Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Green Picture My LCD\DPL went from a Perfect picture to a mostly green tint. Like someone just switch a switch. Model # T5687S
    Guru:
  • 374 Answers
Sounds like you are not getting a red in your feed. Have you check the feed into your tv or if the cables are having a problem?? check it and let me know........
Posted on May 27, 2010
57 inch hdmi rear projection no green or red in picture
how do i press tint on remote dont know how to get in
Apr 15, 2013 | Televison & Video
What causes green tint to picture
should be a setting in the menu for changing the green colour on the screen, should be able to adjust green blue and red to get perfect picture settings for the user.
Oct 20, 2011 | Hitachi Televison & Video
Need lg 32lh30 calibration specs
I think I have a solution involving far less effort. Have you tuned your picture settings? Out of the box, the settings are ok and the presets will do the trick for most. But if you're like myself, you want the best picture possible. Here are my settings:
Picture menu:
Aspect ratio: Just Size
Energy Saving: Off
Picture Mode: Expert 2
Backlight: 35
Contrast: 90
Brightness: 54
H Sharpness: 40
V Sharpness: 42
Color: 50
Tint: 0
--Expert control menu
Dynamic contrast: Off
Noise reduction: Off
Gamma: Medium
Black level: Low
Real Cinema: On [grayed out]
Color Standard: HD [grayed out]
Color Gamut: Standard
Edge Enhancer: Off
xvYCC: Auto [grayed out]
OPC: Off
Expert Pattern: Off[grayed out]
Color Filter: Off
White balance: Warm
Method: 10 point IRE
Pattern: Outer
IRE: [see below]
Luminance: 137
-- 10 point IRE calibration
IRE: [Red, Green, Blue results, respectively, for each IRE point]
100 [-8, 1, -40]
90 [-13, -5, -40]
80 [-20, -12, -40]
70 [-17, -14, -33]
60 [-17, -12, -31]
50 [-17, -13, -26]
40 [-13, -12, -19]
30 [-6, -4, -8]
20 [-6, -4, -10]
10 [2, 3, -1]
Color management system
Red color: 2
Red tint: 0
Green color: -1
Green tint: -7
Blue color: 2
Blue tint: 7
Yellow color: 0
Yellow tint: 1
Cyan color: 0
Cyan tint: 0
Magenta color: 0
Magenta tint: -2
These are taken from CNET.com
Nov 08, 2009 | LG 32LH30 32 in. LCD HDTV
There green tint in my picture on all my connections on vizio 47
Try shielded video cables and make sure you have your cables hooked up correctly. Sometimes you can conect them wrong, specially the red one. If you are using componet in on your tv, make sure the red one is not connected to your audio. The green tint is because you are missing red in your picture.
Mar 16, 2009 | Vizio VO47L 47 in. LCD TV
Help me willtab guru man...Please.
What is the make and model of your television.. green tint and vertical lines indicat a problem with the light engine..although the clear menu says otherwise..im not sure what type tv you have. lcd plasma change the light im guessing you mean bulb .. this indicates to me you have a dlp. but green tint to me indicates a tube projection type tv... so im just guessing hear. vertical lines also indicate a bad buffer board on a plasma or lcd. so let me know what you have
Jun 16, 2008 | Televison & Video
Green tint to pictures
This a CCD fault- it should be returned to the Vendor if under warranty or contact Maskers Website
May 22, 2008 | Olympus FE-110 Digital Camera
Green tint to everything on my Samsung HDTV Digital 1080i television
I have the same problem here on this Samsung 40" LCD. its a 2007 model. everything was fine until recently. I had to reset my digital cable box. now the picture has the green tint. its ruined what was a nice tv, and it won't go away.
Mar 11, 2008 | JVC HD-56G886 56" Rear Projection HDTV
Pink tint when usig the RGB component cable
Check the green signal lead - if one of the RGB leads doesn't make good contact, the picture will take on an odd tint that doesn't always look like it's missing one of those colours. For some reason, the green is always the most common one to fail.
Feb 28, 2008 | NEC MultiSync VT540 Multimedia Projector
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
233 people viewed this question
Henry  Thomas
Henry Thomas
