Question about Whirlpool MH3185XP Microwave Oven
My MH3185XP microwave oven will not turn on. Power is to unit. I changed the fuse inside key pad (clear fuse) but still no luck. Suggestion?
  • Whirlpool Master
  • 9,098 Answers
In these models, there are several fuses and two or three thermal cutouts / thermostats which need to be checked.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your full model number from the label on your oven).
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on May 28, 2010
It's completely dead?? Not sure what happened. Power supply is fine.
Microwaves that suddenly loose power could have many causes with the easiest being a blown fuse inside the cabinet of the oven. To check for this unplug the unit and remove the screws that hold the cabinet in place. Be sure to not touch any of the electrical components inside to avoid shock. Visually follow the path the power cord takes as it enters the unit. The fuse ( usually clear glass with metal ends and cylindrical in shape ) should be located not far from where it enters the cabinet. Once located use a fuse puller or other means to carefully remove the fuse to check the element inside. If the fuse is blown take it to a hardware or electronics store for replacement. These fuses are cheap as this has happened to me before. Good luck!
Jun 19, 2011 | Whirlpool MH6110XE Microwave Oven
No power in the microwave but there is electricity at the wallplug
No power and or NO lights at all,indicate a blown fuse.
Locate and replace the fuse inside the unit.
Feb 25, 2011 | Maytag Appliances Over-the-Range Microwave...
Sylvania Microwave oven SC-11100 We have one of
Had a power outage when the unit was hooked up power came back on now unit is beeping like morris code, how do i clear or reset.
Sep 17, 2010 | Sharp R-353 Microwave Oven
Changed bulbs now the unit is dead
You likely knocked a wire loose on the door interlock switch. Also check seating of all connectors elsewhere in the unit.
Apr 27, 2010 | Whirlpool MH3185XP Microwave Oven
I have Whirlpool Microwave oven Model MH6110XEB-0 that has completely loss power. The outlet it is plug itno is still good with power running thru the outlet. I do not have any manuals for the microwave,...
with any luck you have just poped the inline fuse,
if you remove the control board you should be able to see the tube fuse up by the fan motor
if not the whole thing will have to come down to reach it
Oct 14, 2009 | Whirlpool MH3185XP Microwave Oven
Have a Whirlpool microwave oven, model MH3185XP. Just stopped wor
In some Whirlpool models, there are more than one fuse, and two or more thermal devices which can interrupt power to the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Please write back with more details if you need further help.
Feb 28, 2009 | Whirlpool MH3185XP Microwave Oven
Whirlpool microwave MH3185XP: cancel button does not work
The symbol next to the Cancel pad means it would also be used to turn the Child Lock feature on and off.
But as it is, you have a failed membrane keypad.
Luckily, on these models you can replace the control panel frame with keypad all as one unit without doing any peel & stick.
Just remove your circuit board and drop it in the new frame.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
(There are 12 models which start with MH3185XP, so check the tag on your oven for the full model number.)
See reference number 3 on diagram number 3.
Jan 29, 2009 | Whirlpool MH3185XP Microwave Oven
Whirlpool microwave Model # MH3185XP No power?
I just had a problem with mine and took the panel off and did find a fuse on the inside on the top portion of the unit. Try changing it and see if it works. Hope it helps.....
Dec 29, 2008 | Whirlpool MH1150XMQ Microwave Oven
Microwave went completely dead after changing bulb-
Nom...you probably blew the internal fuse. This time...turn off the power. Remove the button panel and search for the blown fuse. It might be ceramic or of some other type. If on a circuit board, there will be a xxxA with xxx indicating the amperage. Use a multitester available at Ace or Radio Shack to test. Replace with the same kind of unit. Your local auto store, appliance parts guy, Radio Shack or Sears parts can get you the part you need. Show them the old one.
Dec 17, 2007 | Whirlpool MH3185XP Microwave Oven
No power - Nothing happens
if you have power at the outlet and the internal fuse is okay, I would say you have a problem on the control board. We repair these nationwide for $32.50. Please see my profile for the Web address: http://tinyurl.com/yzjozk
Jan 08, 2007 | Emerson MW8107WA Microwave Oven
Whirlpool MH3185XP Microwave Oven Logo
217 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
