Question about Samsung AS18A6RB Air Conditioner
Split unit. blows condensed air/water out early in the morning? I have check the gas pressure with is 150psi It is the only unit that has this problem and I have five of them throughout the house.
  • 420 Answers
Check to make sure the unit is tilted enough to drain the water out the back. If the tilt is at least 3-5 degrees toward the outside make sure the water can drain from the cooling coil to the rear coil (plugged drain circuit?)
Posted on May 27, 2010
Is the condenser inside the unit
In a window unit the condenser is in the unit and is at the back of the outside section. With a split system or whole house cooling unit the condenser is always outside. The condenser compresses the cooling gas after it picks up heat from the inside evaporator, and forces the heated gas through a coil with a fan blowing through the coil to drive out the heat. A gas can be compressed, but the amount of heat it contains remains constant. A compressed gas will be hotter than non compressed.
Jul 26, 2015 | Heating & Cooling
I have a dailkool split ac my split is not cooling well as compared to the cooling when i buy??so there is a problem of compresser or the gas of compressor
The only way to know if the unit is low on gas is to take pressure readings referring to pt chart for the type of refrigerant the unit uses. doubt it is the compressor. Also check the condensing unit if the coil is dirt covered in bugs or cotton wood your unit will run with high head pressure and not be as efficient.
Mar 08, 2013 | Heating & Cooling
How should I disconnect outside unit pipes from inside unit "IAQT32C2bedhac" air conditioner without losing liquide/gas?
Hello, if this is a split system AC then you can pump down the refrigerant into the condenser. You would need a set of gauges to do this. It would involve checking the pressures and closing off the liquid line and suction line, this will keep the refrigerant in the condenser and allow you to disconnect the line set.
Oct 06, 2011 | Heating & Cooling
How to install split type aircon?
Plan the location of your outdoor and indoor unit. Make openings for the pipes and wiring's that should be accessible for repairs or maintenance. Never place the condenser near the walls, and follow the allowable clearance from the walls. Same thing follows for the indoor unit make allowance from the ceiling and it should be tilted to drain the water from the drain pan. Make the piping and wiring connection following the suppliers recommendations. Drain pipe should be lower than the wiring installation. Do not use seal tape for threaded connection, only apply refrigerant oil and tighten all nuts. Leak test or vacuum the lines from the valve fittings outside the condenser to the evaporator( in and out of the evaporator ). If vacuum or pressure stays unchanged for an hour, there is no leakage. If you applied vacuum, just fully open the service valves. If you pressure test the line with Nitrogen, release Nitrogen gas by loosening a little the bigger pipe nut from the condenser until no pressure comes out.Then open the small service valve from the condenser a little until pure freon comes out of the loosen big nut and then tighten it. Full open all service valves and unit is now available for operation with power supply.
Sep 03, 2011 | Friedrich (5TF37) Split System Air...
My 9000 Btu Kenwood Continental Series split unit shuts down compressor after every 10-15 minuits regardles of room temp. Gas pressure is OK & I have tried replacenig cooling sensor but to no use. I am...
Sounds like the compressor may be overheating. You need to check the outdoor condenser coil it may be stopped up with dirt, in turn, overheating the compressor. The condenser coil looks like a radiator and the outdoor fan blows through it, in a sense releasing the hot air from the building. If the coil is stopped up, it can not release the heat. You can wash this coil out with a hose and sprayer. Just be careful not to get the motor wet and be sure to shut off power.
Jun 24, 2011 | Kenwood Heating & Cooling
I have a 24 ton mini split, that has never worked correct. It used to blow cold air, but only for a little while, then it set error codes including p4, and p8. The heat functioned used to work ok. Now it...
Code P8
Error detail Abnormality of pipe temperature.
Inspected unit Indoor. Due to non condensable gas/over charged/condenser dust blocked.
For non condensable gas, remove gas and flush out and then recharge gas./remove over charged gas/clean condenser coil
Aug 25, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
MY RAMSOND MINI SPLIT HIGH PRESSURE LINE IS FROZEN EVERY TIME I TURN THE UNIT ON
The expansion valve or the capillar tubes are inside the condenser and the gas (freon) is already expanded right outside the condensing unit all the way to the evaporator and beacause the diferential of temperature between this copper line (which is not high pressure anymore) and the outdoor air , there's condensention that freezes up.
Oct 15, 2009 | GE Quiet-Aire Ductless Split System Air...
LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
I got a 1.5t split a/c.Now water is leaking in the front side from the indoor unit which creates discomfort.what could be the problem
Your condensate drains is probably plugged. You gotta get to the drain from inside the panel and blow out the drain with some pressure.
Apr 16, 2009 | Heating & Cooling
Oil Leak
This would indicate a leak somewhere in the condenser sheet coil. I hate to be the bearer of bad news but you should call a service tech in to fix this problem.
Aug 29, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Samsung AS18A6RB Air Conditioner Logo
183 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
