Question about Homelite Mighty Lite Lawn Trimmer
I have a homelite mighty lite 26cs lawn trimmer. While attempting to start it I pulled the cord, it got wrapped around the gas tank and stayed out. I took it apart and rewound the mainspring, it's back in place. I can't get the tension back on the cord. The cord is on cw as I look at it and the spring is in the slot. Thanks for the help.
    President:
  • 2,468 Answers
You need to rewind the spring without the pull cord handle,then when you get tension back on the recoil spring then it will take in the pull start cord automatically and then you can tie the pull handle back on and it will again recoil
Posted on May 27, 2010
  • 3 more comments
  • ruhlers May 27, 2010
    Thanks for the reply. I'm not quite with you yet. How do I rewind the
    spring w/o the pull cord handle?
  • danny Hendrickson May 27, 2010
    remove the pull handle from the cord,then pull the cord go thru the hole and let it dangle,then wind the recoil spring then hold the rope as you let it rewind,then push the rope back thru the hole and re-tie the pull cord handle on it again
    Just to help me know what we are talking about, there are 2 springs. One spring is like the mainspring, flat like you would find in an old watch, it is in a metal housing and provides tension for the recoil. The cord pulley sits on top of the mainspring and another spring sits on top of the cord pulley and notches into the cord pulley. Turning this top section gives tension to the cord but it doesn't stay.
    I can only turn the recoil spring about 1/2 turn, then it stops.
    then the cam-dog spring is bad,can you order just the flywheel cover which would include these springs and a pre assembled starter rope installed and ready to put on the unit
Homelite weedeater mod. 26cs
Try going to ebay and finding a carb for the model, some are as cheap as $12.
Mar 12, 2017 | Homelite Mighty Lite Lawn Trimmer
I need an address to purchase a fuel tank for my mighty lite 26cs . Model - UT21506 SN- ATK0712739
Go to psep.biz or jackssmallengines.com you will find all that you are looking for ! Godd Luck...
Aug 16, 2011 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Pull cord stays out. Mechanic says I need new
check with home depot on parts for a homelite.
Oct 21, 2009 | Homelite Mighty Lite Lawn Trimmer
Mightylite 26cs Gas Trimmer
sounds to me like dirt in gas tank dirty or plugged filter screen on fuel line inside gas tank or plugged pinched or obstucted fuel line . also check for the following pin hole in primer bulb bad spark plug dirty or rusty coil or flywheel magnet.or simply dirty or missadjusted carb if i can be of further assistance let me know i would start with the fuel hoses and make sure they are in good shape first ...do the easiest and cheapest things first good luck hope this gets you up and running good mrdmburns@cableone,net
May 01, 2009 | Homelite Mighty Lite Lawn Trimmer
I cant start it due to the pull cord not coming out further than 5-6 inches??
Sounds like the cord may be wrapped outside of the recoil pulley and may be spinning the motor backwards. The cord can backlash especially if the trimmer kicked a bit during starting.
Apr 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
282 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
