Question about RCA Scenium D34W20 34" TV
Crackling noises while tv is on
I bought the tv at Walmart about seven months ago and it has worked fine until now . One evening after work I turned it on and it immediately started this cracking and popping noises from the back of the tv. I thought it was something where is was heating up to play, but the noise kept right on. So I thought maybe it was just a one time thing, but that was a week ago and it is still happening.
  • 3 Answers
We had a TV that did that once and the TV repair man said it was a CRT leak which is flamable. So you may want to be careful with it.
Posted on May 27, 2010
Westinghouse TV making crackling sound
I have had the same issue with a Westinghouse 50 inch LED TV. I believe it is not the power supply but the HDMI input. You can temporarily work around by plugging your primary source into the other HDMI. You may also get some relief by using the Westy remote, finding the TV menu, then selecting (Option) (Restore All). There may be an arcane procedure to reset the HDMI.
Jan 01, 2013 | Westinghouse Televison & Video
I have just bought a Toshiba 32KV501B TV. The tv is fine, but the remote control has decided to stop working, within hours of taking it from the box. The tv recognises none of the commands. The batteries...
I also brought this tv one day ago I don't have a problem with the remote I have a loud crackling noise coming from the tv even when the sound is off think its going back to currys.
Jan 01, 2012 | Toshiba Televison & Video
Sanyo DP32649 works fine for a few minute, then sound goes off. turning the TV off for a moment & then back on restores the sound. But sometimes this will happen ever few minutes for the length of the...
I have the exact same problem. It's a volume control issue. For me, when I turn my TV on and have it on low volume, it works fine (but sounds somewhat distorted). But once I turn the volume up to normal levels, the speakers crackle and then go out. I opened my tv and checked my speakers, and they were perfectly fine; not blown or anything. As well, the audio processor and circuitry didn't appear burned at all.
This used happened every few months for 30min or and hour at a time. Then, about 2 months ago, it happened again, and ever since then it still hasn't worked properly. The only way I got around this was by buying a cheap 2.1 speaker system, and connecting it to the audio output on the TV. Or you could buy a speaker bar or home theater system. I believe this issue has to do with problems with the circuitry in the audio amplifier, and there's not much you can do except add external speakers, or contact Sanyo if you still have an active warranty.
Depending on where you bought your TV (such as from walmart), its possible that the LCD panel was produced by Sanyo, but the electronics were done in China. Walmart does this with nearly every TV they sell.
Jan 30, 2010 | Sanyo DP32649 31.5 in. TV
Tv works then whirring noise like a motor stops and starts again
Bad Color Wheel Call Encompass for Part 1-800-638-3328 DO NOT KEEP playing TV untill this is Fixed other wise you can cause Alot of Damage to Set.
Sep 26, 2009 | Thomson 35776650 Bulb for 44DLP540 Rear...
Seven months ago, a bosch alled at my house
you will always have this problem in city type of appltcations.there is too much of a flow differation.
Jul 13, 2009 | Bosch 2700ES Natural Gas AquaStar ...
RCA D52W19 "crackles" and smells like its burning
Hello pmzone_guard, This problem is quite common in this TV it's due to a capacitor in the power supply being overloaded. The chassis model is a ITC222. The capacitor is located on the deflection board which is part of the power supply and should not be touch by someone that does not have TV Repair Experience, due to the fact that this area of the TV is the most dangerous. I would suggest having a qualified TV repair technician do the repair on this TV. If the problem is just that one capacitor the part will cost about $2.50 at the most, so the charge will be the cost of the part plus the labor involved. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 14, 2009 | RCA D52W19 52" Rear Projection Television
No power, no sound, no nothing
in this model is very common problem is that the fault in the transformer is damaged
Feb 08, 2009 | Memorex MP3851SP Radio/CD Boombox
Crackling Sound
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
Jan 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
Tv making a loud crackling
The set should be under warranty, call the company or go on line and get a servicer out asap. good Luck
Mar 19, 2007 | Polaroid FLM-3232 Television
RCA Scenium D34W20 34" TV Logo
209 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
