Question about Samsung RS2556 Side by Side Refrigerator
Freezer sides works, refridgerator side will not get cool, any quick fix, I am pretty adapt mechanically
    Problem Solver:
  • 14 Answers
There is a good chance that the evaporator on the refrigerator side is frosted up due to a faulty thermal fuse or sensor or both. Since these units have more than one evaporator, there is no damper to get stuck.
Posted on Aug 08, 2010
    President:
  • 1,891 Answers
LETS look at some ot the things that do cause this problem. . if the cold coil in the freezer is frosted over the no air can get through it to cool the firg side . so go back to the freezer . you have a defrost problem . causes . heater / terminator or timer . .. timer ( or the AD C ) tells it when to deforst. the temminator if working properly lets the heater melt the frost off the coil and when about 55 deg turns off hte heater, and the heater has to be ok for this to happen . hope this helps mm . replace the terminator and if glass radiant heater replace them first and them and last the A~D C
Posted on Sep 04, 2010
    President:
  • 2,468 Answers
Is the damper vent door between the freezer and refrige compartments open fully,if this door freezes shut the cold freezer air can't get into the refrige to cool it
Posted on May 27, 2010
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: freezer sides works, refrigerator side
Service Manual
Posted on Apr 20, 2011
I have a 5 yr old hotpoint refridgerator. the freezer side works fine but my fridge side is hot. changed the thermostst but it did not fix the problem
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | Refrigerators
Kenmore side by side refridgerator - freezer works very well, refridgerator not very cold, setting is on coldest set point.
heatman101
Jul 09, 2011 | Refrigerators
Freezer isn't working and refrigerator isn/t cooling. What is the problem? We can hear the fan running however.
my refridgerator is a Maytag side by side did the same thing checked the freezer compartment fan was working removed cover to look at the cooling coil, the coils were frozen solid ended up defrosting freezer compartment every other day. replaced the adaptive control board located in the refrigerator side top, haven't had another problem since.
Nov 15, 2009 | Maytag MSD2756GES Side by Side...
Refrigerator side not cooling
The fresh food section is cooled by the freezer section by forced air supplied by a fan. If you have air flow, check the temp inside the freezer. It should be between 0 and -10. If not look inside your freezer and see if you have ice built up on the back panel. If so you have a defrost problem that is most likely a bad defrost heater, a bad termination thermostat or timer. If ther is no ice then check your fan under the refrig. If you can hear the compressor running it should be turning. If this all checks out then you have a freon system problem like. Low Freon pressure or a restriction.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
MAYTAG REFRIDGERATOR NOT COOLING
Check to see if the evaporator fan is blowing. Sometimes removing the back panel to expose the fan and hand turning it can make it come back on. If this doesn't work then the fan is bad. Also make sure that there is good circulation to the fridge side. Food can sometimes block air flow.
Jul 01, 2009 | Maytag MSD2651 HE Side by Side...
The fridge doesn't cool anything
There is a damper that allows air into the frig side to cool it. There should be a tech sheet in the toe grill with a diagnostic to check the damper operation.
Eric
Jun 30, 2009 | Whirlpool GS5SHAXN Side by Side...
Maytag refridgerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 06, 2009 | Maytag MSD2651 HE Side by Side...
Fridgerator not cooling
I have the same problem. Freezer is okay, but refrigerator is not cooling.
Mar 24, 2009 | Frigidaire FRS26R4A Side by Side...
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Samsung RS2556 Side by Side Refrigerator Logo
852 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
