Question about Danby (DAR604BLS) Refrigerator
My Danby Fridge is propane and is used at our cottage only from May to October and even at that it is intermittently used depending on when we are there. We always make sure the baffle is clean and the back is dust free. It has worked well for many years. This time when I lit it the flame was very very large, basically the almost the size (diameter) of the baffle pipe and I was unable to see the tip as it was inside the baffle. It was still a good blue flame and the fridge worked but created a smell (like a burning) that was very unpleasant so we shut the fridge off after 3 hours. I also felt that this was not right and when something is not right with propane, I shut it off! I have done the following but with no reduction in the flame size. Replaced the fuel nozzle and replaced the regulator on my propane tank. After being unsuccesful, I then turned down the gas flow with the lever on the line. This dropped the flame to its normal size - success! - but unfortunately the fridge did not get cold after leaving it on for 5 hours. The cottage is in a remote area with no roads and would be difficult to get out so my preference is to fix it myself but I am not sure where to go from here. A local gas store suggested it might be the thermostat. HELP!
SOURCE: We have a Danby fridge
Thanks very much for your offer and your effort. After about another hour I got ahold of someone at the company who suggested some solutions, so I'll try them out. Thanks again.
Mildred
Posted on Jul 03, 2008
  • 1462 Answers
SOURCE: fridge not working
almost certainly a compressor fault. not worth repair
Posted on Sep 02, 2008
  • 1462 Answers
SOURCE: this is a Danby refrigerator
fault is the thermostat. auto defrost on a fridge (but not a freezer) is a function of the thermostat
Posted on Nov 16, 2008
  • 132 Answers
SOURCE: frost free fridge making gurgleing sound
mine does the same its sort of like a food digestion sound a reliable fridge mechanic that i have used for over 15 years told me this sound is normal and if it stopped then it would be a problem so no dont worry its fine glenn.....
Posted on Nov 22, 2008
  • 97 Answers
SOURCE: have a diplomat fridge/freezer - the freezer is
check the air damper from the freezer to the fridge. most likely blocked with ice.
Posted on Jun 08, 2009
Question about ignighter
igniter failed, out of adjustment , or dirty carbon build up
Jul 14, 2017 | Danby Refrigerators
Danby propane fridge model # dpr2262w-6. the freezer still works great but fridge portion does not . the fridge has a bad smell. the fridge is at a cabin and no service
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 24, 2010 | Danby DPR2262 Top Freezer Refrigerator
My propane fridge will not get cold
You have described an Ammonia refrigerator. The chemicals in the system are Ammonia, water, and hydrogen. In a crazy system of events, heating the bottom of the unit will cause the chemicals to seperate and then reunite in a complete cycle.
If you have never smelled a strong ammonia smell, then yes, the upside down thing will many times work.
The chemicals can become seperated in the wrong areas of the interior components.
Perform the upside down thing for 24 to 48 hours. Return to normal. Pause it for minimum of 4 yours and try again.
If the burner is working correctly, then you should see some results.
Oct 30, 2009 | Refrigerators
Propane refridgerator wont get cold
It most likely is air locked. Disconnect propane line and burb it ...tip it on its side for an hour and try connecting the gas line and start it up
Oct 19, 2008 | Danby DPAC10061 Air Conditioner
Danby propane frig model DPR2260-2 owner's manual
I have the same refrigerator and am looking for the manual as well. Did you ever find one? If so, where?
Thanks,
Ari
Renata BC
hi_ari@yahoo.com
Oct 06, 2008 | Refrigerators
Dryer LG 6DTD3120
You should change it back to regular gas the problem is in pressure reg gas come to your home at much greater pressure then propane that's why it takes longer to dry the other thing is to keep your lint trap clean because it can affect drying once in while blow out lint hose as well
Jul 26, 2008 | Dryers
We have a Danby fridge model #DPR2262W, bought about 4 years ago for our cottage that has no electricity. Yesterday an acrid smell came out of it and later in the evening the carbon monoxide detector went...
Mildred
Jul 02, 2008 | Danby Refrigerators
Our Danby propane refrigerator has given us sterling service for about five years, but it has suddenly stopped cooling in the refrigerator box-the freezer still works. Any clues?
Having a simular problem; try changing your regulator on your propane tank. I'm try to find a new thermostat myself. Good Luck!
Apr 17, 2008 | Danby Refrigerators
Propane refrigerator is too cold
You have a defective thermostat. Change it.
Nov 18, 2007 | Danby DPAC10061 Air Conditioner
Danby (DAR604BLS) Refrigerator Logo
63 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
