Question about Kenwood KDC-MP235 CD Player
My radio cuts off and says call whenever i am driving
  • Kenwood Master
  • 19,396 Answers
Hi Call on display means Call Service.
That means that a short or an incorrect voltage had been detected. The unit goes off to prevent further damage.
If this happens with vibration, or when turning on the ignition then it is usually a bad wiring at the back of the unit.
Posted on May 27, 2010
  • dee burnett Apr 12, 2015
    The brown mute wire shouldn't be connected if it is snip it and tape it off
How do I stop my car's clock and radio from resetting
Somebody didn't know what they were doing when they wired the radio and put both power wires to a hot in run fuse
Mar 16, 2016 | 1995 Honda Civic del sol
Do you know why whenever my radio was taken and now my car wont start ?
On many vehicles, starting around 1998 or so, there was an anti-theft security measure incorporated into vehicles involving the radio. Alternately, the thief may have cut other wires too, so inspect the opening closely and under the hood, especially.
Jun 16, 2014 | 2001 Oldsmobile Alero
97 camaro cuts off when driving
Hello
The engine and automatic transmission in this vehicles drive train are fully electronically controlled by a computer called the PCM (Power Train Control Module). Whenever a problem like this occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM
Aug 24, 2012 | 1997 Chevrolet Camaro
Engine tripping
Hi
It seems like the wiring issue.
check the wiring or get an auto electrician to have a look at it
thanks
Oct 19, 2017 | 2000 Ford Focus
I have a 2007 Street Glide. The radio cuts in and out. A speaker symbol comes on the sceen whenever the radio cuts out.what can I do? Thank You
Radio has experienced vibration damage to the audio circuit and will need to be repaired. Try contacting Iron Cross Audio. www.ironcrossaudio.com
May 15, 2010 | Harley Davidson 426290 AM/FM Radio
Radio switches modes whenever I hit a bump
think the front panel is pushing on the switch ,you will need to have a good look
Apr 25, 2010 | 1998 Volvo S70
My car will start and then after a minute or two of running, the car will idle down and cut off but I can start it right up again and still get the same results. Whenever I put it into gear to drive it...
Sounds like a possible clogged fuel filter or bad fuel pump. The system provides and initial extra pressure to pressurize the system then pump pressure drops to normal. If pressure is low or filter clogged decreasing available volume the symptoms you describe are the result.
Apr 25, 2009 | 2002 Chevrolet Malibu
the stalling prob when u come to a stop might be ur torque convertor there a wiring plug for it on the transmission unplug it see if thats helps
Apr 13, 2009 | 1997 Pontiac Grand Am
Kenwood KDC-MP235 CD Player Logo
407 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
