Question about Pentax ZX-10 35mm SLR Camera
The film was advancing fine in my Pentax 35mm SLR camera.Half way through a roll of film, the advance lever stopped about half way to complete advance. It will not go past the half way point. The batteries are good,which has no bearing on the problem. What is the problem, and how doI fix it. Thanks!
  • 55 Answers
Rewind film and take it out the camera. Try advancing the wind lever.
If the wind lever does not move, you have jammed advance mechanism.
Posted on Jun 17, 2010
Advance lever and shutter stuck how do I fix it
Is there film in the camera? If so it may be at the end of the roll and thus when advancing the film it jammed. Rewind the film then see if the lever and shutter operate. If not then a CLA is needed.
Oct 28, 2013 | Pentax K1000 35mm SLR Camera
When taking a picture the film does not advance. It must be shut off and turned back on again. After developing those pictures, the top half of the picture is black indicating that the film is not...
if the film drive cogs are all ok then its the film advance drive gears on the motor drive striped or slipping,,you could test this by opening the camera and genteelly holding the film advance cogs with your finger and pressing the shutter if the film advance cogs stop turning then the drive gears are slipping or striped? this could be caused by the after load censer in the camera not censing the end of film roll and trying to get another frame out of it? like it read a 24ex as a 36ex but the censor faled to stop the motor drive winding on and that striped the gears
Aug 09, 2010 | Canon EOS Rebel K2 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Pentax SF10 Camera -- double exposure
If you press the film release button like you are going to rewind exposed film you may be able to activate the film advance lever to cock the camera so you can take another picture, and the film should stay on the first exposure allowing you to re - expose it. I would underexpose each image 1 F stop because.you are exposing the same film twice. Double exposures are always an iffy proposition and anything can happen. After the second exposure cocking the film advance should allow the film to advance once again. You might test this on the final pictures on a roll in case the camera won't start advancing the film after you try it. This way you won't blow a whole roll worth of pictures testing it.
Apr 12, 2009 | Pentax PZ-70 QD 35mm SLR Camera
Film won't advance
Pentax ME Super was one of my favorite camera, small and clean shutter release. But it has been about 25 years since it was manufactured. They happen to use rubber break within shutter unit and as any rubbers, it started to deteriorate and melt between the shutter-blades. This prevents the complete cycle of the shutter and jams the winding. You may be able to unjam the winding but eventually you have to overhaul the shutter unit. Overhaul charge is around $100 in US repair market. -James
Mar 31, 2009 | Pentax ME Super 35mm SLR Camera
My film won't load
Jammed Advance Motor Assembly.
Feb 27, 2009 | Pentax ZX-60 35mm SLR Camera
Film will not advance
Pressing the rewind button wind the film advance lever,if it is free It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Then your winding gears need cleaning
Jan 18, 2008 | Pentax ME Super 35mm SLR Camera
Film advance lever
No problem.
Most film cameras can do that, for quick advancement.
atdlee@netzero.com
Dec 21, 2007 | Minolta X-700 35mm SLR Camera
Film advance lever
Yes this is fairly common with K 1000 and the Spotmatics : although the shutter is cocked and hence you cannot advance film you cannot release shutter because mirror box is not cocked. Remedy : remove bottom cover and locate mirror box lever which protrudes slightely and is movable up and down and is spring loaded. Move upwards until it licks in position ( moving up against spring tension ). Now release the shutter and camera should let you advance the film .
Sep 17, 2007 | Pentax K1000 35mm SLR Camera
Pentax ZX-10 35mm SLR Camera Logo
279 people viewed this question
Top Pentax Photography Experts
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
