Question about Dishwashers
My dishwasher is not getting my dishes clean. I have had it for about 7 years and know there must be filters or something that I should be cleaning out.
Usually food particles blocking outer nozzles of spray arms. Remove them and rinse out. All particles must be removed. Very tredious job!
Posted on Apr 07, 2008
My dishwasher is about 4-1/2 years old. Lately I am getting a film on my dishes especially glasses. I use Finish rinse agent. Is there something I can do?
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Jun 20, 2011 | GE Dishwashers
Leaving a white residue on dishes after its full cycle. Have tried different soaps,rinsing agents, and ran it through a cycle with a cup vinegar in it.Is there something I can do to repair this problem ?...
As you have already done the vinegar cycle and all now it must an technical reason.
Mar 17, 2011 | Frigidaire Dishwashers
I have a 5 year bosch shu43c05uc & my dishes aren't clean any more? i've cleaned the bottom lint container & it still isn''t clean? does my dishwasher need repair?
You should be able to get several more years out of it with a good maintenance call or a Do It Yourself routine on checking your water inlet valve. spray arms, internal filters.
Mar 08, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
My roper dishwasher is not getting my dishes clean anymore. Is there something I can do? By the way, I think it is about 20 yrs old.
Mar 04, 2011 | Dishwashers
I have a Whirlpool gold dishwasher. It may be 6-7 years old. It is cleaning properly. Any suggestions?
I think you want to mean it is not cleaning properly..
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes
Feb 02, 2011 | Whirlpool Dishwashers
Cloudy glasses, less than 2 years old, using the same soap , we don't know what happened?
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Jan 03, 2011 | Jenn-Air JDB1105AWS Stainless Steel...
My 3 year old
Try a different detergent such as the electrosol tablets. Also might add vinegar to an empty cycle to clean dishwasher, or with dishes.
Oct 15, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher is leaving food particles everywhere
Clean the filter screen at the bottom of the washer basin.
Apr 14, 2017 | Dishwashers
Dishwasher leaves film, smelly water
You need to use something with citric acid too try and clean out the calcium deposits inside dishwasher, you can get cleaner at the store or run a can of frozen orange juice thru it or a small bottle of apple cider vinegar. Do this with no dishes inside.
Jul 14, 2008 | Whirlpool 24 in. DU900PCD Built-in...
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
142 people viewed this question
Top Dishwashers Experts
