Question about Sharp LC-32D6U 32 in. LCD Television
I have a nearly 5 year old Sharp LC-32D6U HDTV. The sound stopped working on the TV two days ago. The sound briefly resumed working (about 5 minutes) yesterday and then stopped working again. Is this a simple fix or does it require a repair?
  • Sharp Master
  • 11,800 Answers
No one could know that without actually testing the tv to find what is wrong - it could be from something as simple as a bad connection up to - at worst -  a fried power amplifier. But since it's a sound problem it will be easy and cheap to fix.
Simple test to identify the general origin of the problem: play a something thru one of the AV entries - if you can't hear anything then the problem is in either the IC that commutes between the sources or the power amplifier.
Posted on May 27, 2010
  • ckahler May 27, 2010
    Cable TV is connected through an HDMI cable from the TV to a cable box. There is no sound when Cable TV is broadcast. I also tried playing the DVD player, which is connected via a series of wires ot the TV. The TV displayed the DVD image, but no sound. What is an IC? Is this an expensive repair? Trying to decide if it's time to cut my losses and buy a new TV.
  • Azrael SRL May 27, 2010
    Clearly the problem is in the audio final section. IC=Integrated Circuit.
    Most likely in your case the power amplifier IC has died - it happens. As i said it's a cheap fix for the part($10 to $20, depending on the place of purchase), the labor (which you could do yourself if you have a basic experience in electronics) is where the cost will be.
    If the image is good then it's worth keeping the tv. In the absolute worst case (the failure cannot be fixed)  or if you just don't want to bother to fix it the problem of the loss of the tv sound can be simply put aside just by using an external set of powered speakers connected to the audio output of the cable box and dvd player.
MY SHARP LCD TV HAS PERFECT SOUND BUT WHEN WE TURN IT ON THERES NO PICTURE JUST RANDOM RED LINES.IF WE TURN IT ON AND OFF THEN THE PICTURE WILL EVENTUALLY RESUME
I don't have a solution, but the same thing happened to ours. To sidestep the problem, I just left it on 24/7. Eventually (three days ago) it just stopped working completely.
Dec 25, 2010 | Sharp LC-32SH12U TV
Varous tv channels do not have sound. It is NOT a
TO: rdh041: I don't have the solution to you problem, but we have the exact same problem with our Sharp AQUOS 20" LC tv. Different model than yours, but same age and same perplexing issue. Several channels suddenly have no sound. If you've found a solution, would you please post it? I'll do the same. Thanks.
Jul 15, 2010 | Sharp Aquos LC-20B6U/LC-20B6E 20 in....
My sound card on my sharp aquos 37 is shot. can i
Try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service and tell them that you already did the resets. There is a known problem with a heat dissipation pad for the onboard speakers and they will send a repair tech to replace the pad for free, even if you are out of warranty. At least that was the case with my LC-32D6U.
Aug 23, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquous LC-37hv4u has no sound. All my menu setup and option are still intact. Can this be hardware? If so, what can I do? Thank you
Aug 17, 2009 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
I need a diagram for lcd tv Sharp LC-26SB14U.
I have a sharp LCD (LC-26SB14U) which I purchased one year ago and today the sound stop working as I was watching the olympics. Any idea how to fix this problem as the warranty is only good for a year.
Thanks, Bob
Jun 24, 2009 | Sharp Televison & Video
Sharp aquos lc-32DA5U
check the input
the reciever or dvd maybe its the faulty unit not the tv
Jun 20, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No Audio on Sharp LC-32d43u
If you had sound for before and then lost it (without changing any settings), then try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service (1-800-237-4277) and tell them that you already did the resets. There is a known problem with a heat dissipation pad for the onboard speakers and they will send a repair tech to replace the pad for free, even if you are out of warranty. At least that was the case with my LC-32D6U.
May 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I lose the sound on my 1 year old SHARP aquos Lc-42D62U tv??
There is a fix for this. Call a Sharp servicer or Sharp electronics the cost of repair is around 200.00 dollars.
Apr 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sound went out in the sharp tv we have
I have fixed several of these. The problem is the main board will have to be removed to access the audio amplifier. A qualified technichian should only attempt this due to the location of the main board.
Nov 11, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp LC-32D6U 32 in. LCD Television Logo
76 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
