Question about Chaney Instrument 13130 GM Atomix Digital Clock
How to set time on a atomix digital clock with time, date temperate
How to disable / hide digital clock from the screen of Nokia 2700
To disable or hide the digital clock from the screen of you Nokia 2700, please follow these steps:
1. Go to Date and Time Settings. 2. Select Time. 3. Choose Hide Clock.
Hope this will help. ;)
May 07, 2010 | Nokia Classic 2700 Cell Phone
How do you set the date and clock?
Below are the steps to assist you in
setting the Date and Time on your calculator.
NOTE: The "Time Set", "AM/PM", "12/24" and "Format" associated keys are
on the faceplate above the respective key. Position the calculator so
that you can look directly over the keypad to see the notations.
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first
digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should
stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press
the AM/PM accordingly.
stop blinking and the time is then set. The seconds will again be
displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To
return to either the TIME or DATE, press the CALENDAR/CLOCK key to
toggle between them.
Jan 25, 2010 | Canon MP49D Calculator
SET THE DATE AND CLOCK
Setting the date:
Setting the time:
displayed.
Jan 25, 2010 | Office Equipment & Supplies
Sony NWZ-E438F clock display is blank..
To set date and clock:
1. Go to Settings (looks like a suitcase-bag)
2. Go to Common Settings
3. Go to Set Date-Time (this allows you to set the date and time)
If you want to change date and time display format, you can also do this under common settings.
I hope this helped
May 28, 2009 | Sony NWZ-E438F Digital Media Player
I can't set the day.
You have to set the Year. Hold the time Set until the hours blink then push the time set button again and the minutes blink then push the time set button again and the year will blink. Change it to 09. Then push the time set button again and set the date.
Mar 26, 2009 | Chaney Instrument 13130 GM Atomix Digital...
Time zone
Hi - You can download the manual from the link underlined in blue below:
Chaney
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 13, 2008 | Chaney Instrument 13130 GM Atomix Digital...
Cant change time on phone
time & date
Your phone needs the time and date for the datebook.
To synchronize the time and date with the network:
Press - > Settings > Initial Setup > Time and Date > Autoupdate
> On
To set the time and date: Press - > Settings > Initial Setup
> Time and Date > time or date.
To choose an analog or digital clock for your home screen,
press - > Settings > Personalize > Home Screen > Clock > Analog or
Digital.
hope this helps
riz.
Nov 04, 2007 | Motorola Mobility SLVR L7 Cellular Phone
613 people viewed this question
Top Chaney Instrument Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Chaney Instrument Audio Player and Recorder Expert? Answer questions, earn points and help others
