Question about Maytag MDE308DAYW Electric Dryer
How do you put the belt on on my dryer ? every time I put it on it has alot of slack
    President:
  • 2,468 Answers
Your not getting it onto the idler pulley,or your not routing the belt correctly,when it goes over the idler pulley correctly there will be a lot of belt tension then as you need to force the idler over to get the belt over it
Posted on May 27, 2010
4 Suggested Answers
  • 2468 Answers
SOURCE: How to replace a belt on my dryer, my old one
you don't have it around the idler pulley next to the motor,if its routed the correct way you will need to pull up on this pulley to get it over the motor pulley,then when you release pressure on this idler the belt will be taught then
Posted on Nov 17, 2010
wheelshot
  • 102 Answers
SOURCE: how to replace the belt for a whirlpool ler5620kq1 dryer
It is a very tricky task to put this belt on but I think I can work you through it. When you get the belt around the drum and get to the idler, push the belt under the idler wheel and through the forks of the idler pully assy. attaching it to the pully on the motor. Tension should be on the idler pushing the wheel up toward the drum. Hope this helps.
Posted on Apr 02, 2009
  • 93 Answers
SOURCE: dryer belt slack
Start from the motor threaded shaft. Then pull out the Idler pulley so that the back of the belt will lying on the Idler pulley in upright position. that is all.
Posted on Apr 08, 2009
How to replace drive belt
Unplug it from the electrical outlet.
Remove the back panel.
Look for the "idler-wheel" -- it takes-up the "slack" between the drive-motor and the rotating tumbler.
Loosen it, to put enough "slack" in the drive-belt that the drive-belt can be removed.
Take the belt to a dryer-service store, and get them to match it.
Connect the new belt to the drive-motor and the tumbler.
Adjust the "idler-wheel" to take-up the slack.
Replace the back-panel.
Add power.
May 31, 2015 | Asko T712C Dryer
HOW DO I PUT DRUM BELT ON A PORTABLE HAIER DRYER I HAVE ORDERED THE BELT IT CALLS FOR FROM HAIER COMPANY TWICE AND IT IS STILL TOO LONG MAYBE I AM PUTTING IT ON WRONG help please
Your idler pulley will take up the slack in it. It won't be real tight any way once on. If there is still a lot of slack when ou turn it on and the drum doesn't turn, then take it back. Take the old belt with you so that it can be matched uproperly.
Jan 25, 2015 | Haier HLP140E 115 volt portable dryer...
How do you connect the belt to the pully, and drum?
loop the new belt around the drum,then take loop of belt under the idler pulley wheel and pull back on wheel to get slack to put remaining loop onto motor pulley shaft,then slowly release and idler will tighten up the belt automatically
Jan 02, 2011 | Roper REX4634KQ Electric Dryer
How to replace a belt on my dryer, my old one broke so i am trying to replace a new belt to the drum but am finding i have alot of slack
Nov 17, 2010 | Zanussi TC7102W Electric Dryer
Cannot put the drum belt on
make sure the bracket is properly cliped to the base and the iderl wheel is twords the tub
pull the bel together under the tub, take the loop, pull it under the pully, lift the pully slighltly, place the loop on the motor
Oct 14, 2009 | Kenmore 74602 Gas Dryer
How to replace the belt for a whirlpool ler5620kq1 dryer
Apr 01, 2009 | Whirlpool LER5636P Electric Dryer
Dryer belt slack
Mar 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Good afternoon I'm a bit confused???? I'm knee deep with a dryer repair, (Sears Kenmore model # 110 97292100 gas front loading dryer) and everything is disassembled in my garage. The belt broke - that...
Its a bit frustrating to say the least just trying to explain this one,so I'll give you my best and with patience you'll get the belt on.Follow the picture below closely to get the idea of how the slack is made up. Please Rate This !!10ff711.jpg
Jun 22, 2008 | Dryers
Maytag MDE308DAYW Electric Dryer Logo
142 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
