Question about Pride New Mobility Legend 4 Wheel Scooter
Rear wheel sticks and sometimes when you go to go forward nothing l of a happens,then al of a sudden it jurks forward with no warning.l
  • 177 Answers
Hi. Sounds like you have worn out motor brushes. the brushes wear down to short and get stuck in the brush holders. Sometimes the caps that hold the carbon brushes in come loose, and the carbon brushes get stuck because the current arcs between the carbon brush and the brush guide. Get a serviceman to overhaul the motor, and it will work fine. Probably a good idea to replace the motor bearings at the same time. Good luck. Neil.
Posted on May 28, 2010
Brake warning light on dash and warning chime turn on, brakes seem fine, sometimes turns off, sometimes stays on.
the anti-lock brake pump could be sticking causing a code to turn the light on - i have a 1999 bonneville that does this sometimes in cold weather
Apr 17, 2015 | 1995 Buick LeSabre
Rear brakes locked up replaced brake shoes recently
Hi, I'm AL the owner of Big As Auto Repair in St Charles Mo
I look forward to helping you with your problem.
FIRST: If your rear brakes are drum brakes, then most likely the E-Brake is corroded and sticking. You'll need to lube it and free it up. SECOND: If your rear brakes are disc brakes. Two things could be happening. (1) If you did not clean the area where the pads slide back and forth then the pads could be sticking in place. (2) The caliper could be sticking or the hoses or lines could be restricted and cause the calipers not to release. Here's how you see which problem you have. Jack up the vehicle so the wheel is off the ground and try turning it by hand if it will not turn take a wrench and crack open the brake link going to the caliper and see if the wheel turns. If it still will not turn then you need a caliper. BUT, if it does turn then you need the hoses. If you need further assistance click here: Auto Repair
Mar 15, 2015 | 2001 Ford Taurus
Scooter won't move when forward/reverse engaged.
http://mobility123.com/help-fix-mobility-scooter-powerchair/
Engage the freewheel lever
- allows you to operate the mobility equipment with the standard controls.
Disengage the freewheel lever - This unlocks the unit and allows the wheels to spin freely. You can easy push the equipment without power. This is especially helpful if you run out of battery power and need assistance.
Apr 21, 2017 | Health & Beauty
Rear brakes sticking
need more info---did you have brakes worked on, did it happen all of a sudden???
May 23, 2011 | 1999 GMC Sierra
ABS warning light until bike is put in gear and going forward.
Yes, that is completely normal. The ABS does a self test and extinguishes the light when it sees wheel speed information from both front and rear wheels.
Nothing to worry about unless the light fails to go off.
Happy riding.
Sep 30, 2010 | 2002 BMW K 1200 LT
1980 pony rear tine tiller: when I put it into gear it just sits there and will suddenly lurch ahead uncontrollably.
That will happen when the tines are engaged while the wheels are in Neutral as the tines simply drive the whole machine forward without the drag of the wheels being in gear. If the wheel transmission is engaged and this is still happening, then you have need for repair.
farmerbear at FixYa.com
Sep 22, 2010 | Troy-Bilt Pony Garden Tiller
My '83 dodge ram van goes in reverse fine,but when i try to go forward, the R rear wheel spins, seems the L rear is jamming?? is this a diff or brake issue?
sometimes the emergency brake will stick even after it is released. Most drum brakes will still let it go backwards but not forward. I would pull the rear drums and check. If e/brake is stuck removing the left drum will be difficult. If so then you will have to manually adjust the brakes until drum loosens up. good luck
Jan 18, 2010 | 1983 Dodge Pickup
My 1998 yamaha FZX250 Zeal has a problem - rear sprocket..
the rear sprocket has rubber drive pads behind it inside the rear wheel,,,pop the wheel off and have a look at the rubber pads, you most likley need new ones
Oct 30, 2009 | 1998 Yamaha FZX 250 Zeal
When i switch on, the green light comes on but nothing else happens , the psp has not been damaged in any way , this just happened all of a sudden
It might be brickked happend to me al i did was take out the baterrey and let it sit for 3 days put i back in and started it without mem stick after i t booted up then turn it on again then it worked
Jul 19, 2009 | Sony PlayStation Portable White Console
Pride New Mobility Legend 4 Wheel Scooter Logo
191 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
