Question about Lexmark E260dn Laser Printer
WANT TO INSTALL PRINTER ON LINE
DISK DRIVE NOT WORKING
  • 3,051 Answers
Hello there :
Lexmark has a free online driver installation download.
go to www.lexmark.com and enter the site than search for your printer by entering your printer model number and search for you printer
Now once you have found it i Highly recommend installing the entire suite that is offered, this is because it has all of the features that the cd that came with your printer plus a little bit more.
The download is large so ensure that you have room on your hard drive ok ?
Hope this is very helpful
Best regards Michael
Posted on May 27, 2010
  • mainstaut585 May 27, 2010
    NOT ENOUGH INFORMATION
Hp designjet t1100 blank hard drive installation
Unfortunately I had a similar issue with an HP A0 printer. The Hp 'Engineer' could not fix it. The hard drive had failed and there is a complete new hard drive with software loaded available but only through Hp.
Feb 27, 2014 | HP Designjet T1100ps Printer
Erase hard drive hp1055
In service test menu scroll to "3.Hard disc drive", & press enter, if test drive passed don't replace the hard disc or modification or changes. If test failed then check as shown below:
1 Switch the printer OFF. Remove the EIO Card (if installed) and re-install the Hard Disk Drive making sure it installed correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails again then replace the Hard Disk Drive.
2 If the Hard Disk Drive Test passed after removing the EIO Card,then switch the Printer OFF and reinstall the EIO Card, making sure that the two installation screws are completely tightened.
Switch the Printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails, then the EIO Card could be faulty.Replace the EIO Card.
3 If the Hard Disk Drive Test continues to fail after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module..
I am having little knowledge, if I am wrong Pl don't comment, pl forgive me.
May 20, 2013 | HP DesignJet 1055cm InkJet Printer
I could not samsung scx 3400 printer to my pc having 256 MB RAM
I suggest you install more RAM and do a hard disk maintenance before you install the printer driver.
Hard disk maintenance should be carried once a month to make your computer run efficiently. This removes redundant and temporary files, recovers disk space and speed up hard disk access. Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too. Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click to highlight the C drive and click Analyse - then click Defragment. When this is completed repeat these steps for the D Drive if you have a D drive. Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time. http://www.fixya.com/support/r3559146-hard_disk_maintenance
Mar 08, 2013 | Samsung SCX-3400 All-in-one Laser printer...
Printer will not install
Hello. Thanks for choosing Fixya! Click on your start button and then on printers and faxes. Look and see what other printer drivers you already have installed. Delete any that you no longer need and THEN install your new disc. Regards, Joe
Nov 12, 2009 | Office Equipment & Supplies
Lost the install disk for my HP4580C printer. Is
Take this link to hp and enter your model number or choose let hp detect hardware. I have found both to work nicely.
http://www.hp.com/#Support
Oct 15, 2009 | HP Photosmart C4580 All-in-One InkJet...
Mac OSX 10.4.11 Error when installing the Epson NX400
If you're running the install program from the install disk CD, it may be attempting to create a work folder on the CD instead of your hard drive. I would drag a copy of the install program onto your hard drive first and then launch the copy on your hard drive.
Let me know if that solves your install woes...
best of luck on this.
K
Jul 24, 2009 | Epson Stylus NX400 InkJet Printer
Getting error code 04C300 00310000
Hi;
if you HP 1050C Plus display System Error 04CXX Try the following Steps to resolved an error:
1.)Press ENTER and switch the printer OFF. Remove the Hard Disk Drive (if installed) and make sure that the EIO card is installed
ON again. If this error code continues to appear then replace the EIO card.
2.)If this Error Code disappeared after removing the Hard Disk Drive, then switch the Printer OFF and reinstall the Hard Disk Drive, making sure that the two installation screws are completely tightened. Switch the Printer ON again. If this Error Code reappears, then the Hard Disk Drive could be faulty.
Replace the Hard Disk Drive.
3.)If this system error continues to appear after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module...
May 26, 2009 | HP DesignJet 1050c InkJet Printer
Lost installation disk for microline 520 printer
Did you check on-line with OKI? If they do not have it, check used computer stores on-lne and ask if they have it. Perhaps they can burn you a disk for a small fee.
Does you new computer have it in their database?
Go to Printer install, and check the OKI database in MS windows. Might be there. Just install and go to work.
Cheers.
Mar 27, 2009 | OKI MICROLINE 520 Matrix Printer
My computer's disk drive does not work how do i install the printer now?
are you refering Disk Drive to CD ROM? if yes then you may need to download drivers for your printer and perform the installation. not sure what is your printer and OS. below link may be helpful to solve your problem.
http://etech.maiila.com
if your hard disk is having problem you may need to repair the HD before able to install the printer...
you may find useful link to solve HD problem here... http://etech.maiila.com
Nov 02, 2008 | Office Equipment & Supplies
Lexmark E260dn Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
