Question about RCA P52960 52" Rear Projection Television
My auto convergence feature does'nt come up on my set up menu anymore. This happened one day after the tv shut off by itself.The screen comes on,full color but there is the color shadows around the picture.Also.the picture is bowed on top and bottom of the screen like a rainbow.
  • 185 Answers
The power supply for the converge p.c.b. isn't working
Posted on May 27, 2010
Why does my reciever keep turning off by itself?
try looking into the Timer section on the TV. also on Dish if it is left unattended (like stay on same channel etc) it will go in to sleep mode, U then just hit the Select button.. U can go in the Dish menu and set the Sleep mode (inactivate mode ) to a longer time, I usually set my for 8 hours.
Jul 09, 2014 | DISH Network DVR-625 DTV Receiver /...
I hav a RCA model D52W25 its 52" it has convergence problems dont know how to setup the color things can u help??
Click on the following link :
http://www.riddledtv.com/repair/RCA.html. Go to the following section
(2) (3) (4)
(5) Stretched Image at top and bottom edge very distorted. Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link: Alignment Procedure (pdf)
Also download the Alignment procedure pdf file. Hope this will help you. Please let me know if the information was of any help to you or you need further assistance.
Thanks
Oct 08, 2008 | Televison & Video
Rca big screen 5-8 years old, power shut off this morning while watching then when I powered it back up now blurry and has a red and green outline around everything onscreen
If you have the original remote to that tv, click on menu, then select set up from the on screen menu, then select convergence. you might see auto convergence as well as manual for blue and red convergence.
If you see Auto, select it, this will line up your tubes.
If no auto convergence, you will have to select each one, and follow the instructions to aline your tubes.
Oct 09, 2010 | RCA R52WM24 52" HDTV Projection Television
A red blue and green line comes across both the top and bottom of my tv . alignment is also off
Sounds like the classic convergence option symptom. If you press menu and scroll to the set up screen see if the auto convergence feature is still listed. If its no longer there the rca repair kit called ITC222 and ITC222A convergence option missing repair kit from www.tvrepairworld.com will usually repair that problem. The kit contains the parts and the CD with repair instructions.
Aug 03, 2010 | RCA D52W23 52" HDTV CRT TV
Mitsubishi vs-70601 picture pincushioned and out of convergence
could just be a convergence issue. there should be an auto-convergence feature in the menu. outside of that, you'll have to manually converge the colors seperately (also a feature in the menu).
Jul 29, 2009 | Mitsubishi VS-70601 70" Rear Projection...
Picture green and not clear, getting smaller, shutting itself off
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
No blue auto convergence when performed by menu buttons
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 31, 2008 | RCA HD52W59 HDTV Projection Television
The convergence is way off on my projection rca tv - i lost the manual but i have set it before in a menu but caint remember how to get to it Was watching a movie, tv shut off and powered back on by...
It should be in the options menu. If not often RCA will drop the option when the convergence ICs go out and often the set will shut down. Heres alink that should be able to help you get a manual and parts if needed. If they dont have your manual leave an email and they should be able to get one quckly usually within an hour or two.
http://servicemanuals.vstore.ca/
Apr 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P50830BL
Hi,the trouble is the power supply for the convergence,it the board that mounts above the two board that lay flat,there is a ic on that board that is heat sinked,part number is 215530,replacing this ic will return the menu and repair the set,the board is green 5 inches wide and 8 inches long.
Mar 13, 2008 | RCA P50830BL 50" Rear Projection...
Convergence Problem w/Proscan PS56670
IN THAT CASE YOU NEED TO REPLACE THE CONVERGENCE STK'S AND SOME TV'S NEED A INTERNAL ADJUSMENT AFTER REPLACE THE CONVERGENCE.
Aug 30, 2006 | Proscan PS56670 56" Rear Projection...
RCA P52960 52" Rear Projection Television Logo
140 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
