Question about Microwave Ovens
How high should my micro wave oven be mounted from the floor?
There is no specific height for mounting the Oven.You can mount it according to your convenience .
Posted on Apr 07, 2008
There is no specific height, your can mount accordinf to your convenience to operate.
My Daewoo Micro Wave Was Spitting Flames Last Night Due To A Hole In The Wave Plate
Hello Stephanie.
Get a new filter and try again.
Otherwise scrap the micro.
It the filter plate rusted through, or is it burnt?
The microwave's Magnetron-wave-guide is just behind this filter plate.
Looks like a small tube with a silvery cap with hole in center.
Very hazardous condition here.
The high energy from it is damped by the filter.
Is there food in the micro when arcing happens?
An empty micro will arc.
Sep 23, 2017 | Daewoo Microwave Ovens
Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
Aug 22, 2011 | Microwave Ovens
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
The microwave appears to be working but it is not heating up the food.
Several things can be wrong, 1st the diode which connects to the capacitor may be bad, the capacitor may be bad or the magnatron may be bad. Unless you are very very familiar with micro waves and high power I suggest a qualified appliance tech. Even with micro wave unplugged the high voltage area which all 3 of these components are can kill or cause serious injury. Sorry but do not feel comfortable telling you how to get to these for your own safety.
Feb 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I'm getting a flash inside the oven and the plastic on the inside roof has a burn mark. I removed the plastic cover over the micro wave generator and it did not spark. is the oven dying? It is a 1983 0ver...
It looks like the metal part inside the oven is exposed to the high frequency rf waves. this may sound strange but try coating the metal part with fresh paint. remember no metal inside the oven will stand the waves created inside the oven the spark u see is the waves hitting the exposed metal part inside the oven
Oct 13, 2009 | Magic Chef MCD1311ST Microwave Oven
Micro wave has come loose from hanger on bottom. Need to know how to reattach microwave to brackets. maytag mmv5100
MOST OF THEM YOU CAN TAKE THE SCREWS LOOSE FROMTHE TOP OF THE CABINET OVER THE STOVE, YOU NEED TO PPL, REMOVE TOP SCREWS HOLD IT AN TILT IT AN THEN PULL IT AWAY FROM THE WALL, MOST WALLL BRACKETS HAVE A HOOK THAT THE MICRO MOUNTS TOO IT 90%OF THE WEIGHT IS BEEN HELD BY THE WALL. GOOD LUCK LEAVE SOME FEEDBACK.!
May 28, 2009 | Maytag MMV5100A Microwave Oven
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
I need mounting instructions for frigidaire model plmvz169gcb
You can download Frigidaire owner's manuals and installation instructions here.
Jan 02, 2009 | Frigidaire PLMV169DC Microwave Oven
PAINT IN MICRO WAVE OVEN
It will have to be sanded smooth and clean and dried thoroughly.
Then you can apply high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 21, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Microwave over the stove
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
It may also be a problem with a door switch or door switch mount.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
Nov 27, 2007 | Frigidaire GLMB209D Microwave Oven
Microwave Ovens Logo
185 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
