Question about Maytag Neptune MDE5500AY Electric Dryer
WON'T DRY DOES NOT LIGHT A FIRE EVERYTIME,ELEMENT GETS HOT BUT NO GAS
  • Maytag Master
  • 43,501 Answers
Hi, If you have a gas dryerWON'T DRY - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer TrouWON'T DRY - 2_bing.gifg2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 28, 2010
Hi there I've got a 05 polaris predator 500 Tory
hi try cleaning the carb or check your air filter box might be filled with oil so all you have to do is clean the air filter out with water let it dry and soak all the oil up with a rag or sponge. Best of luck!
Aug 28, 2013 | Garden
Kenmore gas dryer not getting hot enough to dry
If inside of drum gets hot suspect first somewhere between it and the place where it vents outside a blockage---Lint can do this and be hard to find and also represents a fire hazard, each year there are hundreds of fires caused by lint buildup that catches fire
Dec 09, 2012 | Dryers
Hot tub won't get hot enough
Low Heat -
This problem is not usually associated with the heater element but more often a result of water flow issues. Specifically blockages such as dirty filters, partially closed valves etc... But... excessive scale/mineral build up on the element is on uncommon and can result in reduced heating. The fix is easy, use chemical treatments to reduce scale build up.
No Heat
No heat or water is only heating to 60F- 80F? If you are getting a low reading this is because the water is only being heated by the friction caused by running through the plumbing system and pump. Assuming there has not been a dry fire (visual signs of burn/overheat marks/ damage to the heater tube) and your temperature sensor and hi limit are in working order.
A bad element. Like a light bulb, spa heater elements will burn out over time & there are many factors which affect their longevity.
Nov 25, 2012 | Home
My Bosch electric dryer wta3510uc heats but doesnt get hot like other dryers. why is that? it takes over an hour to dry or even more and it use to seem much hotter. clothes are still cool and damp after 40...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
heatman101
Aug 22, 2010 | Bosch Axxis WTA 3510 Electric Dryer
My Kenmore auto dry I no longer gets hot. I assume the pilot light went out. How do I re-light the pilot?
Hi, If you have a gas dryer2_bing.gif.
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
May 27, 2010 | Dryers
Oven won't start
Very interesting. The ignitor is working, so that means you have power and the control is working. The safety valve is working, and you have a complete circuit. So why won' t she fire off? Inside the safety valve is a bi-metal that only opens if the resistance is right. The resistance only changes when the ignitor is on. As it gets hotter it changes in resistance. This allows the gas safety valve to release the gas and ignite. Watch this:
May 07, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Dryer runs but the heater element gets hot then shuts off. After a few minutes it will heat up again. Is the problem more likely: the hi-limit thermostat or the multi-temp thermostat or the thermal cut-off...
The heating element is SUPPOSED to cycle on and off. The element has a regulating thermostats to ensure it does not get too hot. If the element were to stay on continuously, the dryer would overheat to the point of the element eventually failing, or create a fire hazard. It will cycle on and off dependent upon the internal temperature the moisture level in your clothing (if you are using the Auto-Dry feature).
If your dryer IS still heating, but you are experiencing longer dry times, you may want to check the dryer interior cabinet and/or the entire exhaust duct run to ensure you don't have any clogs or choke points. The following link explains many of the problems that can cause poor drying efficiency:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to actually overheat. Eventually, this can lead to component failures and is the source of fire hazards.
If you have any questions, please post back an let me know. I hope you find this information helpful.
May 07, 2010 | Dryers
MODEL PYGT444AWW GAS DRYER LITES UP OK BUT SHUTS DOWN HEAT TO SOON ALONG TIME TO DRY
there is a saftey relay that might be bad and needs replacing.. this is there for keeping dryer from starting a fire or over heateng.. when the dryer start heating the saftey switch is on and once it stops heating the switch is open and and will not dry.. it could be a heating element once it gets hot it expands and will not heat..
Mar 25, 2010 | Dryers
Dryer gets hot and spins won't dry cloths
clean exhaust vent ASAP it could start a fire if the heat has nowhere to go out the moisture stays inside and your heat element will cycle on and off on a high temp limit swich
Apr 01, 2009 | Kenmore 73952 Gas Dryer
Dryer gets hot when not running
Getting hot when not started is a great concern.
I have a few ideas why, but this is a fire hazard and I would suggest unplugging and either getting help or replacing.
That said, there here are a few suggestions.
1) if the element is shorted to ground, it will get power to one side of the element and heat though ground. This, again, is serious.
2) if it heats forever and doesn't get warm enough to dry, this is another indication of an element that is not working up to power. Not getting 230 across the entire element and not getting hot enough to dry.
3) Many times when a dryer runs too long, the air flow if blocked by the vent being plugged or some plug withing the dryer itself.
Again, I am very concerned about this problem and suggest you not use it until it is repaired. If you want to check the element, it is fairly easy, but unit will need disassembled.
Mr Boo
Nov 30, 2008 | GE Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
70 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
