Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Saltware system from intex won't unlock
I cannot get my intex saltwater system to unlock it keeps flashing 88 i pressed the button until the first short beep and then pressed again until the second short beep it never goes to 00. it worked yesterday but i had to unplug it and when i plug it back in it would not work Help This is my second year with this product
I am having the same problem getting it unlock did you get a solution?
Posted on Jun 16, 2011
    Problem Solver:
  • 10 Answers
I'm not sure exactly what buttons you're pushing but you push the down button until it beeps, then the up button until it beeps. Then you set it. To lock it you push the down button until it beeps, then the up button until it beeps. Hope that helps and I apologize if those are the steps you're already taking.
Posted on May 28, 2010
I do not have my user manual for my intex saltwater system, I bought it and used it last summer. I forget how to set my system and it is beeping like mad right now. I just want to run the filter system to...
Alright I imagine you have it hooked up already if its beeping at you. A couple of things to ensure first. One is a PCV pipe that has a electrical connection going to a T at the top. On that section of PVC pipe there should be an arrow. Ensure that arrow is pointing in the same direction as the stationary PVC pipe that contains the titanium plates. Now Ensure that you r filter pump is Supplying water to your salt water system. So it should be pool to filter pump to salt water system back into the pool. Now in order to program your salt water system you need to lift the screen protector. Press the left (down arrow) until you hear a short beep then press the right button (up arrow) until you hear another short beep. You just unlocked the keys, now you need to set the hours of operation by pressing the up arrow. For 2000gal pool you want to set for 2 hours if it is 68 to 97 degrees out. anything higher run it for 3 hours. For a 4000gal pool you want to run it for 5 hours if its 68-82 degrees. 6 hours from 84-97 degrees and 7 hours if its hotter than that. Once you have the hours set the machine will automatically start (ENSURE THEFILTER PUMP IS ON). You can relock the keypad by press and holding the down arrow button until it beeps then the up arrow button. A green chlorine light should light up within the next 5 minutes, which indicates the saltwater system started the chlorine production.
Jul 24, 2011 | Intex Automatic Salt Water System for ...
Still showing code 88. We unplugged the Intex pump numerous time for more than 10 mins. After umplugging the unit several times for more than 10 mins. we powered the unit back up. We held the down button...
Okay!!! Kind of tricky sometimes.. After pressing the down button and you hear the first beep, quickly release the down button.. Now press and hold the up button until you hear the beep again and quickly release..The LCD should be blinking now and ready to set you time by pressing the up button...
If this does not work, you may have to call INTEX
Here's their info and I hope I helped.. Please rate me if I was helpful. Good luck...
Jul 23, 2011 | Intex Automatic Salt Water System for ...
My intex saltwater pump reads 88 and when I hit the arrows it continuously beeps without ever resetting to 0. I unplugged overnight and still doesn't work.
This thing is very sensitive. If you dont get the timing just right or in the right order that often happens.When it happens turn it off for a few seconds then try again. The book says hold the down button down for 5 seconds until you hear one beep, then up button for 5 seconds till you hear another beep. I find that 5 seconds sometimes isnt long enough and sometimes to long. Like I said, it is quite touchy. After two years still have it happen sometimes. P.S. Make sure the pump is running and water is flowing when you try it.
May 07, 2011 | Intex Automatic Salt Water System for ...
Code 88
Plug the pump in. You will see code 88 which is normal. Press and hold the down button for 2 seconds until you hear a short beep.Then press and hold the up button for anohter 2 seconds until you hear a short beep and the LED flashes 00. Using the up button set the time to run based on the size of the pool which you did not list. Tell me the size and I will tell you how many hours to set on the timer. You can download an owner's manual here: http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
Jun 01, 2010 | Intex Automatic Salt Water System for ...
Lost manual
I am assuming you have poured in the correct amount of salt. If not post the size of the pool and I can list the correct amount. Now, you will need to set the hours of operation according to the size of the pool which I need to know in order to help more. I will go through the procedure of startup. When you turn the pump on after dissolving the salt in the pool, it will show a code 88 which is normal. Press and hold the down button for 2 seconds until you hear a short beep. The LED will flash 00. Your keypad is now unlocked. Push the up button to set the number of daily hours of operation according to the size of your pool. Up to add hours, down to remove an hour. If you do not have an owner's manual tell me the size and where you live and I can tell you how much salt to add and hours each day to run.
May 30, 2010 | Intex Automatic Salt Water System for ...
Cant get the salt water pump started
Hold the left button until it beeps. Hold the right button until it beeps. You should see flashing 00. Set the time by moving the right button. Then hold down the left button for a long beep. Then hold down the right button for a long beep.
May 29, 2010 | Intex Automatic Salt Water System for ...
I can't get the (Intex) salt generator to time set. It just stays on 88.
Did you attempt to unlock the keypad before trying to set the time? In case you didn't, these would be the proper steps:
Unlock the keypad by pressing and holding the "down arrow" for 5-seconds until you hear a long beep and then the "up arrow" for 5-seconds until you hear a long beep.
Set the number of hours you want it to run by adjusting the time display using the "up arrow" or "down arrow" until you have the correct number of hours.
After setting the time re-lock the keypad by pressing and holding the "down arrow" for 5-seconds until you hear a long beep and then the "up arrow" for 5-seconds until you hear a long beep. Several minutes later the Green LED should come on indicating the cycle has started.
Jul 06, 2009 | Intex Automatic Salt Water System for ...
88 flashes on display screen
Hold the down arrow till it beeps then hold the up arrow till it beeps When you see double zero then set the # of hours you want it to run with the up and down arrows.
Then you will need to lock it in use the down arrow again and wait for a longer beep then the up again till a long beep.
You are set remeber that it will take about 5 minutes for the chlorine light to come on
you can also go to intex.comm and watch the video or read the manual
Jul 03, 2009 | Intex Automatic Salt Water System for ...
Intex pool chlorinator trouble with unlocking mechanism
do not get frustrated with the long phone call.
Get your receipt ready and you could have a new filter in a week
CALL THEM BACK
They are good about these things
Mine arrived in 5 days no questions asked. I didnt even have to send the old one back
Keep as many parts from the old as you can especially the electro cell that is 200 bucks by itself
Jun 27, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
304 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
