Question about Comfort-Aire HD-651 Dehumidifier
Unit is running but not collecting water
Cleaned filter but still is not functioning
    President:
  • 2,468 Answers
The units sealed refrigerant system has leaked out and you need to have it repaired,and recharged
Posted on May 27, 2010
Testimonial: "Thanks for the quick response. I am wondering if it is worth it to fix since the unit is over 5 years old, or if I should just replace it."
  • danny Hendrickson May 28, 2010
    usually not unless you can do this job yourself,with e.p.a. regulations it costs a lot just to evacuate the old,find the leak,repair ,and recharge it,about $100.00+ minimum
  • danny Hendrickson May 30, 2010
    usually not worth fixing because i.m giving my price structure and our area has pretty cheap rates and &100.00 isn't really cheap when you consider a new one at probably around the same $'s
5 Suggested Answers
SOURCE: no cowater collecttion
I have a goldstar dehumidifier model #dh2510a. It runs but does not collect any water in the tank. I have pushed the tank up to the red button in the back. Is there a fuse or something else I can do.
Posted on Sep 10, 2008
  • 41 Answers
SOURCE: Kenmore Dehumidifier
if the compressor is running it sounds like a refrigerant problem or dead compressor in both cases its not cost efective to repair dan
Posted on Jul 17, 2008
  • 225 Answers
SOURCE: kenmore dehumidifier runs but won't collect water
If you haven't done so already, try removing and cleaning the inlet filter screen which is almost certainly just behing the inlet grille. It may slide upwards out of the casing or downwards unto the bucket area. If this is blocked with fluff then no moist air will get to the cold pipes, so little or no water will be extracted. There's also a chance that the humidity sensor is clogged with fluff, so fooling the system into thinking the room is pretty dry, in which case the compressor will probably not run.
A running compressor can usually be detected as a deep throbbing from the machine. If it is running, but not cooling the pipes behind the intake grille, then you may have lost the refrigerant from the system via a leak. If the air coming out of the machine is warm (caused by the compressor running) but there is no water produced this may be the cause.
Explore along these lines and let me know what you find.
Cheers, D
Posted on Jul 31, 2008
heatman101
  • 43501 Answers
SOURCE: The unit turns on and appears to work, but no water is collected
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on Jun 03, 2010
Whirlpool gold dehumidifier, fan is running, but not collecting water. It's in a bathroom, and the temp doesn't get below 60. filter was very dirty and the inside as well, from not cleaning the filter....
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Feb 10, 2011 | Whirlpool AD35USS Dehumidifier
It is not producing water, it runs but no water is collecting in pan.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again.
Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue.
This situation will have to be addressed by a qualified technician.
Take care.
Aug 19, 2010 | Whirlpool AD25BBK Dehumidifier
Water is not going into the tank, but it does run and panel lights up. Filter is clean. It worked for the past 2 months.
If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Good luck
Aug 16, 2010 | Haier HD656E Dehumidifier
My whirlpool dehumidifier fan runs, but no water is being taken out of the air; cleaned the filter and still no change; dehumidifier was purchased in August 2008.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Aug 15, 2010 | Whirlpool Dehumidifiers
It runs it just doesn't collect any water. Not even a drip.
Take care.
Aug 15, 2010 | Whirlpool AD25BBR Dehumidifier
My dehumidifier is running but not collecting any water. I have cleaned the filter and it still wont collect water. Is it broken?
Good luck.
Aug 15, 2010 | LG Dehumidifiers
My Maytag Model number M7DH65B2A is not collecting water
Take care.
Aug 12, 2010 | Maytag M7DH65B2A Dehumidifier
Collects very little water never fills up the container. all fiters are clean
Take care.
Aug 11, 2010 | Fedders A7DH45B2A Dehumidifier
My dehumidifier has not, does not collect any water. HELP !
Take care.
Aug 10, 2010 | Amcor AHD45 Dehumidifier
Unit not collecting water
Good luck.
May 15, 2010 | Soleus CFM-40 Dehumidifier
Comfort-Aire HD-651 Dehumidifier Logo
698 people viewed this question
Top Comfort-Aire Dehumidifiers Experts
Mike Squire
Bill Long
Michael Youngman
Michael Youngman
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
