Question about Frigidaire Refrigerators
The Grille of my Frigidaire was broken. My Model # is FRT18S6AWJ. What's the part number for it. Where I can get it?
  • chsueh_2001 May 27, 2010
    Very good. Thanks
    President:
  • 2,468 Answers
Part # AP4318624
Posted on May 27, 2010
  • 2 more comments
    Where i can get it?
  • danny Hendrickson May 27, 2010
    you will need to find an appliance parts retailer outlet in your area that handles this particular brand of parts
    I called 1-866-925-7278. They said the parts# has been changed. Do you know the new parts#?
    Thanks
    call 1-877-477-7278 that is the correct number for the grille
  • 10,515 Answers
You could buy it from :-
http://www.partstore.com/Model/Electrolux/Frigidaire/FRT18S6AWJ.aspx
Let me know,if needed further assistance.
Hope i helped you
Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 May 27, 2010
    Thanks for your response!!
    Did you find that.
    The Part Number is 241839405
    Hope i helped you
    Thanks
Whats the wiring diagram on a frigidaire gallery refrigerator, model number FRS267TH
You should have a copy of it behind the toe grille on the front. Or on the back of the unit.
Nov 14, 2015 | Frigidaire Refrigerators
How do I pull out tray behind toe grille to clean?
Hello Friend, this is Z. Thank you for allowing me to assist you!
The drain pan of your Frigidaire refrigerator (FRS23R4A) is not removable. Hope this helps! Should you need further assistance please feel free to reconnect.
Sep 01, 2014 | Frigidaire Refrigerators
Frigidaire model PLMV178HC control panel replacement
I can't find if there's a difference between model PLMV178HC and PLMV178HCA. Every search for PLMV178HC redirects me to PLMV178HCA. Unless there is grease or moisture on the control circuit board, then you have a shorting membrane keypad.
It is repaired by replacing the control panel frame assembly, which comes with a new membrane keypad already attached.
For model PLMV178HCA, that is part number 5304470533 and you can get it from Sears online for $89.95 (subject to change).
At my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes. (Also, the service manual is here.)
If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
Be very careful when disconnecting the cables & wires. Some connectors have a locking tab (see photo) Next remove the keypad strip (see photo) Then simply move your circuit board into the new frame.
Be careful, because your display tube is made of glass, and if it breaks, the board must be replaced as well.
Let me know by e-mail if I can help further.
Regards,
William E. Miller, AS-EET
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Jul 17, 2014 | Frigidaire Microwave Ovens
My Frigidaire Galaxy Series Commercial Heavy Duty Dryer does not spin it heats up but doesn't spin. What would be the cause of that?
most likely cause is a broken belt.next time send the model number,i can look up your model and give part numbers.
Oct 06, 2013 | Frigidaire FDE336RE Dryer
HOW TO REPLACE DOOR SWITCH ON A GE STOVETOP MICROWAVE
It depends on the model number, but I'm guessing you mean it's an over the range model.
If so, you only have to remove the grille and controller assembly to get to the door switch mounts.
Our help file on door switches is here.
A YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes is here.
Dec 10, 2012 | Frigidaire FMV156EM Microwave Oven
Glass on my front load frigidaire washing machine is broken. Cost to much for service repair so where can I find the glass and fix it myself?
Hello - Do you have the exact model number? With that information I can provide you the part number, however most parts can be purchase directly from the manufacturer or through a parts distributor in your area (part numbers may be different). Keep in mind that you may also visit the manufacturer website. I will recommend taking off the last letter of the model number so you can pull up the information.
http://b2b.frigidaire.com/support/manuals.asp?NewSearch=New+Search
Nov 17, 2012 | Frigidaire ATF6000ES Front Load Washer
I need the serial number for my Fridgidaire FAM186R2A AC
Yes the front cover is the same as the grille.
You should see the plate with the serioal and model number on the chasis after you remove the grille.
Good luck.
Jan 30, 2010 | Frigidaire FAL126L1A Air Conditioner
Broken vent grille for a Whirlpool microwave hood combination
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical grille in seconds.
Jun 06, 2009 | Whirlpool GH8155XJ Microwave Oven
Door is loose, microwave won't cook
The door switch mounts and possibly the door hinges need to be adjusted them tightened.
Unplug the oven, remove the cover if it's a counter top type or remove the grille and control panel if it's an over range type.
Then close the door and watch how the door latch heads on the door mesh with the door lathes and door switches.
Also check the hinges.
If the door latch heads are not activating the upper & lower door switches, then adjustment will be needed.
For many brands, you can find helpful exploded view diagrams and order parts by entering your full model number here.
There is often a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Please reply back with your brand and model number if you need more help.
Aug 17, 2008 | Frigidaire FMV156DC Microwave Oven
Frigidaire Washer - Loose Inner Tub
the inner drum is most likely broken. go to sears.com select appliances then select parts enter model number and you can get a blow up. Hope this helps.
Jan 31, 2008 | Frigidaire FWT449
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
