Question about Intermatic Digital 3-Circuit Timer Mechanism P1353ME
I have a P1353ME three circuit pool & spa digital control timer... Programmer I have no idea and was trying to re-program... some how I programmed in a time and my pool pump is going on and off... I only need to use 1 event... and in 1 event there is load 2... that is what needs to be zero out... my question is the system is going on and off on event 1 how do I zero everything out and start over Thank you, Joann
P1353 manual with wiring and programming appear on following link:
http://waterheatertimer.org/pdf/Intermatic-P1353-manual.pdf
1) To clear all programming, press MODE button located above PROG button. Use paper click and hold in MODE button for 5 seconds until display shows SET MODE and the Mode Number blinks.(page 30).
2) Use ENTER button to to review events for each circuit. At this point, you can reprogram timer.
Use PROGRAM button to advance to next circuit and go to next programming feature. (page 31)
3) Don't forget, when reprogramming timer, and you want each circuit to operate independently, then select MODE 1 (page 33).
4) P1353 timer can control 3 different circuits. And programming for each circuit can be independent, or linked by selecting different MODE (page 33).
Linking programs let you control 2-speed motor for example, with each speed controlled by separate circuit.
5) You can set up to 3 programs for each circuit.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 31, 2011
P1353ME Intermatic Pool Timer starts and then stops
sounds like you are working with 220 2 blue are two hots across the two you should get 220 volts each of the greens and green should only give you 120 volts make sure unit can be wired 220 volts
Jul 05, 2015 | Intermatic P1353ME Timer, 3-Circuit Pool &...
How to clear event
Go here and look at page 33
http://cache-m2.smarthome.com/manuals/42689.pdf
Look at page 8 in the Manual link.
May 01, 2015 | Intermatic Digital 3-Circuit Timer...
Wiring diagrama for timer p1353me
P1353ME is versatile timer, and can be wired many different ways, and wiring can vary depending on which mode is selected, and which loads are being controlled.
The key to understanding P1353ME wiring is that incoming voltage connects to terminals 1 and 2. This will power the timer mechanism and power the switches, but does not put any power to terminals 3 thru 8.
Terminals 3 thru 8 are 'dry' switches. There are three switches, and you have to connect power to each switch.
Terminals 3-4 are one switch, just like a light switch that turns on-off with timer programming. Terminals 5-6 are separate switch. Terminals 7-8 are separate switch. So there are three switches.
Also in different modes the switches can operated at the same time, or operate separately with different programming for each switch.
Copy following links for wiring diagrams and more information:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#P1353
http://waterheatertimer.org/pdf/P1353ME-Mode-Applications.pdf
http://waterheatertimer.org/images/P1353ME-2-speed-motor-500.jpg
Jul 26, 2012 | Intermatic Digital 3-Circuit Timer...
How to program intermatic pe 153p
PE153 comes with P1353 timer.
The timer instruction manual is too long to copy.
Read manual, and add a comment with specific question about any part of manual.
Add as many comments as needed.
http://waterheatertimer.org/pdf/P1353ME-instructions.pdf
P1353 is 3-channel timer.
3-channels means that timer can control 3 separate circuits, each with different timing schedule.
Timer has 5 different modes.
Page 13 of manual shows modes.
Select different modes depending on what type of device(s) you are controlling with timer.
For example, 2-speed pool pump, you select MODE 2 or MODE 4
By selecting Mode 2 or 4, the timer protects against programming conflicts that would turn on both speeds at same time, and cause electrical problem.
Aug 15, 2011 | Intermatic Digital 3-Circuit Timer...
My intermatic pool tmer will not set time or let me auto. turn to on so I can't filter or backwash pool
Problem points to electric power.
1) For best possible free answer, please add a comment and give model number that shows inside timer door.
This will give expert access exact manual for the equipment you have, and show what voltage you are working with.
2) You can also review Intermatic pool timer sell sheet, and pool timer site to help identify product:
http://waterheatertimer.org/pdf/Pool-and-spa-catalog.pdf
http://www.poolandspacontrols.com/products.aspx
3) If you have mechanical dial timer, see if manual override works.
And then check electric power.
Check circuit breaker.
Check if manual override works.
4) If you have P1353 digital electronic timer:
http://waterheatertimer.org/images/P1353ME-digital-time-clock-mechanism.jpg
P1353 digital electronic timers have auto setting.
Check programming.
Programming for P1353 is complicated, and longer than space allowed for free answer.
Programming starts on page 25, and you can add a comment about any specific part of manual that is confusing.
Mar 09, 2011 | Intermatic Timer T12404R Pool & Spa...
How do I connect my 2 speed pool motor?
1) You might need a different timer.
240Volt T106 has one NO terminal and one NC terminal.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t106r%20-%20english.ashx
2) Terminal 1 is NC terminal
NC terminal is 'normally closed' so electricity flows continually through this terminal.
For example you can connect this terminal to speed-1.
So speed-1 is on until timer turns on, and then electricity is turned off to NC terminal and speed-1 stops.
3) Terminal 4 is NO terminal
NO terminal is 'normally open' so electricity flows through this terminal only when timer turns on.
For example you can connect this terminal to speed-2.
So NO terminal only has power when timer turns on.
When timer turns off, NO terminal turns off and NC terminal turns on again.
4) As you can see, the problem with T106 timer is that pool motor is continually running.
Either speed-1 is on, or speed-2 is on.
5) Here's how to wire T106 for 240V two-speed pump:
Two hot wires arrive from breaker box: 1 black wire and 1 white wire.
White connects to terminal A
Black connects to terminal 3.
Three wires go to motor.
Speed-1 connects to terminal 1 probably black wire
Speed-2 connects to terminal 2 probably red wire
Remaining motor wire connects to terminal A probably white wire
Ground wires connect to green ground screw.
6) Usually, 2-speed pool pumps are wired to dual timer like T10404R
So each speed is wired to a separate timer.
With this timer, each speed is connected to separate timer, and then the pump can be turned off when neither speed is needed.
http://www.amazon.com/Intermatic-2-Speed-Timer-208-277-T10404R/dp/B002UBPCDW/ref=pd_sim_sbs_hi_1
7) However there is a newer electronic timer P1353ME and P1353ME-6 and PE153 that can control 3 different loads. This timer snaps into any T106 box.
For example speed-1 is one load, speed-2 is another load, and a pool light can be third load, or simply do not use third load.
http://www.amazon.com/Intermatic-P1353ME-3-Circuit-Digital-Switch/dp/B001DSEC7A
http://1000bulbs.com/product/3352/ELEC-PE153.html
8) I am familiar with wiring and programming for P1353 timer, and you can post again on fixya, and I will catch the question.
Feb 12, 2011 | RTO Intermatic T106M Timer Mechanism Only...
I have an intermatic RC3621RT 5 circuit timer with remote controls for the spa. I'd like to upgrade, but I cant find a cross reference for a new box that would be the same. Can you help?
Following pdf file shows Intermatic pool and spa controls
http://waterheatertimer.org/pdf/Pool and Spa.ashx.pdf
PE40000 series has remote control and 5 SPST circuits (3 timed with timer and 2 on-demand with remote control). Can be wired for both 120V and 240V circuits, so pump can be 240 and lights 120, or both 120.
The new timers are electronic
Intermatic pool and spa website with contact-us information & manuals:
Feb 11, 2011 | Intermatic Hardware & Accessories
Hi expert: I am installing intermatic P1353me digital pool or spa mechanism and having trouble to figure out how to do this heater Firemen Switch connection. My existing pool timer is T104 and there were...
1) Fireman's switch automatically turns off heater few minutes before turning off pump.
Not all pool timers have fireman's switch.
If old timer did not have it, then don't worry about it.
P1353 has wires marked for fireman's switch, so simply don't use them if you don't want to.
page 21 of manual shows wiring for fireman's switch.
2) T104 and P1353 comparison
Difference 1: T104 turns OFF both hot wires, while P1353 turns Off 1 hot wire.
http://waterheatertimer.org/Compare-120-and-240.html
Difference 2: T104 controls 1 240V load with 1 time schedule, while P1353 controls 3 different 240V loads, each with different time schedule.
Check that wire(s) coming from breaker can handle all 3 loads.
http://waterheatertimer.org/Color-codewire.html
3) 240Volt T104 is wired as follows:
http://waterheatertimer.org/images/T-104-240-Volt-400.jpg
Hot1 from breaker connects to T104 terminal 1
Hot2 from breaker connects to T104 terminal 3
There is constant power on terminals 1 and 3, each terminal has 120V when combined makes the 240V circuit.
Load1 wire connects to T104 terminal 2
Load2 wire connects to T104 terminal 4
Terminals 2 and 4 have power whenever timer turns ON
4) Definition:
In electric wiring, Line means power from breaker, and Load means wire going to light,fan, motor, pump.
5) Converting T104 to P1353
http://waterheatertimer.org/images/P1353-timer-350.jpg
http://waterheatertimer.org/images/P1353-terminals-566.jpg
Hot1 from breaker connects to P1353 terminal 1
Hot2 from breaker connects to P1353 terminal 2
This will power timer electronics and timer clock and switches.
Jumper wire is placed from Hot1 at terminal 1 to each Line terminals 3 5 and 7.
This will put power at the switch, and when switch turns ON, then power will flow from Line wires to Load wires and then on to the Load.
Load 1 connects to terminal 4, Load 2 connects to terminal 6, Load 3 connects to terminal 8
To complete each 240V circuit, Hot2 is connected directly to each Load.
6) You say 'salt' system connects to terminals 1 and 3 on T104, then those wires are carrying constant 240V to that device. So Salt system connects to terminals 1 and 2 on P1353
7) Get a second opinion:
I frequently contact Intermatic for various problems.
P1353 is fairly new product, and manual is long, and I might not fully understand your problem or wiring.
Intermatic answers their email.
http://www.intermatic.com/customer%20service.aspx
Jan 28, 2011 | Intermatic Digital 3-Circuit Timer...
I need instruction on how to program this timer intermatic p1353me
I dug around Intermatic pool controls and found instruction pdf with programming for P1353
http://www.poolandspacontrols.com/~/media/Files/PoolAndSpaControls/Products/Instructions/PE45343RC.ashx
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 04, 2011 | Intermatic Digital 3-Circuit Timer...
How do I turn off completely the intermatic 3 circuit timer P1353ME, not only in between cycles?
Manual for P1353:
Programming instructions for P1353 start page 30
The on-off button is merely an override of existing program, and then programming resumes at next event setting.
I have read this manual looking for a simple way to turn off timer functions so no pool equipment operates, and it appears that you have to turn off circuit breaker.
This is the same as any mechanical timer such as T104 or T101, and is not brand-specific as all mechanical box timers follow same pattern. Mechanical timers have override button, but the timer reverts to regular schedule at next tripper, just as the P1353 does.
Keep in mind that each load on timer can be wired separate from the timer clock. So you can turn off the load wire going to each load, and still have power to clock.
If you cut power to each load, then it is not necessary to reset current time. Programs remain inside timer even if power is completely cut to timer.
Sep 25, 2010 | Intermatic Digital 3-Circuit Timer...
Intermatic Digital 3-Circuit Timer Mechanism P1353ME Logo
223 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
