Question about Intermatic Inc. ST01C Digital In-Wall Timer
Timer will not turn off
I have an Intermatic in-wall light timer that has been working perfectly for years but now the lights will not turn off either automatically or manually.
As last resort troubleshooting Intermatic battery-operated timers, replace battery and/or reset timer.
Manual has troubleshooting section.
Open following link for manuals and wiring for Intermatic timers.
http://waterheatertimer.org/Flipdown.html
http://waterheatertimer.org/ST01C-program.html
Posted on Apr 26, 2011
Wall timer for carport lights; motion sensor lights
Manual for the discontinued SS5 appears following link:
http://waterheatertimer.org/Intermatic-timers-and-manuals-old.html#SS8
Most the timers at local box store are cheap replica brands. I recommend higher quality, such as Honeywell single-pole heavy duty programmable (or dawn-dusk) timer shown following link: requires Neutral wire
http://waterheatertimer.org/Programmable.html#honeywell
If you need the 3-way or do not have Neutral wire, then battery-operated Intermatic is best choice. Choose either 1 or 5 year warranty:
http://waterheatertimer.org/Programmable.html#st01
Jun 03, 2017 | Intermatic Hardware & Accessories
I have a ML44T automatic timer for my outdoor lights which has been working perfectly until now. When the time turns until it gets to the point where it has to trip the switch to turn the lights on it...
The clock motor has gone bad.
There are no replacement clock motors.
To work around, buy cheap plug-in timer, set power pack to override and plug power pack into cheap timer.
Power packs have 5 year limited warranty.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Mar 08, 2011 | Intermatic ML44T TRANSFRMR WITH TIMER 44...
My EJ351 programmable timer has work perfectly since 2004. A few days ago the red light just started to continuously flash. I turn it off to rest and regrogram but no luck, the indicator light still...
What is amazing is that you know the year of purchase, AND remember how to set the timer.
1) Try turning off circuit breaker and see if timer resets.
2) Buy cheap circuit analyzer and plug into outlet on same breaker and see if line is clean.
3) EJ351 has limited 1 year warranty.
I test timers: usually when in-wall timer goes bad, it needs to be replaced.
There are no repair parts.
Google search: Intermatic EJ351 timer
Amazon sells EJ351
http://www.amazon.com/dp/B000Q9YUGU/ref=asc_df_B000Q9YUGU1408425?smid=ATVPDKIKX0DER&tag=nextagus0039178-20&linkCode=asn&creative=395093&creativeASIN=B000Q9YUGU
Aplus supply sells Ej351 timer.
http://www.aplussupply.com/intermatic/timer.htm
I buy timers from both these suppliers.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 28, 2011 | Intermatic Programmable 24 Wall Switch...
How do I set it and can I use it indoors?
I see nothing in the manual that says 'outdoor use only' EXCEPT timer runs on photoelectric eye.
Timer turns ON automatically at dusk, so if timer is inside, and indoor lights are ON, then timer stays OFF.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb51rc%20-%20english.ashx
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb51rc.aspx
To use timer outdoors.
Plug timer into wall.
Timer turns ON automaically at Dusk.
Rotate dial to set how long timer will stay ON.
Set timer to turn OFF 2 4 6 8 Hours after dusk
Set timer to turn off at dawn
Set timer to ON so lights are ON full time
Set timer to OFF so lights are off full time.
Dec 09, 2010 | Intermatic Outdoor Timer/Photo Control...
Light turns off in the morning, but does not automatically turn on in the evening
Battery-operated Intermatic timers can develop problems.
1) Battery may need to be replaced.
http://waterheatertimer.org/ST01C-program.html#EJ500
2) Troubleshoot guide on manual says to 'reset and reprogram' timer if problems occur.
http://waterheatertimer.org/Intermatic-ej500c-manual.pdf
3) Timer comes with 1 year warranty and can just go bad.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers.aspx
Nov 21, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
There is also a way of setting it by simply turning the light on and off at the desired time. Can yu help?
Manual: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
The manual says:
"To automatically program, letting the switch
timer "record" your ON/OFF activities over a 24-hour period,
storing them as programmed settings:
Move the control lever to the OFF-CLEAR position for about
20 seconds. The red indicator light will go off and any previous
time settings will be cleared from memory.
Move the control lever to the ON position. The Red indicator
light will start flashing.
Press the dial as an ON/OFF switch to turn lights ON and OFF
at the ON and OFF times you desire for the first 24 hours.
At the end of the 24-hour period, the switch timer will be programmed
and the Red indicator light will stay ON, indicating
that the switch timer is in AUTOMATIC mode."
Sep 17, 2010 | Intermatic Programmable 24 Wall Switch...
Instructions on how to program the Intermatic EJ351C
take a look at this :
-or -
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
hope this helps
Jun 03, 2009 | Intermatic Programmable 24 Wall Switch...
Intermatic Inc. ST01C Digital In-Wall Timer Logo
228 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
