Question about Intel Pentium 4 1.7G, 1.7 GHz (p41700400256sk478) Processor
Is nic and lan card same. - Intel Pentium 4 1.7G, 1.7 GHz (p41700400256sk478) Processor
  • Intel Master
  • 4,806 Answers
NIC/LAN are the same.
Regards.
Posted on May 27, 2010
  • 506 Answers
NIC is network Interface Adapter, and LAN Card is exactly the same. Its just another name for NIC.
Nic card not working? How to troubleshoot? Is there a plug and play nic card that can be installed onto this desktop PC?
Hello Sqis,
You can purchase any nic card which is compatible with WinXP or 7.
Insert the card in PC Slot of the motherboard.
Install the driver for the card and it will work.
May 05, 2011 | HP Compaq Presario SR1650NX...
Ehternet light is out (amber), Power, wireless, DSL and internet light on (green). Desktop is wired to the 2wire. Wireless is working.
H there,
Try replacing the ethernet cable, If it does not work try reinstalling the drivers of your NIC card or LAN card. If it still does not work your NIC or LA card is busted.
Apr 18, 2011 | 2wire (2701HG-B) Wireless Router
Having lan card problems what does it affect how much does it cost to replace and fix
C521 LAN card is integrated in MB.
You can Flash the BIOS to most current and load the latest driver (Support.dell.com) see if the card works, next I'd reset BIOS defaults, and try again. If NIC will still not work, it may be damaged. Turn it off in BIOS and replace with a PCI NIC
http://cgi.ebay.com/Xinruilian-Fan-92mm-Ball-Bearing-2pin-4pin-PSU-Power-/200552830688?pt=Computing_ComputerComponents_Fans_Heatsinks_SR&hash=item2eb1e156e0
Jan 14, 2011 | Dell Dimension C521 PC Desktop
Hi I need to figure out the lan/jack port id number.how can I get it? Thank you
LAN/NIC Jack is located at the rear of the machine upper middle if the model has a Network/NIC card installed
Nov 16, 2010 | Minolta Di3510 Fax
How to apply external lan card?
connect usb to rj45 external nic card in to the system install software from cd(one cd may be you received with external nic card)
Nov 14, 2009 | Dell OptiPlex GX280 PC Desktop
Help me enabling "Wake On Lan" On "On-Board Ethernet Card?
Start
Control Panel
Classic View
System
Properties
Device Manager
Expand the "network devices" branch
Select the NIC
Properties
Advanced
Pull-down and select wake-up properties
Change to 'Wake on LAN".
OK
Nov 09, 2009 | Gigabyte GA-945GZM-S2 Motherboard
LAN automatically disconnects while downloading and starts working only after disabling and again enabling the local area connection
With this issue it could be the Hardware / Software compatibility. The first thing to do is ensure the latest drivers are installed or the NIC. If the latest drivers are installed I would recommend replacing the NIC. They are less than $30 and they come with great drivers, and if the old NIC is onboard it would be advantageous to get it off the Motherboard. It would be best to open up the computer before you run out to get the new NIC and makesure the motherboard can support a PCI card. This card slips into the White slot that is about 3 inches long. If you have a White slot that is about 1 inch long this PCI card will not fit into it the card you will need is a PCI Express x1 NIC. The rest of the information you will need is provided by the NIC Manufacturer.
Mar 30, 2009 | Asustek S775 Intel X38 ATX Audio Lan...
Lan 4pc by nic card
You can simply use or buy a router. Router will automatically network your computers without any special configuration.
Dec 17, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Nic
Hello i"am having problem with the port lan no conecting internet
he faded driver of port lan
Oct 24, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Onboard NIC Not connected
remove the nic card from drivers, reboot and check that it is not there,log off put card back in and reboot it should then be regonized
Dec 12, 2007 | 2wire (1000-400108-001) Router
Intel Pentium 4 1.7G, 1.7 GHz (p41700400256sk478) Processor Logo
82 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
