Question about Toshiba Satellite Pro M15-S405 Notebook
Touchpad is not working and does not show up in
Toshiba L355-S7915 Vista sp2
The touchpad is not working and does not show up in control panel>system>device manager. The only mouse that shows up is the usb mouse.
    Scholar:
  • 104 Answers
You need to reinstall the Synaptics driver from Toshiba. If you do not have the Toshiba driver CD for your laptop you can try the generic ones from : http://www.synaptics.com/support/drivers
The touch pad may also be disabled in the system bios, (ie the options before you boot through to windows) Re enable it there if you are sure it is not a driver problem.
If still no joy, your local Toshiba agent can advise free on rectification, but you have to take the notebook in to them.
Hope this helps.
Posted on May 27, 2010
How do I disable the touchpad? I am running Vista Home Premium. There is no Function key to enable/disable the touchpad. I disabled the touchpad by going to Control Panel, Mouse, and disabling the...
have u gone to control panel - device manager - then on pull down menu's show hidden devices ; click on all the + boxes till you see touchpad ( mouse and pointing devices) right click mouse and click on disable.
i always go through device manager as all devices are in one place!!
Apr 11, 2015 | Gateway M-6827 Notebook
Sony vaio all in one touchscreen stopped working
XP and Vista Normal Mode Start your computer as you normally would. Click the "My Computer" icon on your desktop. Go to "C:\ Program Files\Sony\Setting Utility Series." Find and choose the "VCCPointingDevice" folder in the "Setting Utilities Series folder" to open the "Built-in Pointing Device" dialog box. Locate the "Enable" box on the "Built-in Pointing Device" dialog box. Check the box to enable the Vaio touchpad if you wish to use this device. Disable the touchpad if it is interfering with the external mouse. Uncheck the "Enable" box if you have a USB (PS/2) mouse connecting to your Vaio and wish to use that instead of the built-in touchpad. Pick "Yes, I'm Sure" when prompted to activate your choice, then close all the windows. Windows 7 Normal Mode Launch Windows as usual. Go to "Start" > "Control Panel" > "Mouse" > "Pointing Device" to open the Vaio touchpad control center. Uncheck the "Enable" box on the "Pointing Device" window when you wish to use your external mouse. Check the "Enable" box on the "Pointing Device" window when you want to use the Sony Vaio touchpad. Make sure the external mouse is not interfering with the touchpad if you have one connected. If so, unplug the mouse from your computer. Click the "OK" button at the bottom of the "Pointing Device" window. Close all other windows. XP and Vista Safe Mode Restart your computer. Press the F8 key before the Windows welcome screen appears to enter Safe Mode. Click "Start" > "Control Panel" > "Add/Remove Programs." Find and delete all software for mice and pointing devices. Restart your computer in normal Windows mode. Proceed to next step if the problem persists. Restart your computer in Safe Mode. Right click the "My Computer" icon on the desktop. Choose "Properties" on the drop-down list. Pick the "Device Manager" tab in the Properties window. Select the "Other Devices" folder and click on the "+" sign besides it. Delete all the devices under this "+" sign by clicking on the "Remove" button next to each of the items. Restart Windows in Normal Mode. Once Windows is operating, there will be a "New Hardware Wizard" pop-up that will load all the necessary drivers for the touchpad, mouse and other pointing devices. This should fix the corrupt driver for your Vaio touchpad. Windows 7 Safe Mode Reboot your computer and press the F8 key before the Windows welcome screen appears to enter Safe Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Click the touchpad icon. Choose the "Driver" tab and press the "Uninstall" button. Press the "OK" button to confirm. Restart Windows in Normal Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Choose the "Driver" tab and press the "Update" button. Press the "OK" button to fix the touchpad software.
http://esupport.sony.com/perl/swu-list.pl?mdl=PCGFRV26
Feb 08, 2013 | Sony VAIO Computers & Internet
Sony vaio touch screen stopped working
Feb 08, 2013 | Sony VAIO VGC-LV180J 24-Inch All-in-One PC...
Upgraded toshiba a305-s6852 from windows vista to windows 7 FN buttons no longer work'
"Don't mean to insult .. but did you go to toshiba's website and follow their instructions?
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2060005&rpn=PSAG0U&modelFilter=A305-S6852&selCategory=2756709&selFamily=1073768663
** FORTH FROM THE BOTTOM **
How to Upgrade Toshiba laptops to Windows 7
You will need your serial number to match against which path to take. They have an "installer" program that will help you get the drivers.
Jul 28, 2012 | Toshiba Satellite A305-S6852 Notebook
Double click on mouse not workin
Does single click work? if so, the problem is the amount of time between the first click and second click, if the delay is too long, the computer will only register it as 2 single clicks.
Double click settings are change in control panel > mouse
Feb 08, 2012 | Toshiba Satellite L355-S7915 Notebook
Touchpad doesn't work on Toshiba Satellite 305 PSAGU-03601V
Go to
Use a mouse or Tab+Aly keys
Win XP
Start > Control Panel > System
Click the "Hardware" tab
Click the "Device" manager button.
Click the cross near "Mice and other pointing devices".
Right click, "Enable"
Vista
As above but
Start > Control Panel > Device Manager
Mar 18, 2010 | Toshiba Satellite Pro M15-S405 Notebook
My acer aspire touchpad frozes
right click My Computer >> Manage >> Device Manager.
See if the drivers are installed
May 22, 2009 | Acer Aspire One PC Notebook
Touch pad not working properly
Plug in a usb mouse and go to control panel>system>hardware>device Manager (if using XP) or control panel>system>device manager (if using vista) and right click on pointing devices, unistall the touch pad and reboot - remove the usb mouse and the touchpad will be installed again as new hardware. I hope this helps
Nov 28, 2008 | Toshiba Satellite A135-S2276 Notebook
I have toshiba notebook A200.I have been using a USB mouse,and I now can not get the touch pad to operate.Plerase advise me what I can do.I have tried FL F9 to no avail.
If you unplug the mouse and then start up the machine does the touchpad not work at that point?
Some systems have a settings in BIOS that prevent the touchpad from working if a mouse if connected.
Try unplugging, start up and if the touchpad doesn't work, shut down and go into the system settings and turn on the touchpad (if turned off).
Also, make sure the device manager doesn't show any Yellow Exclamation points, meaning a bad or missing driver. To get to Device Mananger, go to control panel, system, hardware, device manager (in Windows XP that is).
Jun 01, 2008 | Toshiba Computers & Internet
Toshiba Satellite Pro M15-S405 Notebook Logo
915 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
