Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Panasonic pt-53tw53 won't power on /off
Hi My Panasonic PT53TW53 projection tv won't power on ..the indicator light justs keep flashing red 3 times then pausing then flashing 3 times again over and over. I can't turn it off either..I have to unplug it. Do you have any ideas on how to fix this? Is it possible to do this yourself?
thank you for any help you can give :)
  • 4 more comments
  • Anonymous Apr 08, 2008
    wHAT ABOUT A FLASHING RED LIGHT 2 TIMES??
  • revitup Apr 17, 2008
    My panasonic pt-53tw53 just shut off when I turn it on and gives me three flashing light. It will not let me turn it off either. Everyone I talk to say its something different and with it being a projector tv the parts ar hard to find local
  • Anonymous May 03, 2008
    My pt- 53 did the same, tried to power on but power light just keeps blinking in sets of 3 Im pretty handy but need to know where to start!
  • xuyendo1 Oct 24, 2008
    My TV turned on foe few second then off, the red light blinked. In order to turn on again I have to unplug and replag the power cord. Please let me know part to be replaced and how can I buy it.
    E-mail: [email protected]
  • kamcauley Jan 07, 2009
    I have exactly the same issue. One expert very kindly offered a solution. Replace diodes 6301, 6116 and 6117 on the G board. I'm a pretty handy fella, but would appreciate info' on how to go about this! I.E. specific locale of G board in this TV (PT 53tw53) thanks
  • Anonymous May 11, 2010
    How long have you had it? Maybe the bulb went to bulb heaven.
Five blinks then turn off
Posted on Jan 16, 2009
My tv ran great except tghe red was out of focus.. i replaced the STK-110 but now my TV wont turn on instead i get a blinking lights of 3 which i know is the converge but can it also be a resistor.... Model PT53TW53G
Posted on Oct 13, 2008
  • Panasonic Master
  • 8,617 Answers
3 flashes is a convergence shutdown. You will need to replace your convergence ICs. Let me know if you need more assistance. Its a repair that isnt very difficult if you can solder.
Posted on Apr 07, 2008
SOURCE:
Panasonic pt-53tw53 location of my stk chip
my tv panasonic PT-53TW53G turn on red light on tv no pictur on sound
Jan 06, 2012 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic projection tv pt-53wx52c no picture red light flashing 3 times have sound
3 times red light flashing is an error code that indicates problem in convergence output section, please check and replace convergence output chips and pico fuse nearby. Chips replacement in circuit board requires soldering work and local tv repair shop will help you if you are not familiar with soldering.
Hope this will help.
Thanks.
Mar 28, 2011 | Panasonic PT-53WX53 53" Rear Projection...
My panasonic rear projection tv does not turn on the red light blinks 3 times
3 times red light blinking indicates that tv got problem of convergence output ICs failure and need to replace two big black ICs (convergence output) to solve this problem.
IC replacement requires soldering work and good knowledge of electronics stuff repair, please cal local tv repairman if you do not have prior experience of such work to avoid any damage.
Thanks.
Feb 28, 2011 | Panasonic PT-53TW53 53" Rear Projection...
Keeps turning off and red light is blinking 3 time
If it is Panasonic PT-53WX54 rear projection tv then 3 times red light blinking indicates problem of convergence output chips failure in tv that need to be replaced to solve its problem.
Let me know if you are handy with electronics stuff repair and can replace/ solder parts in circuit board to provide you more helpful info OR call local tv repairman to replace convergence output chips tin tv.
Thanks.
Dec 30, 2010 | Panasonic PT-53WX54 53" Rear Projection...
Red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
May 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53TW53G 1 Blinking red light, will not stay on.
just got back today for same problem. convergence went out. took to repair shop. $200 part plus $60 labor. second time in a year convergence went out. was told it will happen again.
Mar 19, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-51HX43G no power, red light flashes
I have a Panasonic PT53TW53G projection tv that had the same problem for power .A terrific person gave us wonderful advice and it fixed our tv! We were told to replace the IC conversion amplifiers. On our model they are STK392-110 (your's may be different). We ordered the parts from www.electronix.com and they were only $12. for the two parts. We also had to purchase a soldering iron and de-soldering vac for removal/replacement of parts. Good Luck!
Feb 04, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Powers down after start up
over load on the power supply/poss. power/convergence or shorted video ic on the crt neck board.
Oct 03, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Standby light blinking 3 times means a convergence error. The two convergence IC's need to be changed Panasonic part# C5AA00000203 (do not substitute with a generic STK#) This is about a $300-$400 repair.
Sep 23, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
326 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
