Question about Ingersoll Rand 2135QTIMAX 50 Inch Quiet TiMax Impact Wrench
Run away air impact gun
When i hook my air gun up to the air line, it takes off without squeezing the trigger. Where can i get rebuild kits for this model from? How do you remove the trigger to replace the o-ring?
4 Suggested Answers
  • 50 Answers
SOURCE: my air impact runs without squeezing the trigger.
if u take the tail outa ur gun u will see that da gause filter inside has broke up.it gone inside and holding da valve open pick it out wit a seal pick r somethin
Posted on Aug 03, 2010
  • 30 Answers
SOURCE: Trigger valve sticks full open
before taking you gun apart, put a few drops of automatic transmission fluid in the it through the air chuck. Keep it oiled regularly
Posted on Aug 28, 2010
  • 37 Answers
SOURCE: I have two different model impacts that are both
Hi make sure you are using the proper oil requiered for these tools. I hope this works
Posted on Jan 27, 2011
My Dewalt framing gun blows compressed air thru the nailer nose? Thx Kurt
Rebuild gun with gasket repair kit.
How it works: Compressed air enters through air hose and fills gun cylinder.
When trigger is pulled, air inside cylinder rushes out and pushes firing pin that shoots nail.
Inside the gun there are gaskets that seal the nose, the trigger and the cylinder head.
When any of those three gaskets fail, then air starts leaking.
Putting a few drops of nail gun oil into gun before connecting hose is supposed to protect gaskets.
But everything wears out, and sometimes folks use 3-in-1 oil instead of gun oil.
3-in-1 is detergent type oil and will cause gaskets to fail.
Another thing is guns that are not used frequently and gaskets get dry.
Putting in a few drops of oil and then immediately shooting gun will cause gasket to fail, because gaskets are still dry.
Best to put in plenty of gun oil, and let oil go down into gun for a few hours before connecting hose and shooting. Even so, nail guns are designed to be used every few days with continual oiling.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 31, 2011 | Tools & Hardware - Others
On the trigger of my Bostich Spiral load nail gun AND my Bostick trim nail gun air is leaking profusely from the trigger. Nail guns were not in use for about a year. When I first used them this weekend,...
A nail gun works on compressed air.
When you hook the air hose to the gun it fills a cylinder with air pressure.
When you pull the trigger. the cylinder pressure is released onto a firing pin that shoots the nail.
The air pressure line is also connected to the trigger and therefore the trigger has to be sealed.
When ever using a nail gun, you add a bit of gun oil in the back of the gun (not 3-in-1motor oil, it has to be non-detergent gun oil)
If you haven't used the gun in a while, it is best to oil up the gun and let the oil run down into the gun.
If you use anything but gun oil, the seals will give out.
Your trigger seal has given out. It is probably an 'O' ring. You can access it by taking it apart. Look for the O ring.
Bostich makes re-build kits for the different guns that you can buy on-line.
Back when I was in construction, there were several nail gun shops that sold and serviced nail guns, and sold nails to the contractors. I don't know if that business model is still active or if you have to send the guns to Bostich service center.
Oct 18, 2010 | Garden
Blowing air through trigger area. Need rebuild kit? Longer version...started blowing air out of small hole in left side of casing. Leaked oil out of there as well but still worked fine. This has been...
If the trigger still works to fire the single shot, then the o-ring kit should be sufficient. If the trigger area continues to leak air, then the trigger should be replaced as well. Keep the gun well lubricated as well.
Dan
Oct 02, 2010 | Duo Fast Duofast Cn350 Cn350b Sh Nailer O...
My air impact runs without squeezing the trigger.
May 27, 2010 | Ingersoll Rand Air Impact Wrench 1/2in....
Hi, The socket adapter spins before i engage trigger
The seal is bad inside leaking air pressure to the gun without squeezing the triger. Get a reseal kit from Sears
Jan 22, 2010 | Craftsman Tools 1/2" Air Impact Wrench...
My 772h is running low power i pulled it apart and everything looks great a few light scatches in rear cyl .can i just polish it 320 grit or ??
you need a new rebuild kit with O rings and gaskets,take gun completely apart and make sure you get new air vanes too,the scratches dont make that much difference,but old seals will rob power from gun
Jan 11, 2010 | Chicago Pneumatic CP772H - 6 3/4" Heavy...
My Aircat 1404BG impact gun stopped working.
most of the problems accure from being dry try 2 or 3 drops through the air intake fitting every so often depening how much you use your air tools, it may be time for a new one but i would try the air tool oil first before bying a new one, i hope i helped.
Jan 02, 2010 | Impact Aircat AC1603 3/4" 1330 Ft - Lbs...
My CP 734 has no power under load. Is there a rebuild kit to fix this problem and where can I get it? If a kit is available, is that a difficult rebuild? Tim
I used to repair these impacts for a living. Simplest first thing to do is back off the three 1/8" set screws in the back a couple turns. Pour a little varsol into the air inlet and plug it in. run the gun until your hand is black, (wear a glove). Once the varsol stops disconnect the air, add a few drops of air tool oil and tighten the screws slowly and evenly. You will hear the impact rpm increase. If your gun doesn't speed up to it's original scream you will have to remove the four 5/32" set screws and see what's worn. To open it hold the impact by the nose 3" off the table and position a center punch in the hole of the anvil shank with the same hand and hit it with a hammer hard enough to overtake the spring. The guts should drop on to the table in tact. The guts are in twp parts, the hammering mechanism, and the air motor. The three 1/8" screws hold the motor together. You will soon see the problem. Take the back off the air motor and it will show your if the veins are worn. Cjeck the end plates for wear. You can turn the end plates down on a lathe if available. As a rule of thumb, if the anvil shank is dry buy a repair kit, if it's wet, buy a tune-up kit. If the ring on the anvil shank doesn't turn, buy a repair kit and change your sockets. When rebuilding these front seal often leaks. These impacts are supposed to use 30 weight oil, but a mix of Ingersol Rand grease and 30 weight oil, ( just till it's slightly runny) will stay much longer. Assembling the anvil assembly can be tricky until you figure out how to hold the shank and two pins with the same hand. Good luck.
Dec 04, 2009 | Chicago Pneumatic 1/2" Air Impact Wrench
I have a ir 5/8 drive impact #2905vw599 and need parts
the best advice i can give, after being involved with rattle guns for 30 years is for you to take it to an air tool service centre , ithink the main parts you will need willbe o rings and they will have access to the parts required ,even if they be after market, believe me ,that is the way to go .
Nov 11, 2009 | Air Tools & Compressors
Need rebuilding kit for air gun
you can buy repair kit on the snap-on web-site.
www.snap-on .com
Jan 03, 2009 | Air Tools & Compressors
Ingersoll Rand 2135QTIMAX 50 Inch Quiet TiMax Impact Wrench Logo
Top Ingersoll Rand Tools & Hardware - Others Experts
elunsford
Phil Walker
Phil Walker
Are you an Ingersoll Rand Tool and Hardware - Other Expert? Answer questions, earn points and help others
