Please describe your how to create an IPSEC tunnel between a Sonicwall TZ170 and a cisco RV082 problem:
  • sales68420 May 27, 2010
    I recieved an answer BUT NOT THE QUESTION I ASKED. the answer is for two cisco routers not a sonicwall tz170 and a cisco RV082
    Question I asked
    Answer from experts
    Dear sales68420,
    A new solution has been posted for your Routers Problem on FixYa.com.
    Click here to read the solution: http://www.fixya.com/ThreadView.aspx?thi...
    If you have any questions please contact us.
    Regards,
    The FixYa Team
  • 4,737 Answers
It would be difficult to write down all the details here. And it'll take more than one hour if i explain it here. I hope you understand. You can create Ipsec tunnel for different (make/brand) routers in the same way you connect the same cisco routers. First you need is to create a simulation so that you'll not fail during the setups, otherwise it's difficult to deal with it without seeing things in reality. A diagram is also very helpful, you can create one like this..: Please describe your how to - 9b4c9f8.gif
The details instruction from startup to verification is given here https://www.cisco.com/en/US/products/hw/routers/ps221/products_configuration_example09186a008073e078.shtml, follow the instructions (your ip and and device names will be different). If you are not a certified cisco professional, i would suggest you not to do so, since it's complicated and without proper configuration, you might damage the devices. Good luck
Posted on May 27, 2010
  • 1,170 Answers
ASA VPN setup
this has been nicely explained here:
http://www.computerfreetips.com/Cisco_router_tips/ASA-VPN-tunnel.html
Feb 23, 2012 | Cisco ASA Computers & Internet
What command do i run to show IpSec tunnel status on ASA 5520
show ipsec stats
this command was introduced in code 7.0
it will show the active tunnels, the previous tunnels and several other stats of inbound and outbound packets.....
for example:- IPsec Global Statistics ----------------------- Active tunnels: 2 Previous tunnels: 9 Inbound Bytes: 4933013 Decompressed bytes: 4933013 Packets: 80348 Dropped packets: 0 Replay failures: 0 Authentications: 80348 Authentication failures: 0 Decryptions: 80348 Decryption failures: 0 Decapsulated fragments needing reassembly: 0 Outbound Bytes: 4441740 Uncompressed bytes: 4441740 Packets: 74029 Dropped packets: 0 Authentications: 74029 Authentication failures: 0 Encryptions: 74029 Encryption failures: 0 Fragmentation successes: 3 Pre-fragmentation successes:2 Post-fragmentation successes: 1 Fragmentation failures: 2 Pre-fragmentation failures:1 Post-fragmentation failures: 1 Fragments created: 10 PMTUs sent: 1 PMTUs recvd: 2 Protocol failures: 0 Missing SA failures: 0 System capacity failures: 0
Dec 11, 2010 | Cisco ASA 5520 Firewall
I need to add an ip range to my sonicwall tz 170
This is not directly possible to do with a TZ170 as the device will only allow configuration for 1 static or dynamic IP at a time for the WAN port.
However this being the case, I suggest setting the SonicWALL up as a perimeter firewall and place devices that require the other public IPs form the additional IP range behind the TZ170. Basically the SonicWALL becomes the gateway for the other IPs needed as long as the range of the IP block is contiguous.
This would involve using the 4 ports of the LAN on the back of the TZ170 to connect directly to the other devices or if it is more then 4 devices, using a switch connected to the LAN side of the SonicWALL to provide connectivity to the multiple devices behind it. Most TZ170 are licensed for 10 connections on the LAN side and if you require more then 10, additional licenses will need to be purchased.
I would be careful pushing too much traffic through a TZ170 as it is designed for Small Business use and will quickly become overloaded with too much traffic causing high latency/traffic bottlenecks and in extreme cases connections being dropped. This is especially true for multiple VPNs.
Jan 23, 2010 | SonicWALL TZ 170 SP Firewall
Ipsec problem in asa
Use the ping command to check the network or find whether the application server is reachable from your network. It can be a problem with the maximum segment size (MSS) for transient packets that traverse a router or PIX/ASA device, specifically TCP segments with the SYN bit set.
Jan 22, 2010 | Cisco ASA 5510 Firewall
How to setup up my cctv cam to sonicwall tz170
If your camera is connected to DVR then do the port redirection on your firewall so that you shall view the cameras from internet, If your camera is directly connected to network using RJ45 simply do the port redirection to IP address of CCTV camera.
Nov 19, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
IPSEC problem between ASA and Microsoft ISA
can you try lower encryption levels on each device and see if that helps? sometimes it is neccesary between Cisco and other devices.
May 18, 2009 | Cisco ASA 5510 Firewall
How to routing router static ip address and local
Use the Sonicwall configuration wizard..
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
Apr 22, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
Private network > VPN > network firewll > priv net
Add a static route on the Sonicwall 2040 : 192.168.1.0/24 with the RV082 as gateway (the ip of the network shared between the RV082 and the Sonicwall)
Another solution is to enable NAT on RV082 for 192.168.1.0/24 network. Routing is preferable.
Feb 14, 2009 | Linksys RV082 10/100 8-Port VPN Router...
I want to create site to site vpn with sonicwall tz170+ 2003serv
Complete documentation is available on the below link
http://www.sonicwall.com/us/support/3134.html#heading_3139
Nov 17, 2008 | Sonicwall TZ 170 NFR (01-ssc-5564)...
Site to Site VPN Link with dynamic dns
Hi Rajmeet, Here is the documentation on the SOnicwall TZ170 the detail configuration can be found on page 211. Please let me know if this helps you and if youhave any other questions. http://www.sonicwall.com/downloads/SonicWALL_SonicOS_Standard_3.1_Administrators_Guide.pdf
Apr 02, 2007 | Sonicwall TZ 170 NFR (01-ssc-5564)...
Computers & Internet Logo
David Payne
David Payne
