Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman mid-engine mower with an inconsistent starting problem
This is a 13.5 hp B&S engine that is less than 1 yr. old. It will start fine one day & next time will not start at all. It truns over fine but not firing. Checked plug for spark, but has none. I have checked safety switches & they seem to be okay. Also, checked the fuse. I can go out the next day & it will sometimes start.
I still suspect one of the 4 safety sensors.
Thanks in advance for any advice of this problem BB
    President:
  • 1,033 Answers
It's usually the seat switch that goes bad. take the switch out and tape the switch button down to see if it will start.
Posted on May 27, 2010
My 12 year Craftsman lawn tractor with 20.5 hp B/S engine and 42" blades will not start. The starter turns over fine but no start. I don't know if it is igntion or fuel problem. I replace the...
Test for spark. Make sure the air filter is clean. Then make sure fuel is getting from the gas tank to the carb. Old rubber fuel line deteriorate and stop up small ports and parts in the carb. An inline fuel filter is a good idea on these larger engines. Sometimes, a larger B & S engine needs the OH valves adjusted to start easily and run properly. If after attempting to start, does the new plug get wet or even smell like gas? You should always use gas LESS than 30 day old. Gas goes stale like bread and milk. You can remove the fuel line from the fuel tank at the carb to drain old gas. You can also remove the carburetor bowl to check for water and sediment (which need to be cleaned out). Check these things and post back.
Sep 05, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have Poulan BVM200VS 25cc gas blower. It has compression, is getting fire and has fresh fuel mixture. Will not start. Any suggestions? It is less than 1 yr old.
By luvcatzlotz on Sep 08, 2010
Answer: I have the same problem. Thats why the company is called Poulan.. Because thats what you do half the time when you own one. PULLON the starter cord...............
Sep 08, 2010 | Poulan Electrical Supplies
Gas oven doesn't work.
your ignitor might be bad. check if it glows. if it glows and takes a while to flame up change ur ignitor
Feb 12, 2010 | Ovens
Bottom 2/3 of screen has bars & bands
It sounds like the "data" connection between the motherboard and the LCD screen is "flaky". Open the screen a little more, or a little less, and see if the image corrects, as the screen rotates on its hinges.
But, this "flexing" is just a bypass, not a solution to the problem.
However, if it's less than one year old, it's still protected by the manufacturer's warranty.
The retail store that sold the computer to you may offer a "no-questions-asked" replacement of a "dud" computer. So, backup your personal files (to an external disk-drive or to a USB memory-stick) and then take your computer back, demonstrate the problem, and be insistent.
Some computer-stores (especially the smaller ones) will offer to "rent" a laptop computer to you -- they do it all the time for professional conferences -- for a short-term, while your computer is "away", visiting HP, and getting repaired.
Exercise your warranty, and be insistent in your demands.
Nov 06, 2009 | HP Pavilion dv2-1030us Notebook
Top feed will not pull in paper the black piece inside is broken..where can i get that piece?
If the printer is less than 1 yr old then you can have it repaired under warranty. If the printer is over 1 yr old you can call Laser National (716-824-6159) to get the part if it is in stock.
Nov 04, 2009 | HP LaserJet 2840 All-In-One Printer
Sputtering, chugging, black smoke - won't restart when hot
check your tail pipe for a "clog" engine not breathing correctly.
Jun 22, 2008 | 1993 GMC Sierra K1500
Samsung dlp
HLS4266W 43" dlp. In less than 1 yr whining grew worse, but did know what it was. Year passed with warranty and lamp went out. Replaced lamp. Worked for 3.5 hrs. Turned on next day and did not work. Got another lamp, but did not work. Figured out might be color wheel. Replaced it too. TV started up. Watched that night. Turned on next day, heard loud pop. Lamp never came on. Withdrew and reinstalled lamp a couple times to see if that worked. Did not. Currently, with new lamp and color wheel installed, lamp light blinks, but no lamp comes on. What now?
Sep 17, 2007 | Samsung HLN5065W 50" Rear Projection...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
95 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
