Question about Bosch 24 in. SHX99A15UC Stainless Steel Dishwasher
Error code 01 on bosch dishwasher. what does this mean?
  • Anonymous Mar 22, 2014
    bosch error code 01
    Sergeant:
  • 228 Answers
Error code 01 means interrupted heating phase or no heat on final rinse if machine is heating on beginning of wash this will be a blocked transfer hose or pressure chamber need to remove left hand side panel to access and base panel to access transfer hose it will be full of food deposits messing up water fill cycles these machines will only heat correctly when wash water is at correct level. the wash perfprmance will suffer till this is done.
Posted on May 27, 2010
5 Suggested Answers
SOURCE: What does the error code E01 for bosch dishwashers
my dishwasher e01cod show then turn off
Posted on Jan 26, 2011
maklean
  • 1665 Answers
SOURCE: flashing error code 2.1/01
http://www.repairclinic.com/0047_9.asp
Posted on Aug 13, 2008
  • 10 Answers
SOURCE: Bosch Dishwasher Model SHU5316UC-06 -- what does
2H is not exactly an "error code", but it does indicate a problem. It means that the machine exceded its wash time by more than 2 hours. This is usualy caused by a failure of the heater, most often caused by a failure of the controll. Remove the control from the door, remove the plastic housing from the control, and check for a bad solder joint on the heater relay.
If you find a bad solder joint, REPLACE the controll.
Or call a qualified service person.
NOTE: The SHU53A dish washer with serial numbers from FD8205 to FD8507 are included in a factory recall. If your dishwasher is one of these contact BSH @ 1-800-586-9226 24/7.
Posted on Mar 29, 2010
ZJLimited
  • 17970 Answers
SOURCE: Hi Our Bosch dishwasher (sms63e09uk) has
It means the machine is not getting enough water you need to replace the water inlet valve, that is very possible try cleaning it and see if that helps.If it does not then the problem is the water valve.Which is a very common problem.
This air flow error code refers to the dryer vent. This can refer to the dryer's lint screen, the thermistor behind the filter, or the vent itself could be clogged.
In order to determine which one is the problem we will need to gather some information.
1. Will water pour through lint filter's mess?
2. Outside where the unit vents on the side of the house can you feel air coming out?
3. Is the vent hose on the backside kinked or clogged?
4. Obstruction on vent housing outside (if screen is present on outside remove right away this is a fire hazard.)
Water should pour through the lint filter easily. Fabric sheets will put a layer of wax on the lint screen causing the dryer air circulation to be cut off. We should be able to feel warm, moist air at the vent outside. If air is not present you are in need of a dryer vent cleaning. A kinked or clogged vent hose can also cause the E01 error code. Ensure the vent hose is clear and placed in position with as few bends as necessary. When the vent is clear the E01 error should clear itself upon start up.
Hope helps.
Posted on Apr 02, 2011
What does 01 error mean?
Hello Ned, thank you for your post!
I understand that your Electrolux dishwasher is displaying an error code of "01". This error code means that a leak has been detected. Have you noticed any water coming from the bottom or near the dishwasher? This could also be a miscommunication within the control of the dishwasher and a reset may help clear that out. You can reset your dishwasher by disconnecting power from it for at least ten minutes. If that does not help to resolve your issue I would suggest having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful to some degree. -Matt
Jan 22, 2016 | Electrolux Dishwashers
Dish washer goes through cycle but when finished cold with Code E..09
Bosch Dishwasher Troubleshooting ' Dr. Dishwasher
www.drdishwasher.com/troubleshooting/manufacturer/bosch/
Your Bosch dishwasher can run a test cycle which will quickly go through each ... You can find a list of Bosch dishwasher error codes and their definitions here.
Jul 26, 2015 | Bosch Dishwashers
What does error code 01 mean on my bosch silence plus 42 dishwasher mean?
The 01 error code means that the incoming water isn't coming fast enough. This could be a problem with the water pressure in the building, the fill valve or the water flow meter. Sometimes, this can be caused by something blocking the float from moving freely inside the dishwasher tub.
First check that you have sufficient water pressure in the house and that the shut-off valve is fully open. (If you have low water pressure, find out what is causing the issue.) Make sure that the incoming water pipe/hose isn't crimped or leaking. Next, flip your circuit breaker to off (or unplug the unit) to reset the dishwasher. Next you need to check that the fill valve is opening and closing properly; check that the wiring is good as well. If that is fine, then the problem is the flow meter or the circuit board that reads the sensors from the fill valve and flow meter.
I hope this helps.
Jun 28, 2015 | Bosch Dishwashers
What is E25 on my Bosch super silence dishwasher?
I quote same wrong from other user:
Question: Model dishwasher is Bosch Exxcell SMS50E02
It stopped before the end of a cycle with the error code E:25 and the "check water" light came on
I mopped out all the residual water out of the bottom and then ran a rinse cycle, which after several trials I got to work and then it stopped at the end again with the same error code and water in the bottom as before.
Answer:
I assume by in the bottom you mean inside the dishwasher and not in the base.As long as there is no debris in the sump area and the hoses are clear it appears you have a bad drain pump.
Hope helps.
Apr 03, 2011 | Dishwashers
Display has error code h01 and dishwasher won't run model is SMS63M08AU
h:01 means 1 hour delay. Press the delay button repeatedly to get to h:00 then hit start.
Mar 06, 2011 | Bosch Dishwashers
My one month old Bosch dishwasher Model SHE6AF06UC has and error code E-01. It was there when I came home. Can't find anything on this.
think this means that your water pressure is not high enough for rinsing to be completed 100%. do you have low water pressure.
Jun 19, 2010 | Bosch 24 in. SHX99A15UC Stainless Steel...
Bosch 24 in. SHX99A15UC Stainless Steel Dishwasher Logo
2,863 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
