-1 Corded Phone
How to set fax machine so it can accept after 2 rings?
Distinctive Ring basicsDistinctive Ring service is an optional service available from many telephone companies. The Distinctive Ring service permits you to assign more than one telephone number to the same telephone line. Distinctive Ring allows you to use a single phone line for both voice and fax calls. You can assign a unique phone number and ring pattern for incoming fax calls. When a fax comes in, each telephone number makes a distinctive ringing sound, such as a single ring, double ring, or triple ring.
NOTE: The Distinctive Ring Service is the name HP and others use to describe this feature. Distinctive Ring is also known as:
  • Call Sign
  • Custom Ring
  • Ident-a-Call
  • Ident-a-Ring
  • Ident-a-Ring
  • Multi Ring
  • Personalized Ringing
  • Ringmaster
  • Smart Ring
  • Teen-Ring
The Distinctive Ring Service allows the HP product to work similarly to a dedicated fax line. If you connect an HP fax product and a telephone to one telephone line, you can assign one telephone number for fax calls and another for voice calls.
NOTE: You cannot send or receive faxes when the phone line is in use. Even if the HP fax product has a separate telephone number, it is still sharing the same phone line. Set the Distinctive Ring Service Using the menus on the product control panel, follow these steps to set a distinctive ring pattern. Step one: Turn on Auto Answer Turn on Auto Answer by pressing the Auto Answer button on the control panel. The button light indicates when Auto Answer is on.If the button light is already on, you do not need to press the button. Step two: Set the distinctive ring patternFollow these steps to change the answer ring pattern.
  1. Press the Setup button (c01461502.gif ) on the product control panel.
  2. Press the Right Arrow button (c01185072.jpg ) to select Advanced Fax Setup , and then press the OK button.
  3. Press the Right Arrow button (c01185072.jpg ) to select Distinctive Ring , and then press the OK button.
  4. Press the Right Arrow button (c01185072.jpg ) to select one of the following options:
    • All Rings
    • Single Rings
    • Double Rings
    • Triple Rings
    • Double & Triple Rings
  5. Press the OK button to select the option.
  6. Press the Back button (c01490920.gif ) to return to the main menu.
Now if you have anymore problems copy the link from below and paste it in your address bar and it will help you further with a document. Follow all the settings in the document and your fax should be setup,keep in MIND THAT THE RINGS TO ANSWER SHOULD BE 2,SO YOU CAN RECEIVE FAXES AFTER TWO RINGS
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01647469&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3795406
Feb 01, 2010 | HP Officejet 6500 Wireless All-in-One...
I want the fax to work with an identa ring. How do I program this? As it is now I have to turn on the fax to receive. Does this HP work with identa ring?
The following set up assumes you have one conventional phone line, but two different phone numbers. One being your regular phone number and the other a distinctive ring for your fax machine
If that is what you have then this is how you set up the phone. Its important to know what type of distinctive ring your phone company will send to your phone. If it doesn't work you can talk to them about getting a different one than their default distinctive ring.
2 Set the HP all-in-one to answer incoming calls automatically.
Press the Auto Answer button until the light is on.
3 Change the Answer Ring Pattern setting to the pattern that has been assigned to your fax number by the telephone company, for example, double rings or triple rings.
For information on changing this setting, see Change the answer ring pattern
(distinctive ringing).
Note Your HP all-in-one is factory-set to answer all ring patterns. If you do not set the correct ring pattern assigned to your fax number by the telephone company, your HP all-in-one might answer both voice calls and fax calls or it might not answer at all.
4 (Optional) Change the Rings to Answer setting to one ring or two rings.
For information on changing this setting, see Set the number of rings before answering.
5 Run a fax test. For information, see Test your fax setup.
Your HP all-in-one will automatically answer incoming calls that have the ring pattern you selected (Answer Ring Pattern setting) after the number of rings you selected (Rings to Answer setting). Then it will begin emitting fax reception tones to the sending
fax machine and receive the fax.
If it is easier or you want to know other options which may be more applicable to your phone setup. You can find that information here.
http://h10032.www1.hp.com/ctg/Manual/c00235090.pdf
Jul 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Remote answer machine turn on
Most Uniden answering machines will turn on remotely after the 12th ring. Call your home phone and just let it ring, ring, ring.
Apr 09, 2009 | Uniden 5.8GHz Cordless Phone
Phone ringer
The box underneath the setup in the manual (mine's on page 13) describes what TOLL does. It can answer on the 3rd ring, the 5th ring, or if you have messages it will answer on the 3rd ring and not until the 5th ring if you don't.
You can hang up after 3 rings if the machine doesn't answer, because you have no messages. Other manufacturers call it TOLL SAVER.
Carl
Jan 12, 2009 | GE 27959GE6 Cordless Phone
Faxing
If you have a distinctive ring pattern activated in the same phone line you will be able to receive fax, Voicemal, and phone calls without disconnecting the fax cable on the All-In-One.
When you have activated a distictive ring pattern.
Then you need to set the rings to answer in your fax machine to The ring pattern which was provied by your telephone company.
In the Menu/Setup>Goto> Basic fax setup> Then> Set it to either double ring or triple ring which ever is aplicable. Then Raise the rings to answer in advance fax setup to 5 or 6 Rings
The rings to answer in you phone or answering machine should be set to 4 (Always lower then that of the fax)
Good Luck
Aug 25, 2008 | HP PSC 2210 All-In-One InkJet Printer
Caller Id not working, phone disconnects after 2nd ring
This problem turned out to be a phone company problem.
Jun 20, 2008 | Avaya Lands Phones
How to prevent HP 3380 All in One Printer answering voice calls
If you have call waiting on your phone service you can call your phone company and get "personal ring" service. It will cost a couple of dollars extra a month, but they will assign you another phone number and it will have a different ring style to it. Then you can set the ring type to the type of ring they assign you.
May 31, 2008 | HP LaserJet 3380 All-In-One Printer
Answer a distinctive ring?
No, distinctive ring is not available on this machine.
May 24, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Avaya Eurostyle 18D Corded Phone Logo
23 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Cabanaboyz
Cabanaboyz
Level 1 Expert
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
