Question about Casio Exilim EXZ1050 Digital Camera
My camera just shut off and the lens wont go back in. if i try to turn it on it just makes a weird noise and the screen flickers
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 28, 2010
Seeing how the warranty had expired and steps 1-6 did not work, my wife noticed that the lens (extended and unable to return into camera) seemed off-kilter. She forcefully pushed it back into the camera, which to my amazement, worked!<br /><br />Thanks so much.<br /> <!-- from fixya rte -->
Posted on Aug 11, 2010
Why does my camera turn on, make a weird noise and
hi. you have problem in lens unit and the weird noise come from to focus gear.maybe you go to the beach or dusty place thats why the said dust or sand goes into lens gear. If you can open and try to clean its better but if not bring to service center and request for cleaning and adjustment.
goodluck my friend
Jul 13, 2010 | Casio EXILIM 10.1-Megapixel Digital Camera...
We went to the beach yesterday and after the whole day was done my camera lens is stuck open and it wont turn on when i try it makes a weird noise and turns back off.
I would try to gently push the lens back in hoping itll click into place..but thats risky!!!You can take it apart and try to ge the lens in this way, But again,Risky! Last thing:
Send it in for service. The manufacturers' warranty seldom covers abuse though. If it isn't covered, the repair cost will likely exceed the cost of a new camera.
Jun 15, 2010 | Cameras
Camera lens will not close when i turn off camera!
please make sure nothing is in the lens, even dust.
Apr 16, 2010 | Samsung S760 Digital Camera
Camera says
Hi there just like to informed you that 2 reason can make a noise.
1. low or old battery's using.
Solution: replace it if too old or charged it fully.
2. Lens error. Internal lens guide pin if damaged then the camera goes off with bad noise.
Solution: repair or replaced the lens guide pin.
Thanks & waiting for your feedback.
Apr 01, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
My camera lens won't go back in and is making weird noises.
Since you said it makes noise when you turn it on, the gear system controlling the lens might be faulty. have it checked.
Sep 16, 2009 | Panasonic Lumix DMC-FS3 Digital Camera
Olympus FE-280 not working properly
the lens could be the problem.. probably need to send to repair before the warranty runs out
Aug 28, 2008 | Olympus FE-280 Digital Camera
E18 error pops up and to make it worse the screen is green and its making a lot of beeps
http://blogs.yucs.org/~dwallach/2004/08/canon_e18_error_repair_instruc.html
The better solution is to send it to Canon's service people.  They can fix he problem is the fixes at the above site won't work.
Mar 05, 2008 | Canon PowerShot A520 Digital Camera
Casio Exilim EXZ1050 Digital Camera Logo
216 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
