My Goodman heat pump doesn't seem to cool anymore. The pump does not start at all when we put it to Cooling. However, the pump works well when we put it to Heating. The compressor was changed in 2006 even though this is not a very old heat pump (2001).
    Scholar:
  • 178 Answers
Sounds like a bad reversing valve. Look into that before considering a new compressor again.
Posted on Apr 07, 2008
SOURCE:
Goodman heat pump stopped cooling
yes, but I would try a "hard-start" kit before replacing the compressor itself
Jul 10, 2010 | Goodman CPLE24-1 Air Conditioner
Finding Pilot light on Goodman Model caf024a2a. Cannot seem to find the pilot light...The blower works but no heat.
i think the ca # is for the cooling coil unit - the heater should start with gmXXXXX - if your unit is fairly new - the pilot light electronically when thermostat calls for heat the unit will not light if the burner door is open
Oct 24, 2009 | Goodman Heating & Cooling
Goodman with 2 thermostats, freezes in summer, no heat in winter
is the system zoned? if so maybe the zoning control board to the damper motor is wired improperly. when a system freezez its because of 1- restricted air flow across coil, (maybe dirty filter) or 2-low refrigerant charge. again could depend on how its zoned.
Feb 16, 2009 | Goodman PHKJ048-1 Air Conditioner
Goodman PHJK048 Heat Pump Package
ok...where to start.lol ....the thermostat is just a switch.It will tell the unit to run or not run.if you measure the temp with the heatpump running,the air is warmer than 68 but it feels cool to you because your body is 98.6.The unit will run more often and for longer periods when the temperature drops outside for a few reasons.First,your house has more of a load to heat,meaning you have more heat loss because of the difference in temperatures outside and inside.Second,your heat pump pulls heat from the outside air.The colder the air outside,the less btu's for it to pull.If you have anymore questions [email protected] Hope this helps,Dave
Nov 10, 2008 | Goodman PHKJ048-1 Air Conditioner
1995 ford escort 1800 petrol
cooling system is a simple pump and radiator to cool if water is not pumping or circulating check for rad blockage thermostat stuck closed. need to know more...... how bad did you overheat it??? blown headgasket??
Aug 31, 2008 | 1995 Ford Escort
Goodman ac / heat pump
I just had a new unit installed and I am surfing for troubleshooting tips too. My unit is doing the same... cools well heat sucks. my problem has been isolated down to the reversing valve... It is constantly energised which means it is constantly in a/c mode even when kicking on the heat strips... We disconnected a line at the thermostat and it is working well as a heater now. You may want to check yours to see if it is actually kicking over into to heat mode... -rob
Nov 25, 2007 | Goodman CLQ36AR49 Air Conditioner
Warm Air in Cooiing mode
Warm air in cooling mode usually means that the thermostat needs to be set to energise the reversing valve in cooling. To do this is simple just by opening the stat and moving the selector switch to o. Everything else will wire color to color. r-r, g-g, y-y, o-o, w-w and brown. If you want the heat strips separate wire brown to emergency heat on thermostat. Hope this helps, RepairUSA
Aug 31, 2007 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
236 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
