Question about Vizio L30WGU 30 in. HD-Ready LCD Television
The DTV/TV cable antenna input screw broke off on my Visio 32" TV. What do I do?
4 Suggested Answers
SOURCE: Scanning dtv channels
go to menu setup and do the full system reset setup option... Then before you scan for channels make sure it is set to cable... This fixed the problem for me.
Posted on Feb 12, 2009
budmrtn
  • 11361 Answers
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Posted on Dec 23, 2009
welcomejee
  • 10594 Answers
SOURCE: broken coax cable connector/DTV/TV Cable/Antenna
Tuner will be replaced because Coax Connector is fixed part of tuner and next problem is that tuner is not available as spare part, it is mounted on tv main board so main board will be replaced to solve Coax Connector problem OR check with local tv repairman if he can do some thing with connector.
Below image is main board of tv and tuner is marked with yellow circle to have better idea.
Hope this will help.
Thanks.
Posted on Jul 09, 2011
The DTV input in my GV46L stays black. Why?
You don't say what you are trying to input but take note that your model does not have a digital tuner on the DTV input. If you use a digital OTA antenna, the signal must first go through a digital converter or tuner before it goes into the DTV input. The DTV/ANT input is only cable ready. There is no digital tuner in the TV to activate the DTV menu.
Nov 02, 2012 | Vizio GV46L 46 in. LCD Television
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
Does this model have a digital tuner or do I need to have a box to watch televison over the air?
Yes this tv dose have a digital tuner inside of it,all flats LCD and Plasma tvs are Digital tvs they all can get free DTV air broadcasting tv channels.All digital flats LCD and Plasma tvs are DTV set u just require a very good like a roof Antenna or a newly Digital design portable Antenna connected the tv incomming air broastcasting signal cable back of to the flats screen tvs at the axail input call ANT.Then go into the tv menu.Goto setup go down pick AIR than press the enter button for scanning for free DTV air broadcasting channels.After the tv finish scanning for channels than the tv will let ur tv to get all the free DTV broadcasting channels.
Sep 29, 2011 | Olevia LT32HVE 32 in. LCD Television
I do not see a standard cable input on the tv...is there an adapter to connect standard cable line to the antenna input?
if the TV has 2 screws for an antenna connection then you could use what is called a BALUN aka matching transformer. you can buy them at a dollar store. it has a male cable connection and 2 wires.
I am surprised that an LCD TV would have an antenna connection, they are from the days before cable TV.
if your TV does not have a cable input you can use an old VCR as a tuner
or buy an RF converter (but they are overpriced IMO)
you would plug the TV cable into the VCR and use rca cables red,and white for right and left audio, and yellow for video
Jan 10, 2010 | Mintek DTV-265-D 26 in. LCD TV
I can't scan DTV channels on my vizio 52''
do you have antenna or cable? if you have antena hook directly to the coax, go to menu, TV, tuner and pick antenna and scan. If you have cable hook directly to your coax repeat the previous step but pick cable instead of antenna. Notice if you have a cable box, you will not need to scan for channel since it will be on channel 3, 4 or any other input you may use.
Jun 20, 2009 | Vizio L32 32 in. LCD HDTV
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
After the DTV switch, should I be placing the cable cord into the dtv output to receive all the DTV channels? Protron PLTV 3250 is the set I have and it doesn't seem to get the DTV channels like my other...
Your question is confusing. If you have cable, you don't need a DTV converter box.
If your cable company has switched to digital cable, they will provide you a box, and the cable should go from the wall into the box, then into your TV.
If you don't have cable but instead rely on an antenna, then the wire will go from the antenna into the DTV box, then from the DTV box into the back of the TV. If you're using a regular coaxial cable to go from the DTV box into the television, the TV should be set to channel 3. If you're using the red-yellow-white RCA wires between the DTV box and the television, the TV must be tuned to "Aux," "Line In," "Input Select," or whatever it's labeled on your particular set.
Jun 12, 2009 | Protron PLTV-3750 Television
DTV Box
Dtv Ready Only Means That It Has A Cable Outlet On The Back They Are Gonna Need The Digital Box If They Wanna Continue Getting Antenna Stations.
Jan 07, 2009 | iLO 3200 32 in. LCD Television
Want to use DTV converter with my Toshiba 32AF42
If you're not on cable or satellite, you will need an antenna to get off-the-air reception. This TV does not have a DTV tuner, so you will also need the converter box. Depending on how far you are from the broadcasters' transmitters, you might be able to get away with an indoor antenna. Or you might find that you get few channels with the inside antenna and then you'll need something outdoors. There are a number of styles to choose from.
The antenna hooks to the converter box, and the converter box then goes to the TV. It can be hooked to the TV's "ANTENNA" connector. This should be covered in the set's manual where it shows you how to connect a regular antenna. With the box, your TV will always stay on channel 3 or 4 (depends on how you set up the box) and you'll change channels on the converter.
You can also connect the converter to the TV with audio and video cables like you would a DVD player. Most of the "coupon-eligible" converter boxes include direct video and audio output jacks. This gives you better picture and sound quality than by hooking it to the TV's antenna input.
Hooking up a converter box is like going back in time to when cable TV was new and you had to get a converter box from your cable company. Same way of hooking it up. Hope this helps!
Dec 07, 2008 | Toshiba 32AF42 32" TV
Dec 06, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L30WGU 30 in. HD-Ready LCD Television Logo
328 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
