Question about Norcent Technologies2703 27" TV
Trying to reset tv for use on outside antenna from cable it says enter unlock code..i bought it used and don't know what the code is. how do i over ride it?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The default code is 1111. As you are not aware of the password, please follow this procedure---
POWER (OFF) -> MENU -> V-CHIP-> MUTE” to revert to the default password. Please follow the instructions on the screen to change it. Once changed, please remember it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 27, 2010
  • 6 more comments
  • kingfisher31 May 27, 2010
    power off?
    not understanding power off.
  • Rylee Smith
    Rylee Smith May 27, 2010
    First please try 1111 (default password) to
    reset it. If it is not reset then you'll need to press Power (On/Off) key, then
    menu, V-Chip and mute to reset it.
    Thanks
    Rylee
    is going to take much longer ??
    ok i pressed power, menu, but no v-chip appears.
  • Rylee Smith
    O.K. then
    1. Turn the TV off
    2. Press and hold down the
      Channel up key on the TV
    3. Press and hold down the Power
      button on the remote until the TV shows "reset"
    4. Factory settings are now reset
    did that. heard a few beeps i think 4 then screen came on but still locked. when i try to change the setting it is still askig for lock code i tried the 1111 but it will not accept the 4th nuber 1.
  • Rylee Smith
    Have you
    tried this procedure ---
    1. Turn the TV off
    If still the issue is not resolved then please try 0000 and I hope it will resolve
    the issue.
I have a palsonic TFTV826HD tv and when i came home from a 2 week holiday , i am not able to receive the ABC and ch 10 stations , others i have , i reset and did the auto tuning
Do you use an digital antenna receiver which gives you a couple basic air channels for free Or is it through a cable company? It could be the weather conditions or the antenna could be unplugged or cable wire could be loose or cable company could have certain channels being fixed.
. We have a big Element HD tv flat screen and use an digital antenna receiver and when receiver is unplugged or if our outside/entry way doors are open (receiver antenna is outside) none or some of channels won't work..
Hope this kinda helps :/ :) let me know.at least I tried lol
Feb 01, 2017 | Televison & Video
My tv is locked and asking for a an unlock code. I have never had a lock code on the tv since i bought it several years ago. How can I reset or bypass this feature. BTW mt TV is a 48-50" projection...
Hello
I thinks that you have its original remote handset with you now, and posts this solution. If you don't have it, either buy a new original remote handset or try to get it from any of your friends and relatives, who owns the same model of Mitsubishi Tv, you have now; only to unlock it. After unlock, you can use any other remote control.
Mitsubishi sets use a four-digit code for a V-Chip locked program, view a locked TV, cancel the lock, or to enter the V-Chip lock menus. You can view the locked shows on the TV set by pressing the number 9 and QV buttons on the remote at the same time, whenever your code is requested. This process temporarily unlocks the TV and asks you to enter a new code.
OK.
Sep 15, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I cannot enter any symbols example * and # on my phone therefore i cant input the hard reset code for my samsung f480 and there is a different user code in it because i bought it second hand how cani...
Do you have PUK code from your sim card? If you have it you can use that to unlock samsung tocco F480 but if you don't have it you can unlock samsung phone with cable unlocking process and it must do it at mobile repair shop. Good luck and i hope my solution can helping you.
Sep 13, 2011 | Samsung Tocco F480 - Pay Monthly Cellular...
My viewsonic N3751w LCD TV won't receive air signal. It has a built-in digital tunner so it should be able to receive several air signal without a need to have a digital to analog converter
Check that your antenna is sufficient for your location and oriented correctly. Try antennaweb.org for the most likely channels; tvfool.com has a much greater list of channels and the antennas needed to receive them. Both sites assume external antennas and warn that trees and buildings around your location may cause interference.
If you have a splitter connecting one antenna to several TVs, consider using an amplifier to ensure that the TV gets sufficient signal strength. Remember digital TV is has all-or-nothing reception issues.
If you previously could pick up the stations with this TV and suddenly lost them, try resetting your TV. Unplug the unit for at least 10 seconds. Also restore the factory default settings and then rescan for all channels. The reset is possibly Menu, Options, Restore Default or Menu, Setup, Memory Recall. (Viewsonic has changed its menus at intervals so look for something similar). Once you find it, click enter then left or right arrow to YES, hit enter again. Then hit menu twice to exit the OSD menu and then re-enter the menus before trying to rescan channels.
Also check that the TV is looking for OTA and not cable signals. Check that the tuner is still working by retrying the scan in a spot you know that the antenna captures a stations signal. Make sure your antenna cable hasn't been damaged by anything.
If you recently had a power surge (lightning strike) near the antenna or cable, you may be in need of a new tuner. (BTDT with an older TV)
I hope this helps.
Apr 24, 2010 | ViewSonic N3751W 37 in. LCD Television
My cable channels are not coming through. The tv
try all 0000 see what happens sometimes that is factory code hope it works
Feb 20, 2009 | Panasonic CT-27E13 27" TV
Rca tv my guide plus has quit working
The guide plus needs to reset itself over night. But as long as you are only connected to cable it will not allow for it to reset. You need a two way splitter the cable company signal will go in one side and the outside antenna or what ever you were connected to before cable will go on the other connector. The single side connector will go to the tv. Where the splitter says 'in' you will actually be using it as out to the tv. Where the splitter says 'out' you will be using as in for the cable and the other antenna. Guide Plus is built into your tv and needs the tv to be off to reset over night.
Jan 28, 2009 | RCA P61960 61" Rear Projection Television
Connecting antenna -- No Signal
Hi Shelly_Eddie,
Here are a couple of things to try:
Is the TV set to antenna or cable? Use the menu settings
Be sure a wire end is not bent outside of connection, i.e. coaxial cable wires sometimes bend or hide back into the sleeve.
Reset the TV and do a channel scan, unplug and see what happens.
Let me know how you make out. Good luck.
Paul
My Website
Jan 28, 2009 | TruTech PVS31170S1W 17 in. LCD Television
GE 27GT271 locked onto satellite mode?
Is there a way to unlock the satellite setting? no. Will we have to sign up for satellite for a month or so, so that we can unlock it? yes I do not know about your place I stay in INDIA & here unless you subscribe you can not see cable channels. Or are we just out of luck on this?
Sep 24, 2007 | GE 27GT722 27" TV
Bought a TV and has a password i want to remove
When there is a parental code, you have to ring up your tv service provider for the code.
Sep 12, 2007 | Televison & Video
Norcent Technologies2703 27" TV Logo
69 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
