Question about Toshiba Laptop Keyboard for Satellite L10, L15, L20, L25, Tecra L2 Series
Touch pad problems
How can i disable touch pad with fn keys on key board.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 135 Answers
Most of the toshiba laptops can disable touch pad with FN + F9.
In F9 key u can find touch pad picture.
Posted on Jun 01, 2010
I want to disable my touch pad.
There may be an Fn-Key combination that allows you to toggle between ON and OFF. (maybe Fn-F9). The relevant key should have a picture of a touch pad.
Apr 22, 2012 | Computers & Internet
First at all, I'm sorry about my terrible Eng. I have a HP 6720s laptop and there is a problem with touchpad. How can I disable the touchpad with 'fn' key? I looked every pages on my...
OK to disable you Touchpad you can press Fn + F12 or you can go to Control panel...Search for devices...or you can go to Device Manager. In the menu Look for sp/1 or sp/2 it will have your installed components or drive information for you mouse pad/touch pad. You can right click it and disable it. Also if you are having problems with you Touch Pad you can also download the driver and re-install in on your drive.
Go to this website: CLick Here For Hp Synaptics Drivers.
Click Your OS,
Search For Synaptics driver.
May 24, 2011 | Computers & Internet
I have an Acer Aspire 5517. Just the other day, my touchpad and keyboard stopped working. What do I do?
1 . Look for Fn function key - Most laptops have this special key Fn that is next to the Ctrl key on the keyboard. It should have a blue or green color, easy to find.
2 . Look for F1 to F12 functions keys, they are on the top row of the keypad. Look for one has an icon that looks like the touch pad, which is to control the touch pad of your laptop. It maybe F8 or F9 depends on each make of your laptop. These function keys also control the brightness, sound, wireless etc.
3 . Now hold down the Fn key and the F10 key to enable the touch pad, in this example, the Toshiba laptops. You press them again to disable it
4 . If none of the above works, plug in an USB mouse, then check into the Control Panel -> touch pad or mouse configurations. Also, check Device Manager if the touch pad driver is installed and working properly.
Thanks.Have a great day.
Oct 17, 2010 | Acer NSK8458AN Keyboard
My Hp Laptop's touch pad is not reponding to touch. Please help me. The curser reponds but not the touch reponse. The touch pad reaponds to scrolling but not to finger tappings. The two right and left bars...
there is a key combination that enables/disables the touch pad. it's the Fn key + the function key that shows a little mouse icon in blue at the top of your keyboard. on Fujitsu this would be Fn+F6 for instance. if this doesn't work, it is possible that the touch pad has been turned off in the BIOS setup. you will have to enter the BIOS and enable or automate the "internal pointing device"
Apr 21, 2010 | HP Pavilion dv6000z Notebook
Cs walked on my laptop. noow cursor pad not working. Help
have a look at the F keys - is possible one of those disables the touch pad
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to claasic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 20, 2010 | Compaq (153515-001) Touch Pad
Jumping letters on acer laptop when I type
You need to disable the touch pad while typing. During typing your palm can accidentally touch the touch pad causing the cursor to 'jump' randomly resulting in the problem.
You have not mentioned the model but on Acer laptops there's a key in the upper row with a 'pad and finger' figure on it. If the figure is in blue, press Fn together with the figure key to disable the touch pad and then again to enable it.
Mar 31, 2010 | Acer Computers & Internet
I have an Asus K60 Laptop.I can not figure out how to turn off the touch pad, as I am using a wireless external mouse instead of the touchpad on the laptop.Any clues?
Did you try the FN key and F9...
That is what they say to disable your touchpad
You have a function key which is called Fn That key allows you to use the functions on the F series keys
So Fn then F9 should do the trick
Nov 08, 2009 | ASUS Computers & Internet
HOW TO DISABLE TOUCH PAD DELL LAPTOP
You should have a "FN" key on the keyboard and one of the "F" keys should have a symbol that looks like the touch-pad, hold FN while using this key should disable it, failing this in control panel, then mouse and pointers, you should have touchpad setting there should be a disable button/radius.
Sep 04, 2009 | Dell Inspiron XPS M140 Notebook
My toshiba laptop cursor doesnot move when i touch the tray pad
Hi!
I had the same problem after my fat cat sat on my keyboard. This is how I fixed it. At the top of the keyboard there is a F9 key. If you look closely at this key, it also has two pictures of the mouse pad. This key is a toggle that turns the mouse pad on and off. Down near the lower left corner of the keyboard is a key marked FN. Hold down the FN key and press the F9 key. That will turn the mouse pad back on.
BTDT, HTH
Jun 13, 2009 | Acer Aspire 5610-4648 Notebook
Deactivate the touch pad
Try holding down FN key and F( key. This activated and de-activates the touch pad
Apr 25, 2009 | Toshiba Satellite A20 Satellite A25 Series...
Toshiba Laptop Keyboard for Satellite L10, L15, L20, L25, Tecra L2 Series Logo
571 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
