Car Audio & Video Logo
Posted on May 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i have a Clarion VRX 578 in car dvd player it has an intermittent fault on CD/DVD part of unit. After, between 20 and 60 mins the unit will turn off and then come back on within 30 seconds. This does not do this while in radio/ipod mode. Can you tell me if this is repairable. thanks Ian
Anonymous
Level 3:
President:
  • Master 1,561 Answers
  • Posted on May 27, 2010
Anonymous
Master
Level 3:
President:
Answers
1561
Questions
0
Helped
296535
Points
4482
This is repairable, it will just need a good rewire to help you check, because this is most likely a power problem on the dvd player, whenever the ic on the player gets hot, that is when the units turns off.
Get a good radio mechanic, they will help you fix the problem.
Take care.
Clarion vz400 can't select dvd/cd function
  1. Check the wiring: Make sure the wiring from your DVD/CD player to the head unit is properly connected and secure.
  2. Check the DVD/CD player: Ensure that your DVD/CD player is working properly and that there are no discs stuck inside.
  3. Update the firmware: Your head unit may have a firmware update available that can resolve the issue. Check the Clarion website or contact their customer support for more information on how to update your firmware.
  4. Replace the head unit: If the above steps do not resolve the issue, the head unit may be malfunctioning and may need to be replaced.
If you're not confident in troubleshooting the issue, it's best to seek assistance from a professional installe
Clarion NZ500 nothing on screen
Clarion ebrake safety bypass without using toggle switch
Clarion has a brake safety wire that has to switch from open to a ground every time you turn on the unit so therefore you cannot just ground the brake wire it has to switch to ground every time you turn on the radio
Wich video format supported
Released 2 years ago Included Units Stand-Alone Monitor, Amplifier
Supported Audio Formats MP3, WMA
TV Tuner Without TV Tuner
Radio Tuner AM, FM, Satellite, XM Ready
Aspect Ratio 16:9
Input Connectors AV x 1
MPN MAX685BT
Monitor Size 7 inch
Output Connectors AV x 1
Power Per Channel 50 Watts x
Supported Media Types DVD Video, DVD+R, DVD+RW, CD-R, CD-RW
Supported Video Formats DVD, DivX
Dolby Digital / AC3
I found all of this at http://wize.com/car-dvd-players/p469604-clarion-max685bt
Good luck.
Hope this helps!
I need to know what kind of movie format i have to transfer to ipod to see in the clarion vrx 785bt i mean i bought the cable cca 723 and I put in my ipod one clip movie but I cant see in my dvd...
MP4, MOV, H.264 are suitable formats for iPod. And u also need a video tool named Pavtube Video Converter to help u convert other movie files to a compatible format with iPod with good quality.
It works for me greatly.
My clarion vrx486vd vcd problem
DVD video discs
Audio CDs
video CDs CD TEXT
Clarion vrx 485 vd.tuner works with amp but cant get dvd or cd to play with amp.screen works cd an dvd are playing but no sound.an with key off tuners playing till i open door?what have i hooked up wrong?
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
it sounds like you have hooked the power wires up wrong try trace back your wires with this diagram
Clarion VCZ625 6-Disc CD/Video CD/DVD Changer
I would say to take it back regardless of what the problem is. I would say the unit is bad. Does the remote work the other functions? if it does not then the remote could be bad, if the remote does work the other functions, I would think the unit is bad.
Really Loud Fan Noise
They have a bad issue with that. The fans fail all the time inm those clarions... I can sell you a used fan for $40 or if youd like me to repair your unit you could send it to me and i will repair it for a total of $200. ampman out!
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
