Remote quit working so I turned tv off using button on side when I tried to turn tv on again nothing, did not respond so i put new batterys in remote but still nothing pushed side button still nothing.
  • 94 Answers
Defective IR sensor or main board
Posted on May 28, 2010
My sansung remote quite working, replacement universal remote was programed to the tv but the tv will still not respond. What's next?
You likely don't need a new remote. Certainly not a Universal.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Try this:
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Please rate if Helpful.
Good Luck !!
Jun 18, 2011 | Samsung TV Remote Control
T.v. does not respond to remote control, but does work maually from side buttons
Turn tv on manually.Test the remote control all functions are dead or some functions work other don't?Tries take the remote control parts and clean the inner rubbers buttons between the rubbers insulater and the remote circuitries board and the battery connections + - connections with some rubbing alchahol.Then wait awhile like 20 mins and putting it back together again and putting in new battery in the remote,it might work again.If getting the same result than the remote CPU chip is probally dead,remote control devices are very depended on it CPU chip.Try website like Remotes.com to buy an original remote for the replacement.
Mar 24, 2011 | Vizio 42 in. LCD TV
Att uverse receiver hooked up to sharp aquos tv, remote quits
first try new batteries and be sure you have pressed the AT&T mode button at the top left of the remote - if you still have issues then on the sharp tv menu - turn off any energy saver mode, Optical Picture Control, taking the picture mode from dynamic or vivid to standard, and if that doesn't work - try changing the backlight settings if your tv has one.
Aug 23, 2009 | Denon AVR-1908
Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Jun 06, 2009 | Panasonic TH-42PX60U Television
Tv does not respond to remote commands
You need to isolate the problem.
1) Unplug the TV for a few seconds and then plug it back in.
2) Operate the TV with the buttons on the TV. (Channels etc) I presumed you have scanned in the channels.
If no problem found then do this for the remote.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Now try the remote to see if it works. If it fails you will need a new remote.
Mar 16, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Logitech 890 remote quit working
It just started working again. Maybe it took the day off.
Jan 11, 2009 | Logitech Harmony 890 Universal Remote
Remote control quit working
Batteries can be bad or installed improperly. If you know someone with a digital camera that has an lcd display, point the remote at the camera while someone is looking at the camera's image in real time. Infrared will appear as white light to the camera's CCD "eye". Cool trick.
Remember, IR is line of sight. Make sure nothing is blocking the path between the remote and the TV. Also IR remotes and fluorescent lighting doesn't mix.
Nov 24, 2008 | Radio Shack (15-2147) Remote Control
Dish network remote
i would suggest trying power scan again...
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
Jul 06, 2008 | DISH Network IR Remote Control
Remote control not responding
Perhaps you can try what I do when my KV24FV300 runs through channels and will not stop.  Hard to watch and remote will not work.  Nothing works but on and off from set.
Sony Says:  Take all batteries out of ALL remotes that you use in any way for that set, VCR, etc.  ALL batteries out.  Turn TV off at set.  Unplug TV.  Wait at least 15 minutes then replace all batteries in ALL remotes.  Plug TV back in and turn TV on from set.
Maybe, just maybe it will work.  If it does not work why not call Sony, they always say that cannot happen but they have a solution for it.
niteowl@dejazzd.com
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
Electro Med Services...
