LG Flatron w2052tx the screen just took a severe yellow hue. I didn't change anything. How can I get correct color back?
  • 570 Answers
If you have brought any magnetic thing near it, the screen will go wrong so the color will automatically adjust in few days
thanks
Posted on May 28, 2010
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
Someone pressed 'a button' on the remote - now there is no yellow on the screen - yikes - lots of red and green! How do I fix this?
Go to the menu screen and look for picture options and then look for color or Hue on the menu, this will allow you to change the hue and correct the color balance. I have a Sony and there is a yellow button on mine and it changes the settings to what they call Cinama scene and when I press this it makes the picture darker and more yello. Mine is a Sony and yours may be different.
Dec 31, 2010 | Philips Televison & Video
My Lg Flatron W2241T is doing this strange color shift. It's a color shift, not a light issue. The hues actually bounce to a different shade all togather, and stay that way for anywhere from a few seconds...
Check to see if the color change is evident when you wiggle the back of the monitor cable going out of the PC. If this causes the sympton you most likey have a poorly grounded backing plate. It should ground the video to the chassis. If it is loose sometimes merely resting the case on the cord will keep it from shifting, but just as easily you should recrimp the edges of that little plate to your PC case. If it is on video card make sure the retaining screw is tight.
Aug 17, 2009 | Computers & Internet
LG Flatron - Power button flashing blue
i get a similar thing, i accidently entered sleep mode then turned off my computer at the power button on the back, now i turn on my monitor( i dont get blue flasjhing but it jsut goes on and it doesnt register, then says going into power saving mode and the colour on the button turns yellow its very frustrating :(
Apr 20, 2009 | Computers & Internet
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Yellow Screen
Furst, check the video signal cable, if you can, try a replacement. Try removing and then refitting the original, sometimes this clesans the connections
Dec 26, 2008 | LG Flatron F700B 17" CRT Monitor
My lg flatron L1730S, the screen shows some different color
1. Solder the neck board dry points (cromo IC )
2. display cable connector.
Dec 20, 2008 | LG Flatron 915FT 19" CRT Monitor
Screen is now a weird color
The problem might be in the cable. Try to reconnect it to your machine. Also try to set your color settings on the monitor itself, so that all the colors are equal.
Sep 26, 2008 | LG Flatron L1750S 17" LCD Monitor
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
LG Flatron LCD Power Saving Mode
Well thats seems tricky does it not come on at all when you boot the computer. If the screen is working then it should work to display the Start up screen. If it does then keep pressing Delete until the BIOS comes up- then search the pages for power saving and slect to OFF
May 18, 2007 | LG Flatron L1750S 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
