Question about Whirlpool Dishwashers
My dishwasher has the "CLEAN" light flashing. I can't clear if and it won't run. How do I fix this issue or do I need a Repair Man ?? Suzanne
    President:
  • 1,382 Answers
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
- The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press: HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Posted on May 27, 2010
  • sebarnhart May 27, 2010
    THANK YOU. i WILL TRY THE "dance" THIS EVENING. iF IT DOESNOT WORK i'LL BE BACK !!!
    Suzanne
  • sebarnhart May 28, 2010
    Well.....I tried the "dance" last night. Question....did I need to play music ?? I guess not because IT WORKED..YEAH. Thank you !!!
    Suzanne
Clean light blinks on whirlpool dishwasher won't run
When the light flashes 7 times it means there is/was a problem with the hot water, including a bad heater element. Flip the breaker for a minute and hopefully that will clear the error; otherwise, here's a website that will take you through resetting it.
Apr 04, 2013 | Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
The power light on but the play station wont come on then the light flashes yellow?
hi there Suzanne
This is Yellow light of death and in the gaming world its known as the YLOD.
You can send the console to Sony to fix for around $150 4-6 weeks of waiting time.
The More popular choice at the moment is to fix it your self at home using a PS3 repair guide made by a professional ps3 repair man for the complete beginner costing around $30 - $40.
You can see why its more popular and why gamers are turning to repair guides everyday.
Go to GAMER FIX and you will find a full description of your problem, also Sony's details if you wish to contact them and the most recommended ps3 repair guide on the web.
You will get back to gaming with either option
Best regards
Nov 05, 2011 | Sony PlayStation® 3 (60 GB) Console
Clean light flashes 7 times on Whirlpool DU1148XTPB3 dishwasher and it won't run.
The light flashing 7 times indicates error code number 7 and E7 is a error code for the flowmeter. What the flowmeter does is measure the amount of water coming into the dishwasher. The E7 error code can be cleared aby pushing the buttons in this order
HIGH TEMP WASH-HEATED DRY-HIGH TEMP WASH-HEATED DRY -- OFF/CANCEL
The error code will be cleared after pushing the buttons in that order...if after running the E7 error code returns the flowmeter would need to be replaced
The flowmeter is the part on the left side of the tub it is where the water enters the tub
The part number for it is W10195536
GENE
Sep 05, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
'clean' light flashes
Press the normal wash then heated dry buttons in the same sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button.It will clear any existing faults and makes the dishwasher to operate normally.
To prevent the issue from recurring, run your hot water faucet first to ensure that hot water is present in the entire supply line before starting the filling.
Oct 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 655.13222 k601 bought 5 months ago after
Call sears and they can tell you normal cycle times according to your model. 1888.536.6673. Maybe argue with them to replace this unit since so many issues within 5 months.
Mar 26, 2017 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Soap dispencer won' t dispence soap
My Bosch intergreted dishwasher is only 3 years old. For the past year, the dishwasher dispenser refuses to open on the second cycle. We have had the repair man here 3 times, and each time he says it's fixed,but it clearly is not. Does anyone know what to do about this??
Barbara Berger
Sep 30, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Whirlpool clean light flashes 7 times
Actually, the button order to put it in a diagnostic cycle and clear the blinking clean light on the gu2500 is HEATED DRY, NORMAL, HEATED DRY, NORMAL not the other way around as Iden had posted.
Mar 27, 2007 | Whirlpool 24 in. GU2500 XTP Built-in...
Clean light flashes
solution 2 is the best which is as follows..
The clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again..the pressing of the buttons takes several attempts. the lights on the front panel will all light up and the washer will go through a cycle. it will be fixed upon completion of the cycle
May 29, 2006 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwashers Logo
54 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
