Question about HP LaserJet 3600n Printer
50.9 fuser error shows on my information window. I did what it said and the error code continues to show, saying fuser is hot, however I left the printer off all night.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • HP Expert
  • 217 Answers
Did you repace the fuser?? When no, replace it. When yes, you probibly have a defective powersupply.
Posted on May 28, 2010
Error p1500
The printers first error code show all lights flashing:
Flashing Ready'Data
Flashing Toner Low
Flashing Load'Remove Paper
Flashing Paper Jam
Flashing Error
Flashing Press Continue
By pressing continue twice to get to second error codes the lights show:
Flashing Ready'Data
Off Toner Low
Flashing Paper Jam
Flashing Error
Pressing continue twice more shows:
Off Ready'Data
Flashing Toner Low
Off Load'Remove Paper
Off Paper Jam
Off Error
Off Press Continue
Pressing continue twice more brings back to all lights flashing
The computers ( I have tired more than one with diff USB and A parallel cables) do not see the printer as being attached. My toner is half full. I checked the internal power board in base of printer and the fuse is good. The error should not have anything to do with being connected to a computer or not because when it was working and not connect to a computer it would not blink all the indicator lights (If I remember correctly, just the Press Continue light would be lite).
Information I have found so far:
  1. http://support.dell.com/support/edocs/systems/p1500/en/index.htm#online_documentation
o Under PDF Documents Owner's Manual(English) (.pdf) (1.33 MB) shows very little about the indicator lights.
o Under HTML Documents User's Guide shows more information about the indicator lights but mentions nothing about the secondary error codes.
  1. The Lexmark E321/E323/E220 are very close cousins to the P1500 and on Lexmark's website the manuals have more info on secondary codes but nothing that matches my error.
Information I am guessing could be the problem:
  1. The fuser has gone out (need to know how to check) Why else would they sell the fuser if it didn't go out regularly Part Number: 56P1053
  2. Clutch Assembly I'm not sure of the accuracy of the info on this page.
Mar 12, 2014 | Canon Office Equipment & Supplies
When I turn the Printer on, it will initialize and then display an error message "50.7 fuser error" and will not get to 'ready mode' for printing
1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board. http://printertechs.com/tech/error-codes/error-codes-50-59.php
Fuser Ref: http://computer.howstuffworks.com/laser-printer3.htm
May 05, 2011 | Computers & Internet
Shows 50 service in printer window
ok its either going to be your psu unit or your fuser.... if its showing the 50 service and doesn't print anything I would definitely replace the fuser... here is a link with some more information on the matter... http://www.fixyourownprinter.com/kits/hp/K05
Jan 06, 2010 | HP LaserJet 4 plus Printer
Mita DC1435 Copier shows a C63 error message
you have a fuser code. you will need to test the fuser lamp, thermo fuse and thermistor with a vom with machine umplugged. open the front door and the clamshell. remove the orange fuser cover. t. remove the back cover. remove the bottom black cover. unplug the lamp, and thermistor. go to the fron of the machine. just to the right of the fuser on the frame is a black screw. remove it. now tip up the fuser 97 degrees and slide it to the left it will come out. now test the lamp with ohms, continuity, do the samae for the fuse. you will need ti remove the thermistor with one screw. put your finger onit. put he meter at 200 ohms and it should change vlaue. good luck
Dec 26, 2009 | Office Equipment & Supplies
Hp 4m shows service error 50
The service 50 error indicates a bad fuser assembly. You can get one on Ebay for less than $50. To replace the fuser just open the door on the back of the printer, inside you will see the fuser, unscrew the 2 screws and pull the old one out. Insert the new fuser and screw it down, power on the printer and you should be good to go.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 13, 2009 | HP : HP4 Laserjet Printer
Error 50 code, have replaced fuser and checked connections
I am not sure this will stay fixed but after i cleaned the pcb's and checked the connections and let the unit sit overnight the printer works just fine. If this does not stay fixed I will contact you again.
Thank you,
Apr 14, 2009 | Office Equipment & Supplies
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Mar 23, 2009 | HP Color LaserJet 3500 Printer
50 service flashing on display screen
If the display panel reads 50 FUSER ERROR, CYCLE POWER, turn the printer off for 15 minutes. This allows the capacitor that is responsible for signaling this error to discharge. If you don't wait 15 minutes you will continue to get this error even if you have replaced the fuser. If it continues to show the error, then you need to replace the fuser. It is easy to replace.
The fuser maintenance kit is about $119. on the web.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 17, 2008 | HP LaserJet 4 plus Printer
Fuser Error 50.1 Fuser is hot. What is a fuser?
error 50 means your fuser assembly has gone bad or its not getting power to be functional. you need to replace the fuser unit.
Aug 17, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 3600n Printer Logo
1,517 people viewed this question
Seeker5211
Seeker5211
