Question about Whirlpool DU1055XTSQ Built-in Dishwasher
Water filll sbut then nothing happens. just a humming
    Sergeant:
    Champion:
  • 311 Answers
The wash pump is bad or obstructed. Investigate as needed to see.
Posted on May 28, 2010
Switched on but nothing happens, just a faint humming sound. lamps are on correct
it sounds like the water valve is opening (hence faint humming sound)check the water suplply
Feb 12, 2014 | Bosch Washing Machines
My typewriter hums but nothing happens...seems like the motor is jammed...
The humming is probably the motor turning but the drive belt may be broken. You would need a qualified technician to replace the belt if necessary.
Apr 05, 2013 | IBM Correcting Selectric Ii Typewriter
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
The machine will not fill. There is a humming sound like its about to pump the water, and then nothing. Help!
if there is humming thats the sound of the valve ( water inlet opening) I DONT WANT TO SOUND SILLY BUT IS THE WATER TURNED ON it happens
take care
sonic boom electronics australai
Dec 29, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Washer doesn't do anything. We start the cycle
Nothing will happen untill the water comes in. Check the water inlet SCREENS fer clogs
Aug 31, 2009 | Washing Machines
Just makes a hum nosie and won't spin or anything else
Sounds like the belts are off the bottom of the machine..
You may want to pull the front cover and look underneath.
May 30, 2009 | Washing Machines
My front loader has stopped in the middle of the cycle.
you need to clean your pump something is stuck not allowing the pump to drain
Dec 25, 2008 | Washing Machines
Ariston LBE12X will not fill
depends which program you started with if you started with drain or spin then the humming noise you heard is the pump energised but jammed. remove the filter again and check nothing stuck in the pump impellor - bits of bra wire are the favourites if you started with a wash or rinse program, the humming noise is the inlet valve energised but no water coming thro. check water is turned on and hoses not kinked
May 22, 2007 | Ariston Technologies LBE12X Ariston
Whirlpool DU1055XTSQ Built-in Dishwasher Logo
94 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
