Question about HP 48gx Calculator
NUMBER 8 BUTTON WON'T WORK - HP 48gx Calculator
  • HP Master
  • 7,993 Answers
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the beginning of the post and skip to the last part For Repairs )
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the diagnostic tests.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Release the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterward you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a high pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
You can also try this site. They do repairs on most models, except the newer ones.
Posted on Jun 16, 2010
IPhone camera won't open
Try restarting your phone by doing a full reboot. Hold down the power button and the button on the front for about 8 seconds. then slide to power off. Once that's done, restart your phone by pressing the power button. If that doesn't work do a full restore of your phone via iTunes.
Mar 15, 2013 | Apple iPhone 3G
2003 Lincoln ls v-8 cruise control won't engage. Light won't come on or anything when I hit the button. Everything else work fine.
My 2001 Lincoln ls cruise control will not work. Put in a new clockspring and that did not fix it. radio controls and horn work but the air bag light stays on continually after starting. The lights on the cruise side will go on an off -I have bought that part to replace but don't want to put on if that is not the problem.
Sep 12, 2012 | 2003 Lincoln LS
I replaced the battery on my remote starter and now it won't work. The lights come on but it won't turn over.
not in backwards (battery) but led should not show as they are polarity dependant, didnt format the remote by accident somehow? any error msg on dash?
Feb 18, 2012 | Directed Dei Valet 561r Remote...
Stuck on search for channels and I can't access the menu. All I can do is press the channel up button
Hello
Replace its Memory IC. This is a common fault to Sany Vizon. Memory IC; otherwise called as system memory, is a small IC, with 8 solder terminals. It can be located very near to the main system IC. Its number is the most important to note. It should be same as the present one, otherwise won't work. If you have some technical skill in electronics, you can do it by youreself. OK.
Jun 20, 2011 | Sanyo HT28745 28" TV
Whirlpool 7cycle 4temp dryer won't start. I can hear the timer working, but the start button only vibrates slightly as if there's a partial electric current. Can't even find a model number/...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 18, 2011 | Dryers
The colon between the numbers on the clock, example 8:00 won't stop blinking even after I set the clock and hit the clock button again.
Sometimes the correct procedure for setting the clock is to press the CLOCK or TIME OF DAY button, then enter the time on the keyboard, then press the START button instead.
Otherwise, as long as you can enter a cooking time and your oven operates normally, then don't worry about it. On some models it is normal for the colon on the clock display to blink all the time.
Good luck.
May 11, 2011 | Microwave Ovens
Number 7, 8 & 9 key is not working
change your keypad or clean keypad.
Feb 21, 2008 | Nokia 6600
Clarion car radio
Hi I had the same problem for my clarion but through many frustrated attempts have worked it out you hold down the clk button till you get a 0 onto the computer screen then you start to type the first number of your code using the find seek button on the radio clicking clk between each number hope this helps
Nov 15, 2007 | Car Audio & Video
HP 48gx Calculator Logo
210 people viewed this question
Seeker5211
Seeker5211
